I may as well tag on here with my own little problem: OK?
My motor (DR2) has two spade terminals, and it does not seem to matter which way I hook up the two wires. But it does not self park, and grounding it seems to make no difference . ( It does not have a ground terminal, and I tried various spots to ground it including the terminal on top of the"disc" which has the red wire attached.)
The car is a mongrel. TR2 dash, TR3A number, 60014, with body to match and TR4 transmission with overdrive. Probably a TR4 temperature sensor too. Harness from Roadster 20 years ago was for the body number so I had to cut off quite a few terminals. Changing polarity seems to have gone fine: ammeter now reads correctly. But I am bemused by the failure to park especially in our sometimes wet climate.
I think the wiper switch has no slow/fast function, just off/on. It was a used item.
( The heater motor was OK on the bench but now seems to have a short so I shall not be using it until I have fixed the rest of the car. It will not be any harder to get out then than now!)
Any suggestions?
