Alemites in Trailing Arm to grease Nylatron Bushs.
TR6BILL
Richard Good suggest installing grease fittings into the aluminum trailing arms to keep the Nylatron bushes greased. Has anyone done this yet and what did you do?
Bill, that sounds more wierd than some of the things I've
had to do to get my car off jackstands.
I'd have to pass on THAT suggestion.
d!!
I don't have a TR6, but the suggestion sounds reasonable as long as grease pressure isn't so high that lubing the arm doesn't move the bushings out of place. The Mini uses a bushing on one end (and a needle bearing on the other end) of its trailing arms. The arm assembly includes a zerk fitting and it's important to keep the arm lubed. The downside on the Mini (and perhaps on the TR6) is that the inside of the trailing arm can hold a lot of grease. The Mini arm is supposed to have an internal sleeve to minimize the grease required. On most arms the sleeve fails and you end up pumping about a cup of grease in the arm before it starts coming out of the bushings.
Bill,
I put the zerks in my trailing arms like Bob. There's a flat spot on the bottom of the trailing arm that's a great place for this. I just trilled and tapped and hole and installed the zerks. I could take pics tonight if you'd like. I was planning to check bolt torque's on the HVDA conversion and change the lube in the gearbox anyway.
-s
rchakr said:
.....and talks about their orientation.
That's the nice way of saying he did the first one upside down! :wall:
And here's the right way to do them
My Bad - sorry about that.
I installed the hardened rubber bushings.
It appeared to me the trailing arm grabbed the bushing
surfaces and the entire assembly rotated on the steel
tube center piece. I filled the center steel tube
with red wheel bearing grease.
I was not aware the bushing itself rotated against
the trailing arm surfaces.
Again, sorry for the bad info.
dale
Dale, you got it right the first time, the Nylatron (and other non-rubber) bushing does not rotate against the trailing arm surfaces, it rotates on the inner sleeve, held in place by the through bolt. The original hard rubber bushes are molded to the inner sleeve and are not designed to rotate on the through bolt. Instead, they act as a torsion fitting, the rubber flexes radially as the arm swings. When installing, the trailing arm needs to be in the mid position of it's travel movement. The best way to find the mid position is to wait until the rear wheels are on the ground then torque down the through bolts. Many a rear rubber bush has failed due to improper installation where the upward or downward swing is beyond the bushings ability to flex.
As far as installing a grease fitting to extend the life of a Nylatron bushing, I have no experience to support the installation one way or another. If one were to do this, insure the fitting is located were the two Nylatron bushings meet inside the arm, also insure there is sufficient space between them to allow grease to access the inner sleeve.
In the old days we were taught that grease attracts dirt and it sticks together and then the dirt grinds into the bushings and then you get the squeaks when it gets a little dry in the dirty spots. So you add more grease and it's OK for a while then it starts to squeak again, so you add more grease and on and on...........
Dale put the grease in the right spot where the bolt will ride inside the metal sleeve in the bushing. The other bushing sits solidly inside the casting.
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
TR4nut TR6 Ballpark cost - TR6 trailing arms? Triumph 4
Tim Tucker TR6 Trailing Arm NYLATRON bushing-washer gap questions Triumph 4
A TR5/TR250 Trailing Arm Question Triumph 9
T Wanted TR6 rear trailing arms Triumph Classifieds 1
bugedd Rear trailing arm question Spridgets 2
alanjohnturner TR4/4A studs for the trailing arms Triumph 10
tomshobby TR6 Nylatron trailing arm bushings. Triumph 11
R TR6 Cruciform [T shirt] and possible trailing arm mount replacement Triumph 8
H TR4/4A Trailing Arm IRS Triumph 6
alanjohnturner TR6 Trailing arm brackets - any IRS car Triumph 2
glemon General TR Adjustable Trailing Arm Brackets, Cheap and Lazy, or clever like a fox? Triumph 0
B T-Series MGTD brake shoes. Are there leading and trailing shoes? MG 1
T Trailing Arm Cracks Triumph 23
K TR4/4A 4A Trailing Arm Bushings Replacement Again? Triumph 2
K Remove & Replace Trailing Arm Bushings? Triumph 9
M Rear Trailing arm Shims Question [pic] Triumph 2
J TR6 TR-6 Rear Trailing Arms Triumph 2
M TR6 GoodParts Adjustable Trailing Arm Brackets TR6 Triumph 14
TR6BobNF TR6 TR6 Trailing Arm Bracket - Crack Triumph 10
glemon TR5/TR250 TR250/6 Rear Trailing Arm Bush Options Triumph 39
B TR5/TR250 TR250 trailing arm box section Triumph 5
bugedd Adjustable trailing arms? Spridgets 3
SCguy TR6 TR6 Trailing Arms Triumph 2
T Trailing arm reassembly question Triumph 3
T TR4/4A TR4A IRS trailing arm bushing question Triumph 15
Brosky Trailing arm stud repair and new CV axles done Triumph 14
KVH TR4/4A TR4A IRS Trailing Arms and Bushings Triumph 4
T Cleaning trailing arms Triumph 12
SCguy TR6 TR6 Trailing arm question Triumph 10
Gliderman8 Trailing arm studs Triumph 5
I TR6 TR6 rear hub and trailing arm spares advice Triumph 2
T Shimming my Trailing Arms to correct Toe In Triumph 3
I TR6 How do I grease TR6 trailing arm u-joints? Triumph 8
T Shimming Trailing Arms....for a Dummy! Triumph 1
I TR6 TR6 trailing arm stud upgrade? Triumph 50
I trailing arm torque, torque wrench questions Triumph 28
T Goodparts trailing arm bracket install question... Triumph 4
T Trailing Arm bushing question..... Triumph 9
I TR6 TR6 trailing arm bushing installation help Triumph 24
T Trailing arm failures Triumph 27
D Adjustable Trailing Arm Mounts Triumph 11
John_Mc Trailing arm refurbish Triumph 3
John_Mc Rear trailing arm brackets Triumph 5
SCguy TR6 TR6 trailing Arms bushing removal? Triumph 11
B Trailing Arms on eBay Triumph 0
T Trailing Arm Bushings Install Triumph 4
RobT Trailing Arm Bushes - Help - Too Many Choices Triumph 12
J Need some more help on my trailing arms Triumph 4
