LED Headlamps
Directly under the picture of this product in Moss publication, in the description there is a statement that clearly says
THIS KIT WILL NOT FIT SEALED BEAM HEADLIGHTS !!
Hope this helps,
John
Hi All,
A number of years ago I fitted an alternator and installed (3) relays to handle the maximum power needed for the brightest headlights and driving light while offloading this power draw from my original wiring harness/switches and allowing them to be used only for relay control. This has greatly diminished the value of LED headlight. Add the expense of an LED conversion to the fact that I now drive quite a bit less at night and conversion is a non-consideration … for me.
However, the one place where an LED installation did make sense was when I illuminated the rear reflectors with brake and directional signals. Keep in mind that an incandescent is hot at the globe end but an LED disperses its heat at the socket end. Based upon this fact, having the plastic reflector lens close to the globe of an incandescent will melting the reflector plastic lens while an LED will not. Also, no bias resistors are necessary as they are tied to the original brake/directional bulbs/wiring of the original incandescent tail lights.
Sorry if extending this discussion further then the topic but I personally never understood why converting to LEDs is so popular. As I see it, my original incandescent bulbs have lasted decades so LED longevity provides little additional value to make up for the acquisition and installation costs. Additionally, incandescents reflect classic lighting consistent with the age of our cars where LEDs signal a modern reproduction (an almost Healey). So why the big demand for LEDs?
This is my perspective and although I will do almost all to make my Healey safe and operational secure and enjoyable to drive (i.e. Electronic ignition, sound system, etc.), I strive to maintain a traditional look with every modification both fully reversible and appearing to belong.
Ray(64BJ8P1)
IMO these headlights look out of place on a Healey. They're on the strange side. Where they really shine is on a 6 volt car, such as an old Porsche or VW.
Addendum: I was thinking of the "Crystal Clear Headlamps" on p. A21 of the latest catalog. Those are the weird-looking ones. Having said that, my neighbor has the LEDs on his 6V 1957 speedster and they made a real improvement in brightness.
I think:
If you had a led headlamp replacement for the Healey You would need a Loan to pay for it.
Interesting discussion. About two years ago was desperate to give the missus a suggestion for a birthday gift for myself and suggested she get me a set of the halogen headlights from Moss. Since she got me the headlights I've never installed them (she doesn't know this - yet). The reason was I still use the generator in my Healey and didn't want to stress it to power the higher wattage lights. Since the car is also positive ground LED's were not an option at the time. Now that Moss has supposedly polarity neutral LED's have been thinking about getting them as the wattage they require is so much less than the halogen's. Since I already have the light fixtures it would be a relatively simple install for me. Unless the lights are on you probably couldn't tell they are LED's.
Yes in your case you could just install led Lamp bulbs.
Perhaps that is a more economical way to do it.?
Hope this helps,
John
Guess I didn't phrase my inquiry well: directly to the right of the picture of this product in Moss publication, there is a drop-down option box labeled 'CHOOSE AN OPTION' with a 'WITH HEADLAMPS' option implying, to me, at least, that if one were to purchase said headlamps option they would work (the plugs look the same as the OEM ones, but I haven't pulled a headlamp in a while).
Well BOB :
Seems like for $250.00 you can convert a Healey with this kit using the- OPTION-WITH HEADLIGHTS- to led fixtures.
Some years ago I have mounted the LED (coold light)on my AH -they are very helpful in the night driving and easy to fit IF you have the H4 lamps on the car
Price of MOSS are too expensive- you can find on e bay at very lower price - I have acquired it at the first time when it appeared on the market
(don't remember BUT it probably arrived fro China) at USD 60 for a pair - but probably now the price are lowered
The better advantage are the lower Amper absorption ONE Amper /each (Halogen lamp 10 A/each)
IMPORTANT NOTE : before to buy you must ask if LED are positive or negative sensitive (as your car) probably they aren't sensitive as mine
https://photos.app.goo.gl/dSt2WBAzovMczhcNA
on the end of this Google album you can find a lot of photos
https://photos.app.goo.gl/BK81CyZMY9KmtLQo9
The thot plickens: https://www.ahspares.co.uk/austin-h...ng/LED-BULB-Upgrade-Kit-POSITIVE-EARTH-1.aspx
So, there's a rash of LED products coming on the market--this one looks comprehensive, and they have them for neg. ground and Sprites--so, presumably, there's a demand.
Disclaimer: I need another automotive project like I need another tax bill, and I don't drive my Healeys much, if at all, at night but the LED bulbs I put in my BJ8's brake lights are far superior to the old stuff (although people still seem to think my brake lights don't work because I engine brake as much as possible and don't dive bomb stoplights like most people do). But, since when does common sense prevail among people who can typically afford modern mobility pods but insist on driving ancient British hardware?
And the other reason they dont see the brake lights is either they are driving a jacked up truck that you need a ladder to get into or a huge SUV or maybe just maybe ........they are on the phone or playing with their GPS that they dont know how to program .:peaceful:
Now if they made LED (or xenon) conversions for Lucas 700 SLR driving lights, they would really brighten up the road ahead.
Hi All,
Boy, do I appreciate Healey Nut's perspective.
I live in a area that is reasonably congested with traffic seemingly dominated with large SUVs and commercial vehicles. Not far from NYC/NJ's industrial area and Jersey Shore, unless required, I stay away from major roads in the area when driving my Healey. Since, as Healey Nut's comments reflect, many drivers seem to miss the large rear signal lights of modern vehicles so what chance does the small low set tail/signal lights of our Healeys have of being noticed.
Although I have installed LEDs behind my reflectors to help illuminate my actions or intentions by mirroring the Directional and Brake signals of my small lower tail lights, I am still left with uncertainty as to whether the driver behind will notice. Although I had no interest in the installation of a 3rd directional/brake light, I am at the point of considering an installation of and will be looking for something that either can be installed as if it belonged as an original part and/or installed as part of my Amco boot lid luggage rack.
Yes, I do not need another project but I have begun to believe this is a matter of survival and no longer an optional issue.
All the best to all,
Ray(64BJ8P1)
Ray,
When I was following you from behind to that car show down the shore months ago, even though your right signal was working for sure, it really didn't stand out that well, as I remembered. Compared to newer cars of today, yes, their signals are larger and brighter, but people still don't see the way they are suppose to, as Healey Nut noted.
Even though I drive a PH II having the factory brake light setup, I drive carefully and humble. All I can do is stay clear away of tailgaters and I will pull over to let them pass. Bothers me to have to do that but I do it. I live in a more congestive neighborhood than you (1 mile from Manhattan). You can't imagine how many flatbeds I see everyday with redesigned front/rear ended cars on them.
PAUL161 T-Series MGT 7 inch LED Headlights MG 4
B Positive-Ground LED Light Strip Austin Healey 8
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
J LED lights for PL 700 Restoration & Tools 12
Guido36 LED Headlight Upgrade Austin Healey 1
bighealeysource LED Instrument Lights Austin Healey 12
linuxcoupe General MG Lamp to LED Conversion - How many ballasts to use MG 5
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
BoyRacer LED Turn Signals Austin Healey 5
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
P LED Brake Lights Austin Healey 2
EWD TR6 LED instrument conversion / Dimmer. Triumph 25
B TR6 LED Headlights Thouights? Triumph 28
T Decreasing Intensity of LED Lighting Austin Healey 3
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
Michael Oritt LED bulb/resistor wiring question Austin Healey 24
johnrip Wedge TR7 led light conversion question Triumph 1
ckeithjordan TR2/3/3A LED Flasher Problem Triumph 13
AUSMHLY E10 Light bulb, 2.2w vs 5w vs warm white LED Austin Healey 4
Lukens TR2/3/3A Led flasher relay? Triumph 3
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
R TR2/3/3A Positive-ground LED lights Triumph 13
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
Gliderman8 TR6 Correct LED flasher relay Triumph 6
N Charging warning light LED conversion Austin Healey 29
S LED or Quartz-Iodine headlights for my '67 AH 3000 Austin Healey 22
J LED Brake / Turn Signal Austin Healey 4
Martinld123 Problem Using LED lights with Existing Brake Lamps Austin Healey 20
Joe Schlosser LED Turn signals Austin Healey 9
Joe Schlosser LED flashers Spridgets 2
Gliderman8 General TR Let there be [LED] light! Triumph 18
D LED shop lights Restoration & Tools 10
GTP1960 TR2/3/3A LED headlight question Triumph 11
gbtr6 TR6 LED light bulbs questions Triumph 20
Rob Glasgow E10 Base LED Dash Bulbs Austin Healey 17
Marla TR4/4A Led dash lights Triumph 0
jfarris TR2/3/3A Moss LED Tailight Kit Triumph 4
P LED Dash Lights Spridgets 1
K TR2/3/3A LED dash bulbs again? Triumph 2
gbtr6 TR6 LED Dash Lights Triumph 8
PAUL161 General MG LED Dash and Instrument Bulbs POS or NEG ground. MG 8
D TR2/3/3A TR3 LED Lights? Triumph 5
G BJ8 Phase II conversion to LED turn signals Austin Healey 11
S LED Exterior Light Upgrade Spridgets 15
Scotsman TR2/3/3A LED headlights Triumph 4
andrea Dual Beam LED Head Light Cree Austin Healey 4
