Upgrading BN1 frt brakes
Genos2
Just wondering, would it be better to use Bn7 or BJ8 disc & calipers, etc. I would imagine I'd have to use kingpins also. Would this affect value? I just would like it to stop better,I could always keep all old parts, thanks Genos2
I think the BJ8 brakes would be the better of the two, but much harder to find a complete setup, the car is not a heavy as the BJ8 so it may not be necessary and the BN7 setup would work just fine. Do some research though regarding the brake booster. Will it be necessary to use it with the BJ8 setup and if so, does the 4 cyl generate enough vaccuum to work it. The kingpins would not need to be changed as they are the same for all big Healeys. The value thing is a little bit more challenging. It would depend upon what level your car is, driver, concours, etc. If it is a driver then I don't think there will be much value difference. It may also increase the value in that scenario. Now if you have a concours car, then it may decrease the value.
I installed the Dennis Welch disc brake upgrade on my BN2. Works fine, no vacuum booster needed.
I looked at the Welch setup, looks like stock(upgraded) BJ8 stuff.Sure is spendy,wonder why they show diferent part # for BN1 or BN2 on. I think I've got 2or3 stock BJ 8 assemblies out back. I think that would be my best bet.I did't realize kingpins were the same. Thanks alot, cheers Genos2
I have stock BN/BT 7 front brakes on my 100. No need for a power booster--in fact plenty of reasons to NOT use one.
King pin is the same but the stub axle may be different. That could explain why Welch has two different part numbers. The early ones may have a problem bolting up a disc brake assembly.
If thats the case,then could't I bolt in either the complete assembly (kingpin&stubaxle)or pretty sure i've even got control arms I could use. cheers
Yes if you have the discs set up from a late car the suspension parts should be bolt in, I had a 100 with the earlier BN/BT brake set up, worked fine, not a huge issue but I believe the pads and new discs for the BJ8s are cheaper if you need to replace them, I know I put new disc rotors on mine and remember being bummed when I figured out I had the earlier set up because the parts were more.
I wouldn't think you would need the booster with the BJ8 set-up, but others who have had it could say more definitively.
Jim_Gruber Upgrading rear brakes on a BE Spridgets 6
A Upgrading front rotors and pads. Austin Healey 4
D TR2/3/3A Upgrading Tr3A engine Triumph 8
T TR4/4A Upgrading the TR4 stock fan Triumph 20
T Upgrading My Headlights Jaguar 10
T Upgrading my sound system Jaguar 6
K MGB Upgrading Carbs on a 80 MGB MG 17
W Upgrading to Range Rover Rover / Land Rover 1
B Upgrading valve cover - gasket sealant question Triumph 15
T Wedge Upgrading TR8 stock suspension - start with shocks Triumph 21
ahpook Upgrading ignition questions. Spridgets 6
davidk Considering upgrading brakes - Stainless Lines? Triumph 25
Banjo upgrading brakes on a MKVIII Jaguar 2
sultanoswing Upgrading turn flasher unit? MG 5
B Wanted Early BN1 Right Hand Sidescreen Austin Healey Classifieds 0
B BN1 Overdrive Austin Healey 5
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
J For Sale BN1 project car (price reduction) Austin Healey Classifieds 0
W BN1 Steering Box Removal Austin Healey 11
W BN1 Steering Box Austin Healey 3
I Wanted BN1 with H6 carbs : bodies of TR3 Austin Healey Classifieds 1
S BN1 Wheel-Tyre Combination Austin Healey 10
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
W Healey BN1 Ignition Light Austin Healey 8
T Wanted: Early BN1 Sidescreens Austin Healey 2
Guido36 BN1 with Triumph TR 4 engine Austin Healey 1
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
W BN1 Gearbox First Motion Shaft Austin Healey 0
I Austin-Healey BN1 Parts List Austin Healey 4
BoyRacer BN4 Front Wings on a BN1 Austin Healey 9
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 25
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
red57 Interesting BN1 for sale in Bellingham, WA Austin Healey 4
D BN1 Parts to Trade Austin Healey Classifieds 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
A BN1 Mechanical Brake Switch Austin Healey 23
P Wanted BN1 can shaft Austin Healey Classifieds 0
C BN1 Clutch Pedal Rattle Austin Healey 2
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
Guido36 BN1/BN2 Sidescreens Austin Healey 0
M BN1 Loss of Power Austin Healey 21
L Seat position for a BN1 Austin Healey 0
CharlesBN1 Wanted WTB Shelley Jack [6 INCH DL] for Early BN1 Austin Healey Classifieds 0
M BN1 with H6 carbs : what setting ? Austin Healey 56
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
M Heat-related carb issue on BN1 Austin Healey 7
RCarr 1954 BN1 Wiper Wheelbox and Rack Austin Healey 3
CharlesBN1 Wanted wanted to buy - sidescreen trim/strips for early BN1 Austin Healey Classifieds 5
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
Michael Oritt Optimal lighting for a BN1 Austin Healey 5
