TR4/4A Tubes…or not?
TR Tom
My 65 Tr4 came with the old aluminum 8 spoke American Racing mags, like the rally cars had in the 60’s. Over the years various tire stores have given me conflicting advice as far as whether or not to install tubes or go tubeless. I recently read somewhere that modern radial tires are no longer smooth on the inside so they can wear a hole the tube.
I guess the question would be if these old mags are set up to seal properly with tubeless tires, or if they were designed to use tubes. I’ve gone both ways over the years, but kind of want to be safe. It’s time for new tires, so I need to start thinking about this. What are others out there doing?
Thanks,
Tom
T
TR Tom
Makes sense that condition would be an important factor. I guess the best way to evaluate would be with the tires removed from the rims.
Was wondering though if there was a rim shape difference as well. Unfortunately not too many old time tire guys left that remember the old tube days
Thanks for the reply,
Tom
mctriumph
Send these vintage wheels off to be reconditioned !!! Life is better without flat tires!!
I like Wheels America, but there are many. It is surprising what vintage wheels are worth
these days.
Mad dog
titanic
I have the 4 spoke ARM wheels used on the TR6 and use them without tubes. The only problem I have encountered was loss of air when someone cleaned the exterior with a cleaner. Supposedly, the sand cast wheels need sealing because of porosity. Anyway, I was advised to spray the interior of the wheel with epoxy paint, which I did, and haven't had any further problems.
Berry
T
TR Tom
I remember hearing about sealing the inside surface years ago, but never got around to doing it. Any special type of epoxy paint recommended?
Funny you mention the value of these old wheels. When I was looking for another TR back in ‘83 I almost didn’t bother to go look at this one because the seller said over the phone that it had ”mags”. I pictured some gawd awful Craigers. Pretty sure I could now sell the wheels for what I paid for the whole car back then.
Tom
titanic
I just used "generic" epoxy paint available almost anywhere.
I bought the TR6 ARM wheels at a swap meet in the 80s for about $100. At that time I was going to use them on a TR3, but they were too wide. A few years later, I bought a TR6 and was able to use them. They are still in use.
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
D TR2/3/3A Pushrod tubes Triumph 4
B Tubes in radial tires on wire wheels - what do you do? Austin Healey 27
B TR2/3/3A Tubes in steel wheels? Triumph 18
TulsaFred Proper attachment of Demister tubes and vents Spridgets 3
Michael Oritt Tubes in, Box out Austin Healey 10
Keith_M demister tubes and vents Spridgets 2
D TR2/3/3A Tubes in steel wheels? Triumph 15
doc50 TR2/3/3A Stator Tubes Triumph 12
R GT6 Early Gt6 Pushrod tubes Triumph 14
BlueMax Wiper Chain Tubes Spridgets 3
Lukens TR2/3/3A Are there different lengths for stator tubes? Triumph 3
Got_All_4 General Tech Storage of inner tubes Triumph 4
Scotsman TR2/3/3A Should inner tubes be used with TR3 OEM steel wheels Triumph 3
P New tires & tubes Triumph 23
A TR2/3/3A TR-3A wiper lubricant [tubes and cable] Triumph 1
M_Pied_Lourd TR2/3/3A TR3A Rear Bumper Distance Tubes Triumph 11
S TR4/4A Leaking push rod tubes, TR4a Triumph 7
af3683 Quality Inner Tubes Austin Healey 2
af3683 Moss Wire Wheel Inner Tubes Triumph 8
sail Hand Mounting Tires/Tubes Triumph 12
T Steel wheels and tubes Triumph 12
T inner tubes Austin Healey 13
Jim_Gruber SU Carb overflow tubes Spridgets 11
M wheels, tires, and tubes Triumph 8
GBRandy Wedge TR8 Power Steering Tubes - available soon Triumph 5
mountainman TR2/3/3A TR3 Drain Tubes Triumph 8
R Tires and tubes British Motor Corp 4
S Breather Tubes Jaguar 3
A TR4/4A TR-4 cylinder head push rod tubes Triumph 2
P Manifold and Carb overflow tubes on a BJ7 Austin Healey 18
D Tubes req'd w/ wire wheels on Midget?? Spridgets 6
dklawson Wire Wheels & Tubes Triumph 8
Y Using inner tubes in radial tires Triumph 25
Lin BJ8 convertible drain tubes Austin Healey 7
Baz Wire wheels, tires and tubes.... Restoration & Tools 7
M Inner tubes needed?? Austin Healey 22
AUSMHLY drain channel tubes Austin Healey 15
Y tires & tubes Triumph 4
miranda tires on a 100-6, inner tubes or not? Austin Healey 2
P SU CARB Overflow tubes MG 6
M 69 XKE tire tubes and rubber spoke end strips Jaguar 2
