TR2/3/3A TR3 rear fender needed
Kleykamp
Anybody have a left rear fender for a TR3 Post 60K(if it matters). I'm not satisfied with the way mine is straightening out...too much filler. I know this should be in the classifieds, but I don't go there much and don't think anybody else does much either.
I think I have a very nice LR fender, I'll pm you tonight if I stll have it. Freight would be high from AZ though depending on how it's shipped.
SPACER said:
kleykamp,
You brought up an interesting question.
Are the post TS60000 fenders different?
Thanks,
Bob
In a word...<span style="font-weight: bold">NO</span> :smile:
That's a funny question and answer.
Between pre and post TS60K, the rockers, doors, rear inner fenders, rear floor, spare tire compartment, tonneau saddle, rear trunk panel, scuttle, hood and trunk lid are all different, but according to Moss "TR2 from TS1307 - 3B" fenders are the same. If it's not funny that everything but the fenders are different, you have to remember that "the same" doesn't mean "exactly the same" anyway. An 'original' fender may not fit as well as a reproduction.
The fender I have is in great condition without any rust or dents. Yes it may have a few dimples but I did not see any. I started to chemical strip this fender some time back and never finished. Have you ever tried to strip the original primer from original body panels. The only thing I can find wrong with this fender is I removed the nuts from the cages to use on an other fender. You would have to get new square nuts and put them back in the cages and bend the tabs back. PM me if you would like pictures.
I should keep this fender but I have one more in the shed.
Hey, I need a passenger side front fender! Anybody have one? I have a drivers side front to trade? Or I can buy outright.
Jerry
JP
Last I know of is you sending me your email. I emailed pictures and details of the fenders to you on Thursday. I was waiting to hear back from you.
Marv
Try Team Triumph 330 392 7176. I even saw what could be a new original front fender for a Tr3 in his show room. It was in red oxcide primer. It's a British car and bike bone yard and also sells discounted Moss.
Kleykamp TR2/3/3A TR3 rear fender bolts Triumph 2
S TR2/3/3A rear fender vinyl tr3 Triumph 6
luke44 TR2/3/3A TR3 Rear Fender Alignment at Front Edge Triumph 8
mountainman TR2/3/3A TR3 Rear Fender Mounting? Triumph 4
mountainman TR2/3/3A TR3 Rear Fender Bolts Triumph 2
M TR2/3/3A TR3 Rear inner fender dent repair Triumph 8
fad64b TR2/3/3A TR3 rear fender stone-guards Triumph 22
mcguijo TR2/3/3A TR3 rear fender Triumph 15
T TR2/3/3A Rear Wheel Bearing instillation on TR3 Triumph 7
71TR6 TR2/3/3A TR3 rear axle shims Triumph 7
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
Donald1107 TR2/3/3A TR3 Rear Shocks Triumph 11
B Wanted TR3 Hardtop Rear Stiffener Brackets Triumph Classifieds 0
J TR2/3/3A TR3 Rear seat Triumph 11
K For Sale TR3 rear rebound brackets Triumph Classifieds 0
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
K For Sale TR3 rear cockpit center capping Triumph Classifieds 0
J Wanted Need tr3 rear axle housing Triumph Classifieds 0
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
A TR2/3/3A Newbie wrestling with TR3 rear wheel studs Triumph 5
Tinkerman TR2/3/3A TR3 A REAR WING BOLTS order of assembly? Triumph 3
Got_All_4 TR2/3/3A Tr3 rear differential seal Triumph 7
J TR2/3/3A Tramp bar for rear of TR3 or?? Triumph 7
mgedit TR2/3/3A Steady Springs Rear Brakes 56 TR3 Triumph 0
jfarris TR2/3/3A Wanted - TR3 Monza Muffler - Rear Section Only Triumph 1
M TR2/3/3A TR3 overdrive trans rear speedi sleeve Triumph 6
K TR2/3/3A TR3 Exhaust header's proximity to rear of generator? Triumph 4
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
1937dodge TR2/3/3A Anyone have any photos of TR3's sporting rear finned aluminum brake drums? Triumph 8
T TR2/3/3A TR3 Rear wheel cylinder attachment clips Triumph 6
mgedit TR2/3/3A Rear Drum Brakes 56 TR3 Triumph 2
rckuhlman TR2/3/3A TR3 Castle Nut on Right Rear Axle Triumph 3
K TR2/3/3A TR3 4:11 gears in rear Diff Triumph 6
S TR2/3/3A rear brakes tr3 Triumph 1
S TR2/3/3A tr3 rear main Triumph 24
M TR2/3/3A Topping off rear shocks on TR3 Triumph 11
RickAnderson TR2/3/3A Wanted: TR3 Rear Bumper Overrider - any condition. Triumph 2
M TR2/3/3A TR3 rear axle hub gasket ???? Triumph 4
mgedit TR2/3/3A Rear capping 56 TR3 Triumph 4
M TR2/3/3A Topping off rear shocks on TR3 Triumph 13
K TR2/3/3A TR3 rear overider distance from body? Triumph 3
Tr3aguy TR2/3/3A Rear Lettering TR3 post 60000 Triumph 3
luke44 TR2/3/3A TR3 Rear Bumper Overriders - Upside Down? Triumph 12
T TR2/3/3A The light came on: my TR3 rear apron. Triumph 12
S TR2/3/3A tr3 rear interior panels Triumph 6
J TR2/3/3A TR3 Rear Apron Replacement Triumph 4
K TR2/3/3A TR3 Rear Overider Bracket "distance tube"? Triumph 10
J TR2/3/3A stainless steel rear spring pins for TR3 Triumph 19
