TR6 TR6 Heater Problems
A. Salnick
I recently purchased a 69 tr6. It has turned into a great daily driver except for one problem, the heater. The heater does a terrible job of warming the car and defrosting the windshield. My old Land Rover is far warmer. Granted the soft top doesn’t seal perfectly, but even at low speeds the car never really warms up all that much. The defroster has very weak airflow. The dash vents are better, but the blow only moderately warm air. Just enough to keep it warmer than the outside but not comfortably warm. I checked the heater flap adjustment on the heater box and it appears to be working fine. Next I back flushed the core with a garden hose for 20 mins. This made little to no difference. A new thermostat also had little effect. The heater hoses warm up, but the air in the core just doesn’t seem to take the heat. Is the heater in the tr6 really this poor? Has anyone else had similar problems? Anyway, thanks for your time.
Steven
there could be a couple of things to check. First make sure the cable that operates the heater valve isn't slipping due to a loose screw at the point where it attatches to the valve. Then check to make sure your heater hoses aren't reversed. The worst of all scenarios would be a plugged heater core. Pray it isnt that.
A
A. Salnick
I actaully have the valve wired open. The cable was broken when I got the car. Also, the hoses are for sure plumbed correctly. Is this heater pretty good in most people's tr's?
Rick O.
Well, if both heater hoses are hot, then flow through the core isn't an issue. I bet you haven't closed the dash AND footwell eyeball vents (there are 4 in all). Put the flap control in the "defrost" postion. You should have good flow to the windscreen with the fan on and at-speed with the fan off. If not, there's debris clogging the heater core fins and/or supply ducts to the windscreen. That'll take some effort to disassemble and clear up.
Good luck.
MDCanaday
Rick is dead right on this one, I think derbis and I smell a mouse!! The little bastards love to get into heaters and make nests. Its no fun but you had better clean it out asap, the mouse wastes will corrode the core in time, or even present a fire hazard(there will be chewed wires!)
MD(mad dog)
TR3TR6 TR6 Triumph tr6 heater motor Triumph 3
sundown TR6 1973 TR6 Heater Triumph 1
D TR6 76 TR6 Heater/Blower Switch Triumph 1
B TR6 TR6 Heater core plugged? Triumph 9
W TR6 installing heater hoses '74 tr6 Triumph 1
I TR6 Si sealant for TR6 heater box? Triumph 1
I TR6 TR6 heater blower wires -what are these wires for? Triumph 8
I TR6 TR6 heater removal help please. Triumph 5
Brosky TR6 TR6 Heater Valve - EXPOSED Triumph 9
I TR6 Help with rebuilding TR6 heater system please Triumph 19
I TR6 TR6 heater fire Triumph 15
bigbadbluetr6 TR6 TR6 Heater Triumph 14
hondo402000 TR6 New Heater valve installed from Parts america TR6 Triumph 4
J TR6 Tr6 heater assemblies Triumph 8
bcbennett TR6 TR6 Heater Fan question Triumph 9
WidespreadPanic TR6 Disable Heater on a TR6? Good idea? Triumph 10
I TR6 TR6 heater suggestions Triumph 8
I TR6 TR6 Heater box /air distrbution cable help Triumph 7
2wrench TR6 1974 TR6 heater hoses to firewall or bulkhead. Triumph 12
Brosky TR6 TR6 Heater Case/Core/Motor Repair 101 Triumph 4
O TR6 Pressure testing a TR6 Heater core Triumph 16
T TR6 tr6 heater motor wanted Triumph 13
A TR6 TR6 heater fan conversion?? Triumph 5
A TR6 TR6 heater hoses. Triumph 1
I TR6 69 TR6 heater control cable Triumph 6
V TR6 TR6 Radiator and Heater hoses Triumph 8
RomanH TR6 TR6 Heater function Triumph 12
Brosky TR6 TR6 heater fan switch replacement Triumph 7
AltaKnight TR6 TR6 leaky heater valve Triumph 2
Webb Sledge TR6 TR6 Heater switch Triumph 2
G TR6 Removing heater from my TR6...... Triumph 14
H TR6 tr6 heater motor resistor Triumph 0
jerrybny TR6 Heater Control Plinth Light for 73 TR6 Triumph 1
M TR6 TR6 heater box arm Triumph 4
A TR6 TR6 Heater Control Question Triumph 4
Bill Redd TR6 TR6 heater box Triumph 5
P TR6 72 tr6 heater blower Triumph 2
S TR6 replacement switch for TR6 heater fan Triumph 5
Hawk813 TR6 TR6 Brakes Triumph 2
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
Charlypm For Sale 69 Triumph TR6 Racecar Triumph Classifieds 1
