Trouble shooting trafficator - 1963 BJ7
Xavier70
I just connected the battery following a full restoration on my Healey Pretty much everything is new or rebuilt. New Moss wiring harness. The turn signals not working. Just started working thru the system. So far it appears the switch in the steering wheel is working. Since I really don't know how the flasher relay works any advice on checking this out this component and the system in general would be appreciated.
Ok. The box basically diverts power from the brake lite to the flasher. I just had to replace a new unit with another one.
You should have power between the flasher and the box at terminal 8. Check the flasher for power from the fuse box to the x terminal.
Thanks. Here's an update: Did a little more checking (Definitely not done)
  1. I have power from the fuse to the correct terminal on the flasher. It's a new one from Moss.
  2. Have power to the input to the steering column turn signal switch, actuating the turn signal switch does send power to the correct terminals on the relay box.
  3. I took out the new Moss flasher and put my old one back in. At this point I got the right front to flash but not the left front. Both rear lights flashed.
  4. I had to quit for a meeting at this point, will get back on it on Thursday.
  5. Suggestions welcome.
Finally got back to checking out the system. ( my deck resurface turned into a full rebuild). With a little more checking I found the problem pretty quickly. I had tied both RH & LH circuits together in the trunk. I misinterpreted the wiring diagram and use a double bullet connector, should have used two single connectors. Oh well, all’s well that ends well.
Glad you sorted it. Sometimes it’s good to walk away and come back to it at a later date.
I don’t always have that luxury.
S Electrical Trouble Shooting Spridgets 8
P Flasher trouble shooting - pls help Austin Healey 6
H Trouble shooting gas gauge...any hints? Austin Healey 9
S trouble shooting not working speedo or testing one Triumph 22
T A-type overdrive / gearbox trouble shooting Triumph 69
Monark192 MGB-GT 67 BGT - Overdrive Trouble Shooting Question MG 0
T TR2/3/3A Trouble shooting TR3a Temperature gauge Triumph 13
73MidgetLigon DCOE Trouble shooting Spridgets 32
J Spitfire 1978 Spitfire Horn trouble shooting Triumph 10
A Fuel System Trouble Shooting Help Austin Healey 5
T General Tech Clutch trouble Triumph 12
sparkydave Trouble running hot Spridgets 10
F General Tech trouble with editing post Triumph 2
HealeyRick Tach Trouble Spridgets 2
JPSmit Trouble posting pics FORUM Navigation Questions 2
D Tune Up Trouble Austin Healey 24
G TR6 Clutch trouble Triumph 4
J Powertune booster for a bj8 , trouble installing Austin Healey 2
T Trouble inserting pictures to post FORUM Navigation Questions 2
R TR6 Trouble with TR6, carb now??? Triumph 6
B TR2/3/3A anyone else had trouble with TRFs wheel bearing dust covers? Triumph 5
C First Gear Trouble BN1 Austin Healey 5
L Trouble refitting pulley to new water pump Spridgets 9
C bugeye trouble spots Spridgets 5
C what are the trouble spots on a bugeye Austin Healey 1
RickB MGB Trouble bleeding new clutch MC & slave MG 6
B sprite engine trouble? Spridgets 2
T TR2/3/3A TR3 Engine Noise trouble. New to Triumphs. Granfather's Car. Need Help. Triumph 43
R Lower wishbone bushing installation trouble Austin Healey 9
F MGB '76 MGB ignition trouble MG 62
longbridgehealey Big trouble with BN4 brakes Austin Healey 53
MG Lily T-Series MG-TD Battery Trouble? MG 4
wkilleffer MGB Trouble with adjusting the front SU carb- 74 MGB, HS4 carbs [long] MG 5
smaceng TR6 Trouble with a TR6....body! Triumph 10
bighealeysource Trouble getting toe in done on BN2 Austin Healey 16
J Having trouble getting Forum to work on IE 9 since it was switched to the new format. FORUM Navigation Questions 7
Morris I could be in trouble here... Spridgets 17
M Another Ebay trouble child? Spridgets 39
glemon Trouble Lights for Cheapskates Like Me Restoration & Tools 3
TulsaFred First start trouble rebuilt 1275 Spridgets 29
dvmmatt steering trouble Spridgets 17
M Intermittent Hard Starting on 99 XJ8 Trouble Code Jaguar 13
theleisure Trouble Dropping Motor into Mounts Spridgets 14
T Trouble restarting after a drive Spridgets 11
G Sway bar mounting area trouble? Spridgets 14
rlich8 TRouble with the TRans tunnel and Speedo Pinion Triumph 4
G DCOE trouble/qusetion Spridgets 10
M Had trouble with Prestone Power Steering Fluid? Jaguar 2
MTribe need help - pertronix trouble at low idle speeds? Triumph 19
Tremelune Starter trouble--Local lifetime replacment? Spridgets 54
