Trying to get back working on the 1974 Midget
DavidApp
I seem to have been neglecting the Midget for too long. So many jobs jumped in front of it.
Making an effort to get back to working on it.
The doors are really heavy and when they are off the car they are a bit awkward to handle. So I came up with this method of holding them. Not sure how well it will work.
David
JPSmit
looks great! clever idea for sure. BTW, when I reinstalled my doors, I changed out the screws for bolts. Then I could use a socket to hold and move the door with one hand and snug it up with the other. Once all was alligned I replaced the bolts for the screws one by one. Glad you are getting back to it. Progress!
DavidApp
I got the drivers side door completely stripped down. Trying to follow You Tube videos on the door assembly but found most of them focus on getting the regulator in or out with the glass not installed. Getting the glass off the regulator was a pain and I think I may have missed something somewhere. The Bentley book was not a lot of help in this area.
I think I will have to play it by ear unless someone can point to a good video.
It seems there is a gap in the track on the window which I thought may help in getting them separated. I did find that I think I can leave the quadrant stop in place and the bottom of the quarter light frame it may be better to unbolt the support from the bracket rather than the 2 bolts that hold the bracket.
Looking around in the paint store for colour swatches.
David
JPSmit
There is the piece on the bottom of the glass that fits in the gap on the track. It has been quite few years but I recall that you undo the regulator and slide it along to lift the glass out. The sweep and the felt are the bonkers bit to get back on so anything you can do to start growing six inch fingers the better.
Seriously there is a tool you can make for the clips.
In the meantime here is an excellent site for colour:
Also, assuming you are replacing the rubber sweep and the felt, this is the best sourc out there:
lots of good advice here!
Bayless
On that tool for the window scraper clips, yes you can make it but the over-priced one from Moss has a little magnet built into it that helps keep them from falling off. And I give a resounding second on MacGregor for all the rubber parts. His actually work. I learned the hard (spelled expensive) way.
DavidApp
Thanks for the information.
I got the quarter light seals from moss and they look a bit sketchy.
Will order some from MacGregor along with the other seals.
Anyone have the dimensions for the window stop bracket. All I have left is the mounting screws.
I have a couple of tiny rust holes in the lower edge of the drivers door which I will cut out and patch. Then POR 15 the inside of the door.
I did find a great description of the reassembly by Norm Kerr on the other site. I will try to link to it.
David
Bayless
I had the quarter light seals from moss and they were useless. I finally convinced someone that they sent me the wrong or otherwise bad stuff and they agreed to replace them. They sent another copy of the same thing. That's when someone on this forum suggested MacGregor so I ordered his and they are perfect. I also had a boot lid seal from moss, in fact I accidentally had two, and the lid would not even come close to closing. I ordered that from MacGregor and it works. Then I got smart and ordered his door seals before making the Moss mistake.
This chapter > Sprite Restoration - Chapter VIII < of my web page gives a lot more detail and shows how I got the windows and scrapers installed.
DavidApp
Had a look at the quarter light seals today. One is useless as it looks like they used a razor to cut off the flashing but missed the correct line.there is a section on the back edge that is almost cut through. The other side is not like that.
Started welding up the rust pin holes in the door. So far I have not blown through the door skin. I am using a step bit to drill the holes then cutting out discs to fill the hole.
David
DavidApp
Went out and got a battery for the Midget today, size 51 seems to fit. When I was placing the heater box in the car to judge the amount of room I had for the battery I noticed there is a gap between the bottom of the heater and the air intake to the car. Don't remember what went in there. Some foam packing? It is about 1"
Did run the engine on its stand till it was warmed up.
David
JPSmit
foam packing indeed. I just found some closed cell foam and filled it in.
DavidApp
I have a 3D printer so I may print a spacer and add some thin foam to form a seal. Got to find Real Jobs for the printer.
David
JPSmit
David
Smart plan - I recall cutting layers. It is an odd space that I suspect has more to do with a 'parts bin' heater than anything else.
B GT6 trying to ID my New Car. GT6 Triumph 6
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
JPSmit Thinking out loud and trying to understand. Restoration & Tools 31
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
G General TR Trying to reach Frank.... angelfi? Triumph 2
T Trying to identify a steel plate part Austin Healey 2
red57 Trying to identify this gear. Austin Healey 2
K TR2/3/3A Karl's ham handed adventures for your amusement in these trying times. Triumph 8
E Trying to ID some old classic car gauges Restoration & Tools 2
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
D Trying to understand my cooling system Austin Healey 29
D Lilly second time running... or trying Austin Healey 8
D T-Series Trying to find out an interior dimension MG 7
T Trying to find an accurate tyre pressure gauge Spridgets 24
B MGB Trying to restore emissions controls on 79 MGB MG 0
D TR4/4A trying to identify bolts etc Triumph 5
M TR2/3/3A Grinding noise when trying to start sometimes? Triumph 10
J TR2/3/3A Trying to start engine for the first time! Triumph 11
F Frustration trying to adjust handbrake on Austin Healey BT7 Austin Healey 9
R TR2/3/3A Trying to trace some history on my TR3a Triumph 1
AngliaGT Trying to Rebuild the Brake M/C - Help! Spridgets 5
B New Colorado Red/Signal Red Thread - Trying to get it right Austin Healey 0
tomshobby I am trying to find the past history of my Midget. Spridgets 3
M MGB trying to change rotors - dumb question MG 7
KVH TR4/4A I'm Trying to Tune, Again Triumph 4
S Mk III Sprite cockpit surround - trying to recover Spridgets 9
Answerman Ghost of Lucas is trying to start my Jensen Healey Other British Cars 8
T someone is trying to sell my car Triumph 4
RickB Trying to sell the Sprite Spridgets 27
J Just trying to post pic of cool Jag! Jaguar 0
M Trying to locate William Holden Racing 2
H Trying to help a MG owner, any tips? MG 20
G Trying to reach Robert Triumph 1
H AH 3000 Trying to find the right look Austin Healey 23
M Trying to ID the Right Parts for Clutch Work. Spridgets 1
jlaird Miss Agatha was trying to tell me something Spridgets 4
G My "B" is trying to quit !! MG 7
M Car goes "click" when trying to start - the fix Spridgets 8
bigjones Trying to stay cool Spridgets 0
doughairfield Trying to get my motor started Triumph 8
MCNX_BFF Awakening the Beastie...trying to! Triumph 41
JPSmit trying to understand camshafts Spridgets 22
B TR2/3/3A Williams TR3 Book-Trying to find Triumph 4
OZ_BN1 Trying to identify a part. Other British Cars 21
UmmYeahOk GT6 Is he really trying to sell a GT6? Triumph 22
G Trying to Find T-Shirts Triumph 7
Trevor Jessie Trying out a camera mount... Spridgets 20
M Trying to Find a Family Heirloom Triumph 59
Mark_Barton TR4/4A Trying to replace TR4 transmission mount Triumph 13
mccalebr Trying to contact Jeff Dahn [Bugeye58] Spridgets 4
