TR2/3/3A Wiper motor testing?
karls59tr
Bronze
1)Can I put 12 volts directly from the battery to the green wire terminal on the wiper motor to see if it's working?
2)I seem to have power to both terminals on the wiper switch when the switch is pushed in(off position)....what's up with that?
1) Yes, but make sure you are on the right terminal. Otherwise, you'll have a short to ground when the park switch closes.
Don't forget, you'll need to ground the other terminal to make it run.
2) I'd say that means you didn't hook up the ground wire.
1)Double checking...the green wire goes to the uppermost connector on the motor...the green black goes to the lower one...the black ground wire goes to the screw near the top of the motor casing...the eyelet ground wire goes to the motor pedastal bolt?
2) I believe I have the later wiper motor...dosn't the switch have green wire to one terminal and black green to the other? There is a thin black ground wire behind the control panel that is not connected ,I thought that wire was there in case you needed it to attach to the switch if you had the earlier motor? If not that... then where does that ground wire attach to?
Sounds right to me...
Brown wire on top right= park limit switch.
M.
Switch gets the green/black wire and a black ground wire that comes out of the harness.
Yes, that reddish brown wire is for the park function and is part of the motor so it doesn't not appear on wiring diagrams. As I recall - omit it and the motor won't run, let it short to ground (like a insulation break where it enters the housing) and the motor won't shut off.
All this is as found on TS47905L. As you may know there was a very different set-up earlier. I think yours will be like mine but you may encounter wiring diagrams for the early set-up than can confuse things.
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
P Bench Testing a wiper motor???? Spridgets 3
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
D TR2/3/3A wiper motor parking? Triumph 17
R TR2/3/3A TR3 Wiper motor Triumph 10
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
T TR2/3/3A wiper motor short Triumph 2
B TR4/4A Rubber wiper motor mounts Triumph 4
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
W TR2/3/3A TR2 wiper motor mount Triumph 1
RAC68 Wiper Motor and Arm Adjustment Austin Healey 8
R GT6 Wiper Motor problem and time capsule Triumph 4
N TR2/3/3A Wiper motor armature Triumph 11
Jim_Stevens TR2/3/3A Wiper motor hookup Triumph 4
M Wiper Motor Problem Not Working Spridgets 5
J TR2/3/3A Wiper Motor bracket Triumph 5
T TR5/TR250 TR250 wiper switch and motor Triumph 1
Bayless Question on 1 speed wiper motor Spridgets 2
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
tinman58 TR5/TR250 TR 6 wiper motor Triumph 10
H Post-War Other Wiper Motor [Early type DR2] Issue Triumph 7
pa297pass TR4/4A TR4 wiper motor rubber mount installation. Triumph 7
sparkydave Wiper motor '77 Spridgets 2
J TR2/3/3A Wiper motor wiring Triumph 4
D TR5/TR250 Windshield wiper motor Triumph 9
J TR2/3/3A Wiper Motor Gear Triumph 11
S TR2/3/3A Wiper Motor Troubleshooting Triumph 6
R grease for windshield wiper motor- BJ7 Austin Healey 4
steveg Wiper motor install error - warning Austin Healey 9
P WANTED: Bugeye Wiper Motor Spridgets 0
S TR2/3/3A Wiper Motor Parking Question Triumph 8
P Bugeye Windshield Wiper Motor Spridgets 3
Jim_Stevens TR2/3/3A Wiper motor mount Triumph 4
maxwedge5281 TR6 tr6 wiper motor wiring Triumph 15
maxwedge5281 wiper motor upgrade to two speed Austin Healey 16
Scotsman TR4/4A TR4A wiper motor rebuild Triumph 8
Scotsman TR4/4A TR4A wiper motor questions Triumph 2
T TR4/4A Removing wiper motor - inner cable Triumph 4
rjc157 wiper motor Austin Healey 0
Rob Glasgow Wiper motor rubber mounts Austin Healey 5
J Wiper motor 100 degree sweep gear ??? Restoration & Tools 7
T TR2/3/3A Windshield Wiper Motor Grease Triumph 4
rjc157 wiper motor Austin Healey 6
D Wiper motor mounting Spridgets 0
T TR2/3/3A wiper motor parking Triumph 7
alanjohnturner TR4/4A Rebuildiing a wiper motor Triumph 8
