TR6 Trouble with TR6, carb now???
Rebelbrad
I have a TR6 I inherited from my father, he was going to have a huge engine installed but died in the middle of it. The shop kept all his money and I paid them 500 to put back in old engine.
It drove fine at first but seemed to lose power. Then sat for a few months. I cranked and gas spewed out the bottom of the carbs. After reading the forums I took off carbs thoroughly cleaned replaced o-ring plugs all new seals. They were full of an orange/reddish sediment.
After I hooked everything back up.
It cranked up, no leak, but now there was no power I would give it gas and nothing. Just no power.
Any ideas?
I'm afraid the shop that put the engine back in could have really screwed up the car.
BTW typed on iPhone so forgive typos
Maybe not. Check the rubber diaphams in carbs first. To do, remove four screws on top of each carb dome , lift off and you will see spring and rubber bellows. Check the diapham for any tears or holes. Replace and try again.
Marv
TR3driver
Great Pumpkin - R.I.P
Did you put oil in the dashpots? Change the fuel filter?
BTW, most of the books are either misleading or flat-out wrong about how to set the ignition timing. The 4 ATDC timing number applies only if the vacuum retard is present and functional. If you aren't certain if it works, just disconnect it and set the timing to 10 or 12 BTDC.
mrv8q
Is there a local Triumph club you can join?
glemon
Sediment in the carbs sounds like a rusty tank, nothing the shop did. The crud can block the fuel flow and the car wont run. Usually the harder or faster you run the engine the worse the problem gets. Many options for a fix. Cheapest is to drain the tank, put a handfull of rocks or nuts and bolts in it and shake it (a lot, if you have teenage sons put their youthful energy to work). You then have to get all the rocks or whatever out, which involves more shaking and turning. I rinsed mine with water after, though I am sure there are better things to use, and dried it in the sun, more turning to get the water out. Or you can get a sealer kit and do basically the same thing, plus add sealer at the end, which may or may not work (you can read all about gas tank sealers online, doesnt have to be TR6, a gas tank is a gas tank).
Or get a new tank.
I am assuming this is your problem, no guarantees it is your only problem, but hard to get a car to run right with a lot of crud in the system, and once it starts it usually continues unless measures are taken.
smaceng TR6 Trouble with a TR6....body! Triumph 10
bluemiata90 TR6 TR6 CLUTCH PIN OR HYDRAULIC TROUBLE Triumph 6
T General Tech Clutch trouble Triumph 12
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
sparkydave Trouble running hot Spridgets 10
F General Tech trouble with editing post Triumph 2
HealeyRick Tach Trouble Spridgets 2
JPSmit Trouble posting pics FORUM Navigation Questions 2
D Tune Up Trouble Austin Healey 24
G TR6 Clutch trouble Triumph 4
J Powertune booster for a bj8 , trouble installing Austin Healey 2
T Trouble inserting pictures to post FORUM Navigation Questions 2
B TR2/3/3A anyone else had trouble with TRFs wheel bearing dust covers? Triumph 5
C First Gear Trouble BN1 Austin Healey 5
L Trouble refitting pulley to new water pump Spridgets 9
C bugeye trouble spots Spridgets 5
C what are the trouble spots on a bugeye Austin Healey 1
RickB MGB Trouble bleeding new clutch MC & slave MG 6
B sprite engine trouble? Spridgets 2
T TR2/3/3A TR3 Engine Noise trouble. New to Triumphs. Granfather's Car. Need Help. Triumph 43
R Lower wishbone bushing installation trouble Austin Healey 9
F MGB '76 MGB ignition trouble MG 62
S Electrical Trouble Shooting Spridgets 8
longbridgehealey Big trouble with BN4 brakes Austin Healey 53
MG Lily T-Series MG-TD Battery Trouble? MG 4
wkilleffer MGB Trouble with adjusting the front SU carb- 74 MGB, HS4 carbs [long] MG 5
bighealeysource Trouble getting toe in done on BN2 Austin Healey 16
J Having trouble getting Forum to work on IE 9 since it was switched to the new format. FORUM Navigation Questions 7
P Flasher trouble shooting - pls help Austin Healey 6
Morris I could be in trouble here... Spridgets 17
M Another Ebay trouble child? Spridgets 39
glemon Trouble Lights for Cheapskates Like Me Restoration & Tools 3
TulsaFred First start trouble rebuilt 1275 Spridgets 29
dvmmatt steering trouble Spridgets 17
M Intermittent Hard Starting on 99 XJ8 Trouble Code Jaguar 13
H Trouble shooting gas gauge...any hints? Austin Healey 9
S trouble shooting not working speedo or testing one Triumph 22
theleisure Trouble Dropping Motor into Mounts Spridgets 14
T Trouble restarting after a drive Spridgets 11
G Sway bar mounting area trouble? Spridgets 14
rlich8 TRouble with the TRans tunnel and Speedo Pinion Triumph 4
G DCOE trouble/qusetion Spridgets 10
M Had trouble with Prestone Power Steering Fluid? Jaguar 2
MTribe need help - pertronix trouble at low idle speeds? Triumph 19
Tremelune Starter trouble--Local lifetime replacment? Spridgets 54
R engine trouble, need advice Spridgets 16
Don_R Spitfire Spit trans trouble Triumph 19
smaceng Engine Trouble? Spridgets 7
G Trouble getting flywheel ring gear on. Spridgets 23
RickB MK2 Sprite - new windscreen to body seal - trouble Spridgets 21
