So I started with a brake job, and it got more complicated.
Now its the strut, tie rod end, sway bar bushings, and ball joint.
1, do I really need a special tool for the top of the strut to remove the nut at the top?
2, do I need to remove the bolt at the end of the control arm, (opposite end from the ball joint) to be able to release,
The control arm from the end of the sway bar so I can replace the bushings at the end of the sway bar where it go's into the control arm.
Many thanks in advane, tom
