TR2/3/3A wiper motor parking
TFB
Got my wipers installed todaqy but wipers park in random spots.I have 12v to motor and 12v from switch.Motor runs regardless of switch if I switch leads.I know I should be able to adjust park position by rotating dome on motor top but think they should still stop in the same place even if out of adjustment.Any thought s appreciated before I attempt to adjust or open up the motor.
Thanks
tom
You might mention what year (or commission number) you have as TR2/3/3A wiper wiring changed significantly at one point in the run.
It is a common problem as one widely circulated wiring diagram is incorrect for many (if not most) cars.
Since you say "I have 12v to motor and 12v from switch" it sounds like you have the early version of the wiring scheme.
SorryGeo ,I misspoke.Its a DR2 1959 with 12v, constant earth,and earth thru the switch.3 terminals.I forgot the switch is another ground circuit.
Thanks Shawn,I will watch the video.
Tom
In that case, it's like mine.
You might closely examine that red wire that goes from the wheel box to the motor. As I recall (and it has been awhile):
... If that wire has a break in it the wipers will not park - they will just stop wherever they are when you switch the wipers off.
... If that wire shorts out (most likely to happen where insulation abrades against the motor case where it goes in) the wipers will not stop when switched off.
As I said -- it has been awhile -- but I definitely recall that failure of that red wire can cause some strange motor behavior.
There are two kinds of cap in use on DR2's
https://flickr.com/gp/90670218@N04/0205z7
https://flickr.com/gp/90670218@N04/34jB1c
One uses a reliable springy finger like a DR3A, the other a rather tricky bent contact thing that is prone to poor contact and is hard to adjust.
Take the plate off and clean with Scotch-brite and set the contact so they touch nice.
All these motors need a permanent 12V supply on the correct contact, usually maked 2 and the on/off is done by making the ground side, usually marked 1.
Mess with this and the self-park contact will short the battery and overheat.
Here I am spiffing up some DR2s
https://flickr.com/gp/90670218@N04/pC19gj
Thanks again Geo,and Alan or the pics.I have the cap on the left in first pic.I did resolder the connection on top so some troubleshooting to follow.
Thanks again
Tom
You got the common, easy, type of cap.
But these have an "interesting" failure mode. You see how the brass-disc and outer contact are held with two rivets. Insulation is sandwiched in so they dont touch the main cap.
Well the rivets can stop making a good "through" contact. They tend to touch when you check them with a test-meter and then go off-duty when you are not looking.
A tap with a hammer or maybe a dab of solder.
I drill these out and re-rivet them when I re-build these. Here is a set of photos of a DR3A rebuild showing me doing this.
https://www.flickr.com/photos/90670218@N04/sets/72157641071372515/
I also always replace the wire. This can fail internally but still look OK outside. The original is rubber coated but PVC will do.
When this stops in the "wrong" place short the contact on the top of the cap to the body. If it moves the fault is inside the cap or the body of the motor does not have a good contact to the car body.
Al.
D TR2/3/3A wiper motor parking? Triumph 17
S TR2/3/3A Wiper Motor Parking Question Triumph 8
wingsandwheels TR6 TR6 wiper motor parking Triumph 1
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
R TR2/3/3A TR3 Wiper motor Triumph 10
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
T TR2/3/3A wiper motor short Triumph 2
B TR4/4A Rubber wiper motor mounts Triumph 4
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
W TR2/3/3A TR2 wiper motor mount Triumph 1
RAC68 Wiper Motor and Arm Adjustment Austin Healey 8
R GT6 Wiper Motor problem and time capsule Triumph 4
N TR2/3/3A Wiper motor armature Triumph 11
Jim_Stevens TR2/3/3A Wiper motor hookup Triumph 4
M Wiper Motor Problem Not Working Spridgets 5
J TR2/3/3A Wiper Motor bracket Triumph 5
T TR5/TR250 TR250 wiper switch and motor Triumph 1
Bayless Question on 1 speed wiper motor Spridgets 2
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
tinman58 TR5/TR250 TR 6 wiper motor Triumph 10
H Post-War Other Wiper Motor [Early type DR2] Issue Triumph 7
pa297pass TR4/4A TR4 wiper motor rubber mount installation. Triumph 7
sparkydave Wiper motor '77 Spridgets 2
J TR2/3/3A Wiper motor wiring Triumph 4
D TR5/TR250 Windshield wiper motor Triumph 9
J TR2/3/3A Wiper Motor Gear Triumph 11
S TR2/3/3A Wiper Motor Troubleshooting Triumph 6
R grease for windshield wiper motor- BJ7 Austin Healey 4
steveg Wiper motor install error - warning Austin Healey 9
P WANTED: Bugeye Wiper Motor Spridgets 0
P Bugeye Windshield Wiper Motor Spridgets 3
Jim_Stevens TR2/3/3A Wiper motor mount Triumph 4
maxwedge5281 TR6 tr6 wiper motor wiring Triumph 15
maxwedge5281 wiper motor upgrade to two speed Austin Healey 16
Scotsman TR4/4A TR4A wiper motor rebuild Triumph 8
Scotsman TR4/4A TR4A wiper motor questions Triumph 2
K TR2/3/3A Wiper motor testing? Triumph 7
T TR4/4A Removing wiper motor - inner cable Triumph 4
rjc157 wiper motor Austin Healey 0
Rob Glasgow Wiper motor rubber mounts Austin Healey 5
J Wiper motor 100 degree sweep gear ??? Restoration & Tools 7
T TR2/3/3A Windshield Wiper Motor Grease Triumph 4
rjc157 wiper motor Austin Healey 6
D Wiper motor mounting Spridgets 0
alanjohnturner TR4/4A Rebuildiing a wiper motor Triumph 8
