Kleykamp
Issue...the front plate on the generator is worn to a oblong slot rather than a hole. It is the lower hole that mounts to the bracket via the spacer. I'm thinking it could be welded up and then redrilled.
Question 1...Anybody tried this
Question 2...would the front plate need to be removed to weld. Seems the electricity/heat generated to weld the hole up would be detrimental to the winding,etc.
If this is not feasible:
Question 3...buy a used generator (core quality) and replace the front plate??
Question 4...how to you hold the pulley from turning when you take the nut off to remove it??? special tools required?
The generator is a working generator but sits at a angle and will not tighten up properly.
Thanks in advance for your help, Joe
