I have removed both rear fenders and had to use a die grinder to remove several bolts whose captive nuts would rotate. The three captive bolts at he rear vertical part of the fender are not accessible for replacement. The bolts pass through the flange of the rear apron which overlaps the quarter pannel. What approaches could I take to replace these? Is it feasible to remove spot welds and remove the rear apron without distroying it?
Once accessibility is gained, do you weld a nut in place or use the same type of captive cage?
