General Tech Universal Joint—Driveshaft
KVH
Can I replace a drive shaft universal joint with the driveshaft left in the car? Room is tight but it must be possible?
You might want to pull the whole shaft out and put it on the bench, makes life a lot easier! PJ
Removal of transmission is not required. The drive shaft ends terminate in 4 -bolt flanges that unbolt from similar flanges on the tranny and rear end.
Bob
I would not try to replace the U joint in the car. ( You should likely do both front and rear at the same time.) It requires a lot more need of movement than you are apparently aware of..
Charley
Really takes very little time to remove the propshaft completely. I did it recently just to have more room to replace the rear seal with the gearbox in the car.
Once undone on each end it is easily slid out the back .
I always mark the flanges so I put it back in the exact same orientation but not sure that's necessary.
Not really. You cannot access the front of the drive shaft in the car. Then, as mentioned above, it's not really a job to replace u joints in tight spaces.
Oh? And what fate have I invited by failing to mark that yoke? It’s all back together, and I guessed:smile:
The driveshaft is spun up to balance it when first assembled. You may experience a vibration if the yoke alignment is off from original position. Any good driveshaft shop should be able to rebalance it, just tell them you may have the weight distribution off and why.
If you put it back together with both u-joint yokes in the same clock position, you are 50/50 likely to have it in original position. Even if you are out 180, you may very well not get a vibration. If you do, try a 180 position change before the shop.
Bob
Actually there are four possible ways to line up the U-joints. Two with yokes on each end the same and two not so much.
I have got them jacked up high enough to run and hold a marker to the driveshaft and see if it vibrates and used ss hose clamps and balanced them. Not for the unsafe person.
Is this a big enough issue that I need to pull the driveshaft and have it balanced, or is there sufficient working space underneath to release and change the yoke spline alignment after a few test drives, or successively?
I have replaced the U joints on 4 TRs and have yet to have any of the drivelines balanced. And have not felt any vibrations.
Charley
Great. I’ll put it all back together and report by post if I feel or hear anything I don’t like or can’t recognize.
I have change many many UJ's during my lifetime without the need to rebalance a prop shaft,
I have even shortened propshafts without rebalancing, allways shortened them at the yoke and never had an issue
I've replaced a "few" U joints also and never had to have one balanced. Only when I've had a driveshaft shortened, or lengthened, they were balanced by the driveshaft shop.
Align UJs as they came out and you should not have problems. Only time I had to balance was for length, shortening, or replacing damaged yokes from crashes or failures.
C Bugeye propeller/drive shaft- universal joint Spridgets 1
Griz Universal joint let go Austin Healey 15
Foura TR4/4A Universal joint diameter Triumph 9
Scotsman TR4/4A Lower steering flex joint upgrade to TR6 Universal joint Triumph 2
D TR2/3/3A Universal Joint Lube Question Triumph 8
R Drive shaft universal joint bear cap modification Austin Healey 7
TulsaFred Universal Joint problems Spridgets 9
wkilleffer Broken universal joint MG 11
Ohiobugeye Can a Bugeye ignition switch be replaced with a universal ignition switch ? If so how would the wires be attached ? Spridgets 15
OZ_BN1 Drive Shaft Universal Joints Austin Healey 2
T TR2/3/3A 30a 5 pin universal relay Triumph 12
Bugeyze Universal joints Spridgets 6
Foura TR4/4A Steering column Universal Joints Triumph 10
JPSmit Universal Wire Harness question Restoration & Tools 3
sd80mac7204 Universal Joints Triumph 3
1 Hardtop AH 100/4 Universal Laminations Austin Healey 16
1 Hardtop AH 100/4 Universal Laminations FORUM Navigation Questions 1
TR4 TR4/4A Changing universal joints in a TR4???? Triumph 5
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
K TR2/3/3A Inner tie rod ball joint. Triumph 6
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 4
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 15
Jim_Gruber Strange noises - Bad U Joint perhaps? Spridgets 10
D TR4/4A inner tie rod ball joint tension Triumph 0
TomMull TR2/3/3A Flooe panel to bulkhead joint detail Triumph 3
H GT6 Axle u-joint replacement Triumph 3
Keith_M steering rack inner ball joint Spridgets 14
D Side Rod Ball & Joint Installation Austin Healey 17
W Etype lower ball joint removal Jaguar 14
RJS General TR U-Joint Grease fitting interferes Triumph 4
B Spitfire How do you replace U Joint on late model Spitfire OD Prop/Drive shaft? Triumph 7
DornTRoriginal TR2/3/3A U Joint Issues Triumph 5
J New Ball Joint for Control Arm or use the old one? Triumph 4
Willie_P TR4/4A tr4 tie rod end/ball joint - technical question Triumph 2
L Speedometer pinion bush joint washer Spridgets 1
richberman Pictures of BN4 front shroud/chassis joint Austin Healey 5
T Help on ball joint - vertical link fit Triumph 20
doughairfield Ball joint to spindle Triumph 3
T sealing oil leaks in a horizontal joint Spridgets 6
T Stahlwille part #12616 balljoint puller Austin Healey 13
mrsprite Total U-joint failure @ 70 MPH.... Spridgets 13
Stinger TR4/4A TR4A Inner Tie Rod and Ball Joint Triumph 8
T TR4/4A Silly question on TR4A ball joint Triumph 4
CinneaghTR Which ball joint separator should I use? Triumph 7
Tabcon New Ball Joint Install Help Needed. Triumph 2
glemon U Joint questions Triumph 11
SilentUnicorn Ford-93 ranger Ball Joint-lower 4x4 Other Cars 2
NutmegCT Mazda fun - CV joint? Other Cars 6
bthompson U-joint kerplooey! Spridgets 1
Tabcon Mushy ball joint boots...A SOLUTION! Triumph 13
