TR6 LED Headlights Thouights?
Jerry
There won't be representatives from Litezupp at our show. Just flyers.
I think in my cars, I used halogen lights, but I would try the new LEDs
tr6nitjulius
> LiteZupp Industries, LLC < After speaking with the vendor @Triumphest 2018 seeing a TR6 with them on purchased the complete kit for my '72 replaced halogen, difference white light vs yellow. Vast improvement on visibility behind the wheel amount of bright lit distance in front down the road as well as lighting up side shoulder. Less draw on electrical system. Easy plug & play change of bulbs no wiring required, worth the purchase. They sell separate bulbs as well
AggieTR6
Tr6nitjulius - based on your experience, I think I will order a set of headlights. Assume you have the R model 7" fluted lights. Have you seen their new S model with less curvature?
tr6nitjulius
Aggie TR6 I enjoy & do a lot of long distance night driving, the older I get the more light needed to see. No accidental leaving lights on there's a audible cooling fan incorporated in headlights, you'll like the easy/peasy plug & play, Love the difference in light to the road suggest a call to Litezupp & speak with Mike to match your needs, no haven't seen S model still happy with current which you can get replacement bulbs for, thinking perhaps curved source of more light on shoulder.
Pics 9 & 11 Litezupp led headlights on during the day: > '72"Buttascotch"TR6 <
When 1st installed 2018 in garage LED passenger side white, halogen driver's side yellow.
Site says: The uploaded file is too large for the server to process file to large to attach here want to see PM me email & I can attach pics
AggieTR6
Tr6nitjulius - have talked to Mike and will be ordering two sets - one for TR6 and the other for my Cobra. Did check out Butterscotch!!! Where did you get your chrome valve cover and do you like it? Does it leak?? My email is jmorgan@tamu.edu if you want to send other photos. Thanks for the info....
tr6nitjulius
AggieTR6 good nice gent & knows what he sells. Chrome valve cover was on it when I got the keys from original owner in 1979. All British Iron mark their spot not leak. No nothing leaks other than drop or 2 from tranny, diff after long drive, carbs occasionally let me know we got fluids. U R Welcome email/pics sent
tr6nitjulius
While I am sure it's been covered, a quick search didn't uncover what I was looking for. Simply, does anyone have LED headlights installed and, if so, your general impressions? I know all the benefits, just looking for some feedback. I think almost as important as the added light is the relief on my headlight switch on my TR6. Many thanks.
After speaking with the vendor @Triumphest 2018 seeing a TR6 with them on purchased > LiteZupp Industries, LLC < complete kit for my '72 replaced halogen, difference white light vs yellow. Vast improvement on visibility behind the wheel amount of bright lit distance in front down the road as well as lighting up side shoulder. Less draw on electrical system. Easy plug & play change of bulbs no wiring required, worth the purchase. They sell separate bulbs as well. We enjoy & do a lot of long distance night driving the last 6 yrs with led compared to the previous 39 yrs with halogen/oem bulbs drastic improvement, older I get more light to see, led vs oem double the bright light. LBC needs to See & Be Seen in a world of behemoths
PAUL161 T-Series MGT 7 inch LED Headlights MG 4
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
S LED or Quartz-Iodine headlights for my '67 AH 3000 Austin Healey 22
Scotsman TR2/3/3A LED headlights Triumph 4
AUSMHLY LED headlights Austin Healey 36
B Positive-Ground LED Light Strip Austin Healey 8
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
J LED lights for PL 700 Restoration & Tools 12
Guido36 LED Headlight Upgrade Austin Healey 1
bighealeysource LED Instrument Lights Austin Healey 12
linuxcoupe General MG Lamp to LED Conversion - How many ballasts to use MG 5
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
BoyRacer LED Turn Signals Austin Healey 5
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
P LED Brake Lights Austin Healey 2
EWD TR6 LED instrument conversion / Dimmer. Triumph 25
T Decreasing Intensity of LED Lighting Austin Healey 3
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
Michael Oritt LED bulb/resistor wiring question Austin Healey 24
johnrip Wedge TR7 led light conversion question Triumph 1
ckeithjordan TR2/3/3A LED Flasher Problem Triumph 13
AUSMHLY E10 Light bulb, 2.2w vs 5w vs warm white LED Austin Healey 4
Lukens TR2/3/3A Led flasher relay? Triumph 3
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
R TR2/3/3A Positive-ground LED lights Triumph 13
Bob_Spidell LED Headlamps Austin Healey 14
Gliderman8 TR6 Correct LED flasher relay Triumph 6
N Charging warning light LED conversion Austin Healey 29
J LED Brake / Turn Signal Austin Healey 4
Martinld123 Problem Using LED lights with Existing Brake Lamps Austin Healey 20
Joe Schlosser LED Turn signals Austin Healey 9
Joe Schlosser LED flashers Spridgets 2
Gliderman8 General TR Let there be [LED] light! Triumph 18
D LED shop lights Restoration & Tools 10
GTP1960 TR2/3/3A LED headlight question Triumph 11
gbtr6 TR6 LED light bulbs questions Triumph 20
Rob Glasgow E10 Base LED Dash Bulbs Austin Healey 17
Marla TR4/4A Led dash lights Triumph 0
jfarris TR2/3/3A Moss LED Tailight Kit Triumph 4
P LED Dash Lights Spridgets 1
K TR2/3/3A LED dash bulbs again? Triumph 2
gbtr6 TR6 LED Dash Lights Triumph 8
PAUL161 General MG LED Dash and Instrument Bulbs POS or NEG ground. MG 8
D TR2/3/3A TR3 LED Lights? Triumph 5
G BJ8 Phase II conversion to LED turn signals Austin Healey 11
S LED Exterior Light Upgrade Spridgets 15
