Low-Profile Electric Puller Fans
Patrick67BJ8
Has anyone found a low-profile electric “puller” fan for between the radiator and water pump (without the metal fan).
Also, an aftermarket shroud for the engine side of radiator?
I have an AC condenser in front of my radiator and a pusher fan does not efficiently push air through the condenser and radiator. A puller is much more effective.
Thanks
Patrick67BJ8
Patrick67BJ8
This is the narrowest I could find: > Maradyne 14in Electric Fan <
I found this. Wizard has a similar setup, but is a pusher. I’m going to contact both of these suppliers.
Cape has one with a radiator that is a puller. I assume that it fits since it’s for the six-cylinder Healeys. One thing is missing is a shroud, but may not be required. The fan is 2 1/16” thick.
bdcvg
I have just changed to an aluminum radiator with pusher fan and it was a huge failure. After staring at the whole package for 2 or 3 hours it occurred to me that simple brackets could be made to move the top of the radiator forward about 1 1/4 in. and spacers could move the lower mounts the same distance increasing the space between water pump and radiator.
Patrick67BJ8
Patrick67BJ8
What was the “huge failure”?
dougie
Thanks
Been there and done that....Custom design, fabricated and installed. Race tested and proven!
RDKeysor
Bronze
My effort to gain better cooling with a Chinese aluminum radiator also failed and it is for sale. But I write to say that British Car Specialties in California sells a two-piece steel fan shroud manufactured in Australia. I installed one on my BN7, which has a Texas Pusher fan, and it seems to have been to some benefit. Needless to say, living in Florida means engine temperature is always a potential concern with Healeys. I bolted the top ends the newly purchase shroud to either end of the red-painted protective piece that mounts on the engine side of the radiator. Pretty easy installation. Bottom ends use existing bolting points. Ever notice how Healey engine cooling elicits so many responses?
Patrick67BJ8
Patrick67BJ8
The Wizard with fan. $719.00
If they can do a pusher why can’t they do a puller!?
bdcvg
Yep, this is what I just installed. It works great with the Texas cooler mechanical fan. sits between 190-195. Complaints about Wizard. 1 Metric threads on mounting lugs so get new bolts. 2. No petcock supplied and so far no luck finding one that is correct threads metric or other wise. 2. For that price They could have tossed in #'s 1 & 2 and a radiator cap. The pusher alone was useless. It blocked so much flow the temp just kept creeping up.
Keoke
Keeping fan noise down requires the use of unequal fan blades.
Enhancing the fans performance is achieved by incorporating a shroud
bdcvg
Don't care about that. Real world is engine runs better without mechanical fan and noise without mechanical fan is greatly reduced. Fan is just a passenger after 30 mph, shroud or not. Aluminum radiator keeps 190-195 as long as air moves through it. A pleasure-driven street car needs a shroud like a fish needs a bicycle.
HealeyRick
I've got nothing but good things to say about Wizard. Keeping a V8 cool in a Healey isn't an easy task, especially considering the space considerations that limit the size of a radiator that will fit. All the info I could find said a pusher fan isn't ideal as it blocks incoming airflow. Wizard worked with me to modify their Healey radiator to move the inlet to the opposite side to match the Ford water pump and add a shroud to work with the Maradyne fan I mentioned above as a puller. Their workmanship is top shelf with some beautiful welds.
Warren
This is what improved my cooling this season...........original radiator w\baffles\10" pusher fan-thermostat. Ambient temps have been 80's and 90's F.
Drain and flush........with,
https://www.autozone.com/antifreeze...estone-radiator-flush-cleaner-22oz/223022_0_0
Add 50\50 Prestone coolant and Water Wetter.
Removed front license plate which may have been impeding airflow at speed?? Ohio no longer requires front plate.
Engine in tune and timing correct using premium Sunoco fuel. Slowly creeps past 190 in
traffic but quickly cools and stays in the 180's(185 thermostat).
5 plus degrees improvement. Best cooling I've seen in years.
(Was that front license plate, located center bumper, blocking that much air at speed??)
WD 67 BJ8
K TR2/3/3A Volvo low profile space saver spare tire for TR3 ? Triumph 1
I Is there a low profile tire for 73 MG 6
X spring ride height/ low profile tires/minilites MG 2
roscoe Low-Budget Luggage Rack Austin Healey 27
Donald1107 TR2/3/3A low cylinder compression Triumph 12
D Lucas Low-Tension Leads Austin Healey 1
CJRams For Sale 1974 Rolls Royce Silver Shadow - low mileage, all original Other British Classifieds 0
rgfrey 1959 Low Beam Headlights Not Working Austin Healey 5
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
F TR6 Sputtering at low rpm Triumph 16
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
Joe Schlosser Spedo reading low Spridgets 8
T TR6 Low Oil Pressure Light Triumph 3
F TR6 Squeal When Turning Sharply at Low Speed Triumph 6
F TR6 Carburetor issues at low rpms webers Triumph 23
RAC68 Heavy Tapping low in the Engine Austin Healey 58
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
Geo Hahn TR6 Low Miles TR6 on eBay Triumph 4
TomMull Volvo Low Rider spotted in Vassalboro Me Other Cars 1
RickPA Water temp gauge reads low Austin Healey 6
HighAltitudeTR3 TR2/3/3A Oil Pressure low all of a sudden Triumph 10
JFS Wedge Low Coolant Light Triumph 7
O Low manifold pressure! Jaguar 8
warwick-steve How low is too low? [spring question] Austin Healey 19
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
S Low entry cost into AH ownership? Austin Healey 18
C 100-4 At Mecum Kissimmee Auction-low price? Austin Healey 22
charleyf TR6 low speed stall Triumph 51
CJD General TR New Low for Ebay Triumph 21
Jim_Gruber BE Hi Low Beam Footswitch and Relays Spridgets 6
doc50 TR2/3/3A Speedo reads way too low Triumph 13
R Low Brake Pedal Austin Healey 9
Jim_Stevens TR2/3/3A OD low pressure vs Operating valve shaft setting Triumph 9
F TR6 Starter Relay = Low Engine Power Question Triumph 13
M TR2/3/3A Low charge with Alternator Triumph 5
B No Low Beams Austin Healey 1
CJD TR2/3/3A Low Port Head Cracks Triumph 36
aeronca65t Post-War Other super low mileage Herald Triumph 2
R low/high temp engine running question Spridgets 23
C TR2/3/3A TR3 Low Port vs High Port Head Triumph 10
NutmegCT TR2/3/3A low idle after a fast run - TR3 Triumph 4
AH67 ‎62 BN7 for $69,000? Seemed low to me.. Austin Healey 21
Jer Too Low of idle cause PCV to malfunction ? Spridgets 1
B TR6 Low mile tr6 Triumph 12
D Carburetor Backfire on acceleration at low speed Austin Healey 18
V Low Oil Pressure Triumph 4
H low oil pressure Austin Healey 15
