TR6 TR6 valve adjustment help
I think the book says to do it cold, but the maker of my cam said to do it hot (ISKY)
I always do mine COLD... that is what is specified.
Besides, it's better on the fingers.
Hi Kevin - of you have a stock engine then cold is the way to go. Really cold, as in overnight cold. There should be some tappet noise still once you are done. I just did mine on the '74 last night and they were way too tight, quiet, but too tight.
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
T TR6 TR6 Aluminum Valve Cover Gasket Triumph 3
sundown TR6 1973 TR6 bypass valve Triumph 1
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
S TR6 Help! Need help from TR experts with this frustrating TR6 pushrod/rocker/valve issue Triumph 23
smaceng TR6 TR6 brake pressure balance valve Triumph 2
P TR6 tr6 valve guides Triumph 14
D TR6 76 TR6 Stromberg Air Valve Triumph 2
Gliderman8 TR6 Setting TR6 valve clearances Triumph 19
Coyote1 TR6 TR6 EGR Valve Delete ? Triumph 9
Brosky TR6 TR6 Heater Valve - EXPOSED Triumph 9
I TR6 69 TR6 engine suggestions - cause for burnt valve? Triumph 5
D TR6 TR6 Valve Springs Triumph 26
bcbennett TR6 TR6 Valve cover Triumph 11
wangdango TR6 '76 TR6 pcv valve, etc Triumph 3
hondo402000 TR6 New Heater valve installed from Parts america TR6 Triumph 4
TR6oldtimer TR6 TR6 valve reality check Triumph 4
T TR6 Back to that stock TR6 valve cover. Who, where... Triumph 0
T TR6 High temp paint required for TR6 valve cover? Triumph 13
G TR6 I want a stock valve cover for my TR6 Triumph 7
I TR6 69 TR6 vacuum control valve Triumph 8
I TR6 PCV valve attachment 69 TR6 Triumph 5
GT6_Mark GT6 GT6 TR6 etc Oil Filter By-Pass Valve Pressure Triumph 2
roofman TR6 TR6 silicone valve cover gasket Triumph 9
roofman TR6 TR6 silicone valve cover gasket Triumph 2
I TR6 TR6 valve help/upgrade? Triumph 26
I TR6 TR6 valve cover leaking Triumph 5
E TR6 TR6 Valve Train Specs Triumph 0
B TR6 TR6 aftermarket valve cover Triumph 7
F TR6 Oil Pressure Relief Valve- TR6 Triumph 2
G TR6 TR6 inlet valve dimensions Triumph 4
A TR6 tr6 valve lifters--which ones??? Triumph 21
G TR6 Anti run-on valve question for 73 TR6 Triumph 3
AltaKnight TR6 TR6 leaky heater valve Triumph 2
V TR6 two piece valve spring retainers on tr6 and 250. Triumph 1
B TR6 TR6 Valve Cover Gasket Triumph 5
Stinky TR6 TR6 valve cover ??? Triumph 3
R TR6 TR6 EGR valve Triumph 12
J TR6 1975 TR6 Convertible Top Replacement. Triumph 1
mctriumph For Sale Tr6 rear bumper assembly/with over ride bar Triumph Classifieds 0
E TR6 TR6 Front fenders Triumph 5
EWD TR6 74 TR6 headscratcher Triumph 38
jfarris For Sale TR6 Yellow Fan - New Triumph Classifieds 0
tr6nitjulius TR6 TR6 review Triumph 3
K TR2/3/3A First gear ratio on the TR6 gearbox? Triumph 11
D Wanted TR6 Lamp/Bezel Assembly - Heater Controls - 219139 Triumph Classifieds 1
mctriumph Wanted Tr 3/Tr6 transmission kit interest Triumph Classifieds 2
tr6nitjulius For Sale SOLD! 8/29/24: 4$ale NEW! TR6 radiator support brackets Triumph Classifieds 0
T TR6 TR6 distributor issue Triumph 6
tr6nitjulius TR6 TR6 N IT That SOUND FEEL LOOK! Triumph 0
