Boot Liner Edge Finish
Rob Glasgow
I have never cared for the way the boot liner exposed edge looks at the top. Was there some finisher strip covering the edge originally? I‘ve owned the car since 1963 and don’t remember anything there. Has anyone come up with a solution to cover the edge that doesnt look too out of place?
JoeCA
Your car probably differs from my BT7....but the original front armacord panel on my BT7 didn't extend all the way out to the edge that you show. I've been fitting a new trunk kit and it has required substantial trimming and a bit of sewing to match the original pieces and fit the car properly. I removed about an inch of material on the top of that panel to limit the reveal.
It would help if the insulation was black. Have you thought about using a black marker on it? You could try it in a corner on a short area to see if it helped. If you try it, be sure to mask off the painted areas.
It probably wouldn't be to difficult to make a finishing piece, but the trick is going to be attaching it without removing the front panel. I assume the piece is solidly glued to the top panel?
joe
Madflyer
As for the Boot liner is that wood on the back? Anything would be better than that good luck. I have used wrinkle paint and or vinyl on hard board on TR's and MG B's MF
John Turney
Mine stops about 3/4" from the bend in the panel, so I don't see the edge when standing. Now that you've brought it up, I could use some black Gorilla Tape (like a duct tape, only black and stronger) to tape up the edge.
Rob Glasgow
Rob Glasgow
Isn’t it funny. Sometimes when you have a problem, it’s best just to ask the question and the answer will come to you. I was repainting some chips on the bottom of the strip where the rear shroud meets the bottom of the frame. I was using flat black paint. I looked up and the solution was evident. Just paint the exposed edge. What do you think?
GregW
That looks pretty good Rob. My original thought was to use undercoat spray masking off the armacord. Seemed like the best way to do that was to remove the whole piece from the car. I painted a subwoofer for my Mazdaspeed with this stuff.
shopping
Rob Glasgow
Rob Glasgow
Joe, now that I see your original installation, I think my BT7 was finished the same way. I guess I missed that detail when I installed the new liner. Since the new piece was long enough to cover the overhang panel, I just assumed it needed to be glued there. Oh well, one of these days I might cut it back to the correct spot but maybe not......
JoeCA
Rob, I think your solution is simple and takes care of most of the problem. Removing that piece and the associated glue might get you into some paint problems. If it was me, I would just live with it and touch up occasionally as required.
If that piece started sagging and needed to be reattached...then I would probably deal with it.
joe
Rob Glasgow
Rob Glasgow
"If that piece started sagging".....sounds alot like me but replacing these parts are much more difficult. I will take your advice and leave it be. I looks perfect when the boot lid is closed....
Rob Glasgow
Rob Glasgow
I looked through some photos I took during my restoration and came across these two showing the original Amarcord installation. It was just like Joe's. Still don't think I'll change it until it becomes a problem.
S Boot Liner - BJ8 Austin Healey 19
tahoe healey boot liner/spare support Austin Healey 8
tahoe healey boot liner Austin Healey 6
G Wanted Tr4a boot lid Triumph Classifieds 2
mctriumph General TR Spring boot sale Umpteenth Annual Triumph 5
5 BJ7 Boot Rust-Through Austin Healey 13
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
K TR2/3/3A boot drain troughs 59 tr3 Triumph 7
AUSMHLY Boot Lid Identification Austin Healey 2
J Restoration Progress - Boot Installed Austin Healey 1
B BJ7 Boot Trim Austin Healey 7
B Fitting the Boot Lid Seal Austin Healey 8
chicken Boot Lid Badge Austin Healey 8
F TR2/3/3A Boot floor Triumph 50
steveg TR6 Dealing with Rack Boot Triumph 3
steveg TR6 Steering boot clamp wire - why? Triumph 2
T How do you cover your battery in the boot? Austin Healey 5
S Securing the jack with strap in BJ8 boot Austin Healey 11
Michael Oritt Boot floorboard? Austin Healey 9
C Under boot and under bonnet paint? Austin Healey 7
tahoe healey Leak into boot Austin Healey 17
B TR6 Boot lid thread plates loose in stiffener Triumph 1
G For Sale TR6 Matador Red Interior and Boot Triumph Classifieds 0
B Soft Top Boot Cover - BJ7 Austin Healey 5
A BN2 Boot Lid Austin Healey 4
W Gear Lever Boot for BN2 Austin Healey 5
ckeithjordan TR2/3/3A Boot Trim Triumph 3
1 Wedge Breaking Into a Trunk Boot Triumph 3
R TR2/3/3A Boot/trunk floor Triumph 5
B Dynamat in Boot? Austin Healey 7
S TR4/4A Fascia support and shift rod boot Triumph 0
S TR4/4A Handbrake cable rubber boot at clevis pin end Triumph 1
B Wanted I'm looking for a boot [trunk] lid and drivers rear fender for a 100/6 or 3000 Austin Healey Classifieds 0
H Wanted Braket that connects the boot lid to the boot lid stay strut on a Herald. Triumph Classifieds 0
Rhodyspit75 Replacing boot floor need bracing? Spridgets 2
CJD TR2/3/3A Boot Seal Pics Triumph 17
J BJ8 boot rubber strip Austin Healey 9
CJD TR2/3/3A TR2 Boot Strip Triumph 22
K TR4/4A TR4A vinyl top boot cover factory markings??? Triumph 0
K TR4/4A Black marks on a TR4A/TR6 vinyl top boot cover? Triumph 4
Rut TR4/4A Boot and bonnet bodywork. Triumph 4
D boot rubber ??? Austin Healey 2
Rut TR4/4A Parts in boot Triumph 11
SASSAMON TR2/3/3A TR3 Boot Construction Info Wanted Triumph 2
toysrrus TR6 "how to un-lock a boot lid"??? Triumph 11
R Boot hinge support brackets for BJ8 MKIII Austin Healey 4
T TR2/3/3A Rubber gear shift boot tearing Triumph 14
Tinkerman TR2/3/3A 1960 TR3A Boot rubber seal installation? Triumph 7
Popeye TR4/4A Trunk [boot] lock removal Triumph 12
