TR2/3/3A Tr3 trans fix
tinman58
We started at about 8:30 this morning, pulled the trans to replace the front main seal, Remove the seal and ready to install the new one. Wrong one, go back to Napa auto parts get the right one. Put the trans back together reinstall trans in the car. Bleed the clutch fill the trans with gear oil reinstall trans cover, carpet and seats. Done at 3:00 Just as the test drive is a go, the rain started, So just 1 lap around the block. Dry off the TR go in the house for lunch. What a good day!
Good Job Dan! No rain here yet. Seems winter is now starting here and everyone east is seeing Spring. The things we have to put up with living in California.
Paul
for information purposes, can you list the NAPA part number and transmission case number in case others need the seal
thanks
Hondo
I could not find a number on the case of the trans, But it is from a 1982-1985 toyota celica. The Napa part # is 11615 for the front seal and 14753 for the rear seal. When we tried to install the front seal the outer diameter was 5000th to large. Napa counter Guy could not figure out what was wrong. So we went to another auto parts and under national brand the # 1981 fit perfect.
M TR2/3/3A TR3 overdrive trans rear speedi sleeve Triumph 6
doc50 TR2/3/3A TR3 trans issue Triumph 1
doc50 TR2/3/3A TR3 trans issue. Triumph 18
toysrrus TR2/3/3A What Oil goes in your TR3/4 Trans? Triumph 14
K TR4/4A How to check TR3/4A Trans for wear? Triumph 3
K TR2/3/3A TR3 OD Trans & Diff Fluids? Triumph 4
K TR6 TR6 Trans in a TR3...What about clutch? Triumph 1
K Anyone racing A TR3 with TR6 trans? Racing 0
T TR2/3/3A TR3 trans cover to floor gasket Triumph 8
A TR2/3/3A TR3 REAR TRANS SEAL Triumph 6
T TR2/3/3A TR3 [Toyota] trans question Triumph 5
T TR2/3/3A Early TR3/4 trans help needed Triumph 7
K TR4/4A Putting aTR4 motor and trans in a TR3 Triumph 4
K TR2/3/3A What $ to ask for a used TR3 Trans? Triumph 6
M TR2/3/3A Quick TR3 Question .Trans cover color Triumph 6
TR4nut TR2/3/3A Another TR3 trans trivia question.. Triumph 2
TR4nut TR2/3/3A Question on TR3 trans top cover Triumph 9
C TR2/3/3A Motor and Trans Out!!! TR3 shift lever??? Triumph 6
mrv8q TR2/3/3A TR3 Trans Cover gasket Triumph 2
mrv8q TR2/3/3A TR3 Trans tunnel holes Triumph 3
G No directional signals or brake lights on 60 Tr3. Triumph 1
T TR2/3/3A Rear Wheel Bearing instillation on TR3 Triumph 7
RichB4493 TR2/3/3A Rare “TR3” spotted on safari Triumph 3
71TR6 For Sale TR3 Radiator with crank hole- refurbished Triumph Classifieds 3
jfarris For Sale Original Style TR3 Luggage Rack Triumph Classifieds 0
jfarris For Sale TR3 early used fan $25 + shipping Triumph Classifieds 1
71TR6 TR2/3/3A TR3 rear axle shims Triumph 7
IdahoNuke For Sale Free TR3 Seats Triumph Classifieds 0
T Wanted Wanted TR3 rust free nut & bolt restoration Triumph Classifieds 12
R TR2/3/3A 1956 tr3 value? Triumph 7
cguild TR2/3/3A TR3 1991cc engine emits black soot from exhaust Triumph 13
D TR2/3/3A Black TR3 Triumph 20
K TR2/3/3A A TR3 plug check left to right 1234...do I lean out front carb a couple of flats?...turn down correct? Triumph 3
K TR2/3/3A The TR3 is up and running again.... Triumph 7
S TR2/3/3A Battery box for a triumph tr3 Triumph 5
J TR2/3/3A TR3 age Triumph 4
G For Sale TR3 original metal air filters Triumph Classifieds 0
G For Sale 1960 TR3 fitted black cover. Triumph Classifieds 0
S TR2/3/3A tr3 sat all winter Triumph 15
S For Sale FREE - TR3 engine and transmission Triumph Classifieds 5
W TR2/3/3A TR3 Seat Belts Triumph 10
R TR2/3/3A TR3 Timminge Triumph 11
J SOLD!! Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J SOLD!! TR2 TR3 Tie Member Triumph Classifieds 6
S TR2/3/3A tr3 valve spring compressor Triumph 5
