MGB-GT Adjustable rocker arms, Volvo --> Rover V8
Jake
Probably not the best forum to post this to because its Rover V8 related but here goes anyways. Its intended for those of the MGB V8 w/ BOPR persuasion.
Anyone fit Volvo adjustable rocker arms instead of the stock Rover ones? They are reported to be quasi-interchangable according to the Hardcastle book and were used on Group A engines. I got a line on a pair of rocker trains with the right arms but the seller told me they are (he measured) 1.4 ratio and the Rover is 1.6. Any veracity to this? Anyone do this? Any ideas?
The volvo rockers are usable but will require a bushing to fit the rover rocker shaft. They are also a 1.5 ratio which would mean a drop in valve lift if used with the stock camshaft but would be fine if used with a 1.5 ratio cam UNLESS I was able to bush them with an offset shaft bore and get that .1 back in the ratio. Who knows, I will probably get one rocker and try it out first as an experiment.
Believe me when I tell you this. THEY ARE NOT WORTH THE EFFORT/EXSPENCE. If you want adjustable rockers, call Woody at the wedge shop. https://www.thewedgeshop.com He sells a set of adjustable roller rockers that are worth the money. In fact, they are probably cheaper than trying to make the Volvo ones work. They alone can gain you somewhere in the vicinity of 20 HP on a big motor. Another cheaper option is adjustable pushrods. I have a set of the pushrods on one of my motors and they work well. You won't need to go adjustable unless you go to a cam with more than 470 lift. I think Woody is running a solid lifter cam with about 550 lift in his car with the roller rockers.
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
kodpkd Adjustable Tie Rods Austin Healey 20
Got_All_4 TR6 Non Adjustable Stromberg Pistons Triumph 8
T Kilmartin Adjustable Front Shock Mount Plates - Installation Instructions Austin Healey 0
BoyRacer Did BN2s have adjustable steering wheels? Austin Healey 5
J TR2/3/3A TR3A Adjustable Steering Triumph 5
J Wanted Adjustable steering wheel circlip Triumph Classifieds 4
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
steveg SOLD!! Moto-Lita 14" wheel for sale with adjustable hub & collet Austin Healey Classifieds 0
J TR2/3/3A Adjustable vs non Adjustable wheel Triumph 0
Walter74 Adjustable steering wheel removal Austin Healey 4
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
R TR2/3/3A Frozen Steering Wheel [Adjustable] Triumph 7
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
John_Koop TR2/3/3A Adjustable steering wheels Triumph 3
AUSMHLY Adjustable steering wheel removal Austin Healey 5
C Non-Adjustable steering column questions Austin Healey 14
G TR2/3/3A Fitting the Control Head - Telescoping [Adjustable] Wheel Triumph 20
B Wanted Need '58 TR3 adjustable steering set up Triumph Classifieds 4
60BN7 Adjustable Steering Column Won't Lock Austin Healey 9
D BT7 adjustable steering column / steering wheel Austin Healey 1
maxwedge5281 Trafficators, Adjustable vs. Non-Adjustable Austin Healey 14
4tecdog Adjustable Steering how? Austin Healey 8
maxwedge5281 adjustable trunnion Austin Healey 15
CJD TR2/3/3A Adjustable vs Non-adjustable Control Heads Triumph 4
brgrmyster GT6 Sourcing the adjustable control rod 69-70 GT6+ Triumph 1
J Armstrong adjustable lever shocks Spridgets 11
Lin Loosening adjustable steering wheel Austin Healey 3
maxwedge5281 bj7 adjustable steering column Austin Healey 14
Lbp TR2/3/3A Looking for info on adjustable steering wheel - Does a Healy wheel fit? Triumph 9
glemon General TR Adjustable Trailing Arm Brackets, Cheap and Lazy, or clever like a fox? Triumph 0
Lbp TR2/3/3A TR3A - Converting Adjustable Steering Wheel to Standard? Triumph 16
DanLewis Electronically Adjustable Timing and Dwell Spridgets 7
B Rocking movement in adjustable steering wheel Austin Healey 6
Crankshaft Adjustable steering column? Triumph 11
Lbp Looking for Adjustable Steering WHeel Triumph 5
S WTB: Non-Adjustable Horn Button for a 3000 Austin Healey 6
F Replacing the horn push adjustable steering wheel Austin Healey 7
H horn button for BN6 "non-adjustable" Austin Healey 4
B TR2/3/3A Adjustable Upper Fulcrum for TR3 Triumph 9
pkmh Removing BJ8 'Adjustable' Steering Wheel Hub Austin Healey 18
M TR6 GoodParts Adjustable Trailing Arm Brackets TR6 Triumph 14
I another adjustable steering column question Austin Healey 8
M Adjustable Steering column Austin Healey 9
bugedd Adjustable trailing arms? Spridgets 3
6 Adjustable lever shocks Spridgets 5
W Longbridge 100-6 and adjustable steering wheel Austin Healey 7
HealeyCopter Adjustable Steering Wheel Nut Stuck Austin Healey 10
richberman Adjustable shock mounts or fixed? Austin Healey 16
