TR6 vacuum system TR6
Rob DeScherer
When I got my '74 TR6, the vacuum system running fromt he EGR valve to the carbs and distributor was missing. I have done nothing to replace it. Does anyone know if it is okay to run the car without it? Could this be the reason why I am having a very difficult time adjusting the carbs?
aeronca65t
Removing EGR control system (and thus disabling the EGR) will definitely make car run rich at mid-range and above....shouldn't have any effect on mixture at idle. EGR kicks in at mid-range (~2000 RPM+)and is a like a "controlled vacuum leak"....and engine is tuned to work with it. There may be alternate Euro needles for the carbs that will lean out mid-range or you could try dropping the needles (in the carb pistons) a bit. Be sure carb diagphrams are good....car will run terrible if they're ripped or cracked(I'm assuming it has Zenith carbs).
R
Rob DeScherer
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by aeronca65t:
Removing EGR control system (and thus disabling the EGR) will definitely make car run rich at mid-range and above....shouldn't have any effect on mixture at idle. EGR kicks in at mid-range (~2000 RPM+)and is a like a "controlled vacuum leak"....and engine is tuned to work with it. There may be alternate Euro needles for the carbs that will lean out mid-range or you could try dropping the needles (in the carb pistons) a bit. Be sure carb diagphrams are good....car will run terrible if they're ripped or cracked(I'm assuming it has Zenith carbs).<hr></blockquote>
I do have Z/S carbs, but they are actually running extremely lean, so much so that the car will not hold an idle at all, but will stall immediately if the choke is off. We have tried resetting the low idle, but have found it to be impossible because we can't keep the car running. We ahve not found any vacuum leaks. Any ideas about what we can try next, or should i just pull the carbs off and rebuild them?
[ 05-11-2002: Message edited by: Rob DeScherer ]</p>
aeronca65t
If your EGR valve is stuck open all the time, the car will run very lean, especially at idle. Using the choke will mask this to some degree. Remove the EGR valve and clean it in kerosene (or similar) and make sure the valve is opening and closing fully (it is noramlly "closed" due to spring pressure). Sometimes these valves get burned and will not seal completely (and you'd need to replace the unit)....but usually, they just get gummed up with carbon. In a pinch, you could remove the EGR valve and plug the manifold port that it attaches to.
Another thought: If one of the floats is stuck, the car could be running off one carb (because the float chamber would be empty in the "stuck" carb)....and the car would run lean. Try tapping on the float chamber with a small wrench to see if you can "un-stick" the offending float.
Another idea: to find vacuum leaks, start the engine and get it "idling" as best as you can. Spray WD-40 around the manifold gasket, the carb gasket, etc. If there's a leak, the engine will slow down as it sucks in the WD-40 (the WD-40 won't hurt anything....but it doesn't really burn like gas, so the engine slows down)
aeronca65t
AUSMHLY Vacuum system and what does it do? Austin Healey 4
deadair TR2/3/3A TR3A -- Vacuum Bleeding Girling Brake System Triumph 13
Sopwith_Camel MGA booster Vacuum MG 8
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
S TR2/3/3A Vacuum Advance Union Size Triumph 1
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
drooartz MGB Question on timing and vacuum MG 11
B Vacuum at Idle Austin Healey 9
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
B Vacuum Source Austin Healey 4
WHT Vacuum Advance Pipe Austin Healey 7
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
JPSmit Today's question - vacuum advance Spridgets 2
Gliderman8 TR6 Vacuum Gauge Hookup Triumph 11
B Vacuum Advance Pipe Austin Healey 2
Twit TR4/4A TR4 AUC878 vacuum connections Triumph 7
J TR6 Vacuum Retard question Triumph 1
R TR6 Thermostatic vacuum switch Triumph 3
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
S TR6 TR6 Vacuum Issue... some help please... Triumph 8
M Vacuum Line on a 948 Spridgets 4
S TR2/3/3A Vacuum leak Triumph 19
B Vacuum Servo Austin Healey 19
D TR2/3/3A Vacuum connection at Carb Triumph 23
G TR4/4A Distributor Vacuum Manifold Hard Line Triumph 11
6TTR3A TR2/3/3A Vacuum advance questions Triumph 2
E TR4/4A Vacuum connection on SU-H6 carbs Triumph 4
D TR2/3/3A Vacuum advance tube Triumph 6
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
C Distributer with no vacuum advance Spridgets 15
Griz Testing Vacuum Advance Austin Healey 5
BJ8Healeys '72 Midget Vacuum Advance Line Spridgets 2
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
B TR6 Timing using a vacuum gauge Triumph 13
T MGB Vacuum advance and Electronic ignition conversion MG 5
SherpaPilot TR6 Vacuum Gauge Timing Triumph 5
jfarris TR2/3/3A Vacuum Advance Thread Size Triumph 9
PatGalvin TR2/3/3A Vacuum Hose Fitting Install, Any Suggestions? Triumph 6
Merlin63Tr4 TR4/4A Gasoline in vacuum advance unit. Triumph 10
jfarris TR2/3/3A SU H6 Vacuum Advance Fitting Thread Size Triumph 2
W BE vacuum advance line and fittings Spridgets 2
W Vacuum advance nipple Spridgets 0
Gerry M TR6 Vacuum Lines Triumph 8
GTP1960 TR2/3/3A SU, H6 carb vacuum line connector? Triumph 2
J TR2/3/3A Vacuum lin Triumph 13
PatGalvin TR2/3/3A vacuum leaks? How to check Triumph 9
M Vacuum Leaks Austin Healey 22
bigjones Vacuum advance on a 1500 Spridgets 13
sundown TR6 1973 TR6 vacuum reading Triumph 2
jfarris TR2/3/3A Early 56 TR3 H6 Carbs, distributor vacuum advance/retard Triumph 3
