TR2/3/3A Trunnion replacement done....Thanks to Forum
karls59tr
Bronze
Thanks to Randall and John and all the others that helped me out with advice on the suspension rebuild. There's maybe 3 good weeks of sports car driving left up here and I'm going to take advantage of them.. Guess you guys in Arizona and California can drive all year round? Great forum. Let's keep those LBC's on the road. :eagerness:
Bremer
Three weeks left? Envious. Our season ended two weeks ago...
martx-5
Gonna get up to about 80°F here on Long Island today...unfortunately, I've gotta work. :frown:
Normally, we would be in the 60s this time of year, which is about perfect for me. I feel that the fall is the best driving season. We should be good for at least another month.
TR4nut
Our season is just starting!
R TR6 TR6 Trunnion Setup Triumph 5
R TR6 Lower A-arm trunnion bushings Triumph 18
Upland SuperPro trunnion bushings Spridgets 0
pkmh BJ8: Upper Trunnion Rebuild [Of Continuum] Austin Healey 9
J Top Trunnion Bushing Fit Austin Healey 9
F TR2/3/3A Trunnion bolts Triumph 11
warwick-steve Front suspension rubber trunnion bearing question Austin Healey 4
J TR2/3/3A Trunnion Install Triumph 3
D TR6 Rusted Trunnion Pivot Bolt Triumph 18
G TR4/4A Well...another stripped trunnion Triumph 8
Scotsman TR4/4A Steering Stop Lock on trunnion Triumph 9
B TR2/3/3A Dimensional discrepancy in Moss trunnion parts Triumph 0
B TR2/3/3A trunnion bush clearance Triumph 2
GTP1960 TR2/3/3A Re-tapping a zerk in a brass trunnion housing? Triumph 17
C TR5/TR250 Trunnion Installation Triumph 3
maxwedge5281 adjustable trunnion Austin Healey 15
B TR2/3/3A Removing front trunnion Triumph 15
M TR4/4A TR4A - Torque the Front Suspension Trunnion Bolt! Triumph 5
Got_All_4 TR2/3/3A Reaming trunnion bushings Triumph 4
doc50 TR2/3/3A Trunnion seal Triumph 1
M_Pied_Lourd TR2/3/3A Verticle Link to Trunnion Fitment Triumph 5
catfood Top trunnion pin removal. Austin Healey 4
S TR2/3/3A bottom out the trunnion Triumph 7
gubba TR4/4A Lower Trunnion question Triumph 8
S TR2/3/3A trunnion drama Triumph 2
S TR6 Trunnion lube Triumph 6
Gerry M TR6 Trunnion oiling Triumph 7
B Top Trunnion Bearing Kit Austin Healey 6
K TR2/3/3A Trunnion spindle conundrum again? Triumph 2
K TR2/3/3A Randall....another trunnion spindle issue? Triumph 5
K TR2/3/3A Trunnion spindle cotter pin hole non existent! Triumph 9
K TR2/3/3A Front end reassembly: trunnion spindles and wishbone bushes??? Triumph 10
K TR2/3/3A Trunnion oil/grease again? Triumph 1
trrdster2000 Trunnion torque. Triumph 16
R BJ8 Top Trunnion removal Austin Healey 8
H top trunnion too tight Austin Healey 3
kurts100 TR6 TR6 Trunnion/Lower A-Arm Bolt--Torque or End Float Triumph 8
K TR2/3/3A TR3 Trunnion Question Triumph 2
Willie_P TR2/3/3A Trunnion Installation - TR3/4 Triumph 7
doughairfield Trunnion question Triumph 27
A TR2/3/3A TR3 Trunnion - vertical link play Triumph 10
M TR6 TR6 Trunnion Bolt Removal Triumph 3
J Trunnion Oiler Triumph 5
ekamm TR2/3/3A tr3 trunnion bushing help Triumph 2
Jim_Gruber Refitting trunnion and .008" Spacers Spridgets 30
ekamm TR2/3/3A Tr3 trunnion Triumph 8
F Trunnion Oiler Triumph 23
Bremer Trunnion pin diameter Triumph 3
T TR4/4A TR4A/6 trunnion question Triumph 7
T Local options for trunnion plugs MG 3
