Volvo OD Unit
MikeH
Hi all, Ebay occasionly has J type overdrive units for Volvo's listed. I know that the gearbox mainshaft has to be changed, and an adaptor plate and electrics added to convert a standard four speed. Has anyone done this? Thanks, Mike
63 TR4 Surrey Top ( Back from paint shop /ubbthreads/images/graemlins/laugh.gif )
71 MGB OD & Wires
I used a J-Type from a 1974 142E on a late TR6 gearbox. If you can find the super-rare 164 O/D unit , it already has the correct output flange for a TR3-6. The 142 flange is for the small u-joint. You will also need the correct TR6 speedo gears and housing. The boss's were there for the rear mount but undrilled. I'm sure there is something else I left out.
Alan T
Hi Mike,
I gotta ask... Why would you want a J-type? Is it for your TR4?
Heck, I'd put in an A-type! No contest. First of all, it shifts faster and is a more durable unit. Plus, TR4 came with A-type, so installing one would greatly enhance the value of your car, while a J-type might give little increase in value, or could even reduce it in the eyes of a potential buyer, if that ever becomes important.
A-type are 22% reduction ratio, but can be rebuilt to 25 or even 28% ratio, if you wish. Most J-type are 25%, but might also be a different ratio, depending upon the car it's out of, or if it's ever been modified.
I must disagree with Alan on this one. I'm running this J-Type Behind a close ratio gearbox behind a full-tilt TR4 Racing engine. It is so much smoother in and out compared to the A-Type. I ran A-Type O/D's for about fifteen years (with no real problems) but do not plan to go back unless forced to.
Alan T
Thanks for the replies. I have an MGB with an L type OD, and its great for freeway driving. Would like to have same option in the TR4. Looking at the J type option because it would be a less expensive way to get overdrive. I already have a spare four speed gearbox I can use. I just don't have the $2400 that someplace like Quantum wants for a rebuilt A. Thanks, Mike
63 TR4 Surrey Top
71 MGB OD & Wires
Hi again Mike,
In fairness, I have to say that when it's intended primarily for highway cruising use with a moderately tuned engine the J-type will probably do fine. Some points in its favor are that in stock form it will typically have a little more reduction (25% compared to 22%), most likely you will only be using it on top gear (where it's least stressed and OD durability is less of a concern) and you won't object to a slight delay as it engages.
That's a bit different than using the OD as a sort of "7-speed" gearbox. I.e. using the OD on 2nd and 3rd, as well as top gear to get just the right rpms in fast corners. For a more "sporting" purpose like this, an A-type might be preferred.
So, if you can get a J-type cheap, it might work out really well. Just so you know, a key reason J-type takes longer to engage than an A-type is that the A-type runs at high pressure all the time, while the J-type doesn't build up to engagement pressure until the switch is turned on. The A-type uses a higher overall pressure, too. Because of this, the A-type is a little more inclined to leak oil than the J-type.
Some other things to consider. Yes, the gearbox will still need to be modified with a shorter main shaft. It should also at a very minumum be thoroughly cleaned inside. Any used OD should at least be cleaned carefully, too. This is because the two share oil and one that's in rough shape can contaminate and damage the other. You are also correct that an adapter plate is also needed, between the gearbox and the OD. I'm not sure if the one for the J-type is different from the A-type adapter plate, but would guess it is. The electrical harness, switch and relay are all pretty easy to find or make up, so really aren't an issue.
Now, Volvo has shared a lot of parts with Triumph over the years. So, by all means there is good likelihood a Volvo OD, specifically, can be made to work. Often the major difference between Laycock OD units is the tail piece, providing different mounting methods for different cars and, often, differing speedo drive fittings and gear ratios. Even so, a fabricated adapter plate might work if the rear mounting is different, instead of trying to track down a tailpiece for the OD. And, often an angle drive can be used on the speedo fitting to resolve clearance issues, but doesn't correct for any gearing differences that would make your speedometer inaccurate. However, the speedo drive in the OD might be changeable, or the speedometer itself might be re-calibrated instead.
All are certainly issues that can be resolved. It would be great, though, to work with someone who probably has some expertise on making this sort of swap, like John Esposito at Quantum Mechanics.
Hi
This caught my eye, as I want the same mod.
Is it ok to mention that there is an article describing the required changes for this mod on the Quantum Mechanics website? Pretty much what's been described but good reading all the same.
My .02 worth,
I've made this conversion adding a volvo j-type OD to a stock TR6 transmission. It is not a difficult project and in the end you will have a completely rebuilt tranny complete with OD unit. All the necessary hardware is readily available as are write-ups on rebuilding your transmission while its out of the car and converting the OD unit. Below is a list of parts you will need:
-new mainshaft (quantum mech)
-adapter plate (quantum mech)
-eccentric cam/key (quantum mech)
-new rear output flange (quantum mech)
-wiring harnesses (multiple providers)
-speedo pinion gear (multiple providers)
-OD isolator switch (multiple providers)
-tranny rebuild kit (multiple providers)
69MGC MGB Volvo engine in a B MG 1
Brooklands Volvo Museum - Gothenburg, Sweden Other Cars 1
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
Basil Volvo and BCF member! Spotted 17
K TR2/3/3A Volvo low profile space saver spare tire for TR3 ? Triumph 1
TomMull Volvo Low Rider spotted in Vassalboro Me Other Cars 1
AngliaGT 1970 Volvo 142 Other Cars 8
HealeyRick Hot Volvo Other Cars 0
Basil Volvo 1800 Spotted 7
AngliaGT Thoughts on Volvo wagon? Other Cars 5
trotti Calling all SU experts - Volvo HS6 Carbs Austin Healey 11
HealeyRick Volvo-Healey? Austin Healey 0
Got_All_4 Wedge TR7 Volvo front brake converson Triumph 4
JPSmit Volvo 1800 Spotted 0
RickB OT - looking at new grocery getter: Volvo V70 Spridgets 21
aeronca65t Sashimi Tabernacle Volvo Spotted 4
aeronca65t Volvo P1800 Spotted 0
mailbox Volvo 940 turbo known problems Other Cars 8
W If you have a Volvo 240 wagon... Spridgets 12
T OT - looks like the Volvo is out, because.... Triumph 26
Bruce Bowker Volvo to China Other Cars 12
swift6 Volvo 240 Wagon transmission question... Other Cars 10
Sarastro This doesn't happen in a Volvo Spridgets 48
Steve P. T-Series Which Volvo engine fits in an MGTD? MG 40
H TR6 Volvo HS6 Carbs on a TR6 Triumph 9
PATR8 Opinions on a 1997 Volvo 960? Other Cars 2
PATR8 almost bought a Volvo today, need diagnosis help Other Cars 8
PATR8 Need advice on a new project [Volvo 240] Other Cars 19
davelgee Old Volvo [PV444] Other Cars 4
AngliaGT 2 - [TWO] Volvo 122 Wagons - FREE! Other Cars 0
amcboy Post-War Other Difficulty in converting Volvo 1800 J-type O/D? Triumph 6
Banjo 'member that Volvo???? Other Cars 10
tony barnhill 2000 Volvo S40 Other Cars 5
AngliaGT Looked at a Volvo Today.... Other Cars 6
Banjo Info on a Volvo.... motor Other Cars 21
aeronca65t Old Volvo Wagon Tours USA Other Cars 4
Sherlock Volvo begets Camry... [car shopping] Other Cars 9
Sherlock Volvo DL Wagon Latest Other Cars 1
Sherlock 1985 Volvo DL station wagon Other Cars 39
G TR6 volvo OD on TR6 Triumph 13
Jake MGB-GT Adjustable rocker arms, Volvo --> Rover V8 MG 4
Howard_The_Duck Volvo 122s - Anyone have thoughts on it? Other Cars 21
SilentUnicorn Volvo ! Other Cars 30
Basil Volvo S60 Other Cars 3
Jerseygirl My Volvo 1800ES "project" Other Cars 33
wkilleffer Question about the turbo on a Volvo 740 turbo Other Cars 3
wkilleffer Volvo Amazon/120 Other Cars 7
C volvo 5-cylinder Other Cars 8
aeronca65t Volvo P1800 Racer Other Cars 4
KLUTZ Volvo... 5 cylinder... what's with that? Other Cars 18
