Wing/fender chrome side flashes
Jeepster
I am expecting a short answer to this one -
BJ8 is still in the bodyshop but due back in a couple of weeks.
Can the wing/fender chrome flashes be fitted whilst the wing is fitted to the car? Or do the bolts have to be undone and the wing removed?
AH100M
Yes they can but you need a thin, flexible arm to do it. It would be easier to do with the wings off the car but they would then impede final buffing of the paint, if that's relevant.
Jeepster
Jeepster
Bill,
thanks for the reply.
That's the issue - they have been left off to ease with buffing of the paint. Think I need to visit the bodyshop to see if i can access the rear of the wing, or make them aware that the wing has to be removed again.
AH100M
Make sure you have the fresh air ducting installed before the wings go on. I don't have a BJ8 but hear it's real bear to do it with the wings installed.
Healey Nut
Leave them off, then visit your local body supplies place and buy some of the trim stick foam adhesive stuff . Apply it to the flashes you may need two layers due to the inset on the back of the flashes , leave the studs on for location . Stick em on ,,,,done
Shhhhhhhh I wont tell if you don't ....
RAC68
Although I have installed the fender spears without removing the fenders, I do not recommend as flexing of the fender could risk cracking or chipping your new paint.
The only way I have found to install the spears with the fender on the car is by reaching up from the bottom of the fender. I did this by first applying painters tape to the fender and door edges, jacking up the front of the car sufficiently to partially slide under and by removing the bottom fender bolts and lower jam screws. I then inserted the spears and applied additional painters tape to hold it in place. By moving the fender bottom out sufficiently to insert my arm at the wheel well end, I reached up and applied the anchor nuts to the spears and tighten with a small ratchet wrench.
If you do decide to remove the fender, consider installing a bilge blower into the cold air duct to power your cold air flow.
Good luck,
Ray (6 4BJ8P1)
maxwedge5281
not to hi-jack the thread...but, my flashes are on backwards. is it necessary to drill different hole locations to install in the wrong direction? i would just like to know before i go to all the trouble to remove them and reinstall and find out that i have extra mounting holes in the fender. and, especially if i have a hole exposed on the more narrow end... thanks
HealeyRick
Shouldn't be a problem. The reason so many of them are put on backwards is they go on either way using the original holes.
maxwedge5281
i was hoping that was the case. now if i can get the behind the fenders nuts! thanks rick!
Keoke
I installed mine after the wing was attached. It can be done.
ME TOO !!
Plus,Folks been doin it for years ain"t no big deal.
Certainly not worth pulling the wing to do
Healey Nut
I still prefer my method , quicker , easier and saves me loosing skin of my arms and fingers etc .
maxwedge5281
removed the flashes and installed proper direction. thanks for the help.
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
H TR4/4A Fender/Wing repair how to do Triumph 5
D Wing Fender Fitment Question Austin Healey 6
N Fender [wing!]??? Spridgets 7
B MGB 1971 MGB Wing or Fender removal. MG 2
martx-5 TR2/3/3A TR3 Fender [Wing] Beading Triumph 9
Lin Christmas Wing [Fender] Austin Healey 2
Lin Mounting the RH front fender [wing] Austin Healey 0
N Fender[wing]sealant questions Triumph 17
Lin Rear Wing [fender] fasteners Austin Healey 1
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
K TR2/3/3A Wing mirror replacement again... Triumph 0
B Wanted Lucas wing mirror Other British Classifieds 1
S Rear Wing Fit Austin Healey 4
B Wanted wing windows gt6 Austin Healey Classifieds 0
71TR6 TR2/3/3A TR3A Wing to Apron Mismatch Triumph 9
JFS Wedge Door wing window finisher Triumph 2
M Wanted Bj8 left front wing Austin Healey Classifieds 3
D TR2/3/3A Wing nuts for gauge panel on TR 3 Triumph 10
UltimateQuestion GT6 GT6 Mk3 rear wing removal Triumph 3
S Bakerlite Wing Mirrors Other British Cars 2
F TR2/3/3A Front inner wing baffle measurement Triumph 7
JimLaney Drain holes relieve wing water retention? Spridgets 3
Griz Wing Mirror Location Austin Healey 31
Rut TR4/4A Wing installation Triumph 9
CJD TR2/3/3A TR2 Wing Beading Triumph 24
Rut TR4/4A wing patch panels Triumph 5
S Aluminum wing vents for BT7 3000 Austin Healey 1
Tinkerman TR2/3/3A TR3 A REAR WING BOLTS order of assembly? Triumph 3
Tinkerman TR2/3/3A 1960 TR 3A Rear Wing Attachment Triumph 13
A Aligning New half front wing, outer sil and rear wing Austin Healey 5
GTP1960 TR2/3/3A New left front wing body panel from TRF? Triumph 11
F J hooks an wing nuts for attaching hard top to body BT-7 - anyone got photos? Austin Healey 5
K TR2/3/3A The "brass wing nuts" rhat hold the instrument panel on...... Triumph 2
Tinkerman TR2/3/3A Rear Wing installation fun................... Triumph 3
DerekJ Removal of front wing Austin Healey 15
Rut TR4/4A Amco wind wing repair Triumph 7
Tinkerman TR2/3/3A Front wing question Triumph 3
Tinkerman TR2/3/3A Rear wing fixing clamp Stan Part # 602167 Triumph 5
P BJ8 wing and panel fixing help? Austin Healey 3
Jeepster Front wing flash fixing holes Austin Healey 5
AH100M Why weren't sill and wing flanges painted black on BN1s and BN2s? Austin Healey 12
PatGalvin Front Wing Sealer Plates Triumph 5
healeyblue Side screen wing nut Austin Healey 7
B rear wing mounting on my 57 Triumph 5
M Home on a wing and a prayer Triumph 16
H wing mirrors Austin Healey 11
B TR2/3/3A Fitting the front wing 57 TR3 Triumph 2
Jeepster wing beading Austin Healey 7
