Ball joint to spindle
doughairfield
Ok, probably a dumb question but I can't figure it out.
When tightening the nyloc nut to attach the upper part of the spindle to the new ball joint, the bolt in the ball joint just turns and I can't get the nut tight. How do you get the nut tight to secure the ball joint to the spindle?
it should be a friction fit and as you tighten the nut it locks the spindle into place and able you to tighten more with out the spindle turning, maybe clean the socket really well with degreaser and try again
hondo
Do it first with a non nylock nut. After it's tight remove the nut and then use the nylock nut.
K TR2/3/3A Inner tie rod ball joint. Triumph 6
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 4
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 15
D TR4/4A inner tie rod ball joint tension Triumph 0
Keith_M steering rack inner ball joint Spridgets 14
D Side Rod Ball & Joint Installation Austin Healey 17
W Etype lower ball joint removal Jaguar 14
J New Ball Joint for Control Arm or use the old one? Triumph 4
Willie_P TR4/4A tr4 tie rod end/ball joint - technical question Triumph 2
T Help on ball joint - vertical link fit Triumph 20
Stinger TR4/4A TR4A Inner Tie Rod and Ball Joint Triumph 8
T TR4/4A Silly question on TR4A ball joint Triumph 4
CinneaghTR Which ball joint separator should I use? Triumph 7
Tabcon New Ball Joint Install Help Needed. Triumph 2
SilentUnicorn Ford-93 ranger Ball Joint-lower 4x4 Other Cars 2
Tabcon Mushy ball joint boots...A SOLUTION! Triumph 13
J Ball joint and steering question Triumph 12
KVH Ball Joint and Tie Rod Grease Zerc Fittings Triumph 4
bigjones Upper Ball Joint Fun and Games Triumph 15
S Greasing new upper ball joint? Triumph 5
C Turning ball joint Triumph 6
M TR4/4A TR4A upper Ball Joint Removal Triumph 9
J Spitfire Ball Joint replacement on Spitfire Triumph 1
M Ball joint/tie rod ends Triumph 8
M XK 140 Lower Ball Joint Jaguar 1
S TR2/3/3A Tr3 ball joint play Triumph 2
C TR2/3/3A TR3 Ball Joint Replacement Triumph 2
Guinn Ball joint problem!!! MG 4
S tie rod end/ ball joint tool Restoration & Tools 10
nevets ball joint rubber boots Austin Healey 2
1 E type upper ball joint rebuild... anyone done one Jaguar 1
Cain Lubing Outer Tie-Rod Joint/Upper Ball Joint Triumph 5
D TR4/4A TR4 inner ball joints Triumph 8
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
Joe Reed General MG MG logo ball point pens... MG 0
tr3guy TR2/3/3A Brake caliper with ?ball bearing? Triumph 5
B TR2/3/3A Anyone have quality problems with TRF's TR2-4 ball joints? Triumph 10
brgrmyster GT6 What's the purpose of the ball bearing in the PDWA switch? Triumph 1
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
S TR2/3/3A this shifter/ ball and cup Triumph 5
bighealeysource Proper way to "seat" ball bearings in OD operating valve Austin Healey 3
B Ball Bearing-type Clutch Release Bearing for BN2 - Availability ??? Austin Healey 2
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
T sourcing linkage ball/sockets Austin Healey 13
vette Throttle Linkage Ball Joints Austin Healey 5
V Upper Ball Joints Triumph 16
Willie_P TR4/4A restoration - ball joints, TR4 Triumph 10
5 Steering Ball-Joints Austin Healey 3
SkinnedKnuckles TR6 TR6 Ball Joints Triumph 13
Mark_Barton Ball bearing in Float Chamber? Triumph 8
