Here's the story in brief (I hope). My TR6 pretty new battery started going dead. I would recharge it and two weeks later it was dead. I discovered the back casing of the alternator was melted into the alternator internal parts. I thought it was the ignition wire from the front cylinder, I wasn't sure. I got a new alternator from TRF and installed it. I recharged the battery. The car would not start, it would turn over but not start. I tested for a spark to the plugs but found none. I took off the distributor cap and discovered that the previous owner had installed a Pertronix Ignitor, so I checked it for a spark, none. I installed a new coil, ignition wires, rotor button, spark plugs (hey I might as well) new everything in the ignition system except a new pertronix ignitor ($89). Still the car won't start. The battery holds a strong charge and the engine turns over and over again, no spark to the ignition wires. Anyone have any ideas? I could sure use some help. Thanks.
