Trailing arm reassembly question
tdskip
Hi guys - on the TR6 I used Richard's full bushing kit which has washers like this that are used in the assembly;
I have TA bushings from BPNW on hand and am not sure if I can use these (Richard says his are recommended) without the washers? The metal sleeves might need a bit of a trim, but mostly fit well.
Track down generic washers once the sleeves have all be perfectly trimmed, or go washer-less?
You can see the washers in the pick below in between the bracket and black bushing.
Tom I have the same setup on my car. The washers pictured are all different in thickness. You can see the numbers in your picture. It's trial and error to get them in the right place. They are used to remove any slop between the bushing and the bracket. Get them so they are just about to get tight, without any binding. The part of the washer that has the indent goes against the sleeve on the inside. Not sure if this answered your question or not.
Hi Keith - thanks for the note.
I've actually installed this kit on the TR6, and am familiar with matching the washer thickness to the bushing sizing, but thanks for the refresher.
What I was trying to ask is if you don't have Richard's unique bushings if you;
1) You could trim the metal sleeves to exact size and run without washers
or
2) Could trim the sleeves and just use standard washers (with right diameter)
Sorry if I could have explained that better originally!
It's been some time since I did the change to my car so it's not fresh in my mind. I did use Richards bushings with my installation. Without any washers I think the sleeve would have to longer than the original. It would have to be as long as the bracket is wide. Then you could install washers that would fit over the sleeve to remove the side movement. I don't think you would want to over thighten the bolt that goes thru the bracket to pull it in tight against the washers.
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
Tim Tucker TR6 Trailing Arm NYLATRON bushing-washer gap questions Triumph 4
A TR5/TR250 Trailing Arm Question Triumph 9
bugedd Rear trailing arm question Spridgets 2
tomshobby TR6 Nylatron trailing arm bushings. Triumph 11
R TR6 Cruciform [T shirt] and possible trailing arm mount replacement Triumph 8
H TR4/4A Trailing Arm IRS Triumph 6
alanjohnturner TR6 Trailing arm brackets - any IRS car Triumph 2
glemon General TR Adjustable Trailing Arm Brackets, Cheap and Lazy, or clever like a fox? Triumph 0
T Trailing Arm Cracks Triumph 23
K TR4/4A 4A Trailing Arm Bushings Replacement Again? Triumph 2
K Remove & Replace Trailing Arm Bushings? Triumph 9
M Rear Trailing arm Shims Question [pic] Triumph 2
M TR6 GoodParts Adjustable Trailing Arm Brackets TR6 Triumph 14
TR6BobNF TR6 TR6 Trailing Arm Bracket - Crack Triumph 10
glemon TR5/TR250 TR250/6 Rear Trailing Arm Bush Options Triumph 39
B TR5/TR250 TR250 trailing arm box section Triumph 5
T TR4/4A TR4A IRS trailing arm bushing question Triumph 15
Brosky Trailing arm stud repair and new CV axles done Triumph 14
SCguy TR6 TR6 Trailing arm question Triumph 10
Gliderman8 Trailing arm studs Triumph 5
I TR6 TR6 rear hub and trailing arm spares advice Triumph 2
I TR6 How do I grease TR6 trailing arm u-joints? Triumph 8
I TR6 TR6 trailing arm stud upgrade? Triumph 50
I trailing arm torque, torque wrench questions Triumph 28
T Alemites in Trailing Arm to grease Nylatron Bushs. Triumph 8
T Goodparts trailing arm bracket install question... Triumph 4
T Trailing Arm bushing question..... Triumph 9
I TR6 TR6 trailing arm bushing installation help Triumph 24
T Trailing arm failures Triumph 27
D Adjustable Trailing Arm Mounts Triumph 11
John_Mc Trailing arm refurbish Triumph 3
John_Mc Rear trailing arm brackets Triumph 5
T Trailing Arm Bushings Install Triumph 4
RobT Trailing Arm Bushes - Help - Too Many Choices Triumph 12
71tr New Trailing Arm Brackets Triumph 5
M TR6 TR6 trailing arm bracket bolts - Help! Triumph 9
A Installing Trailing Arm Bushes Triumph 9
2 Trailing Arm Studs Triumph 10
SCguy Trailing arm bushing removal Triumph 6
G TR6 Rear suspension [trailing arm] adjustment on a TR6 Triumph 18
71tr Trailing Arm Brackets Triumph 0
tr6web TR6 Bumper stop on trailing arm - TR6 Triumph 5
71tr Trailing Arm Busing Removal Triumph 13
Mark_Gibson TR6 TR-6 Rear Trailing Arm Brackets..Success!! Triumph 10
Mark_Gibson TR6 TR-6 Adjustable Trailing Arm Bracket Feedback Triumph 3
beez trailing arm section Triumph 3
T Trailing arm & rear shock paint ? Triumph 2
TR4nut TR6 Ballpark cost - TR6 trailing arms? Triumph 4
