TR2/3/3A TR3 Fuel Injection / Turbo project Latest
newmexTR3
TR3 Fuel Injection / Turbo project up-date
Just got this from Kevin ( who I posted about previously):
and
lookin' nice!
Re: TR3 Fuel Injection / Turbo project up-date
Ok, want to read that thread but it <span style="font-size: 26pt">IS TO BIG!!!</span>!
Is there a way to shrink it down to normal??
Don, if you right click on each image and select "view image" your computer will show it (each image) to you in more manageable size. But you have to do that for each image separately.
This was the nutter that figured he'd get 300 BHP out of the TR engine.
Looks like he is doing nice work, but get back to us with those dyno results when he is finished!
'Tis said nutter. I forwarded him all of the naysayers comments form the list. This is what he said: "Most of the strength needed for a rod is at bottom dead center and top dead center. If done properly the parts will handle it."
I have serious doubts, so we'll see how it turns out.
Neat trick. I learned something today. :yesnod:
Yea, but that only helps the images. Hate to have to slide the page back and forth to read the text. feels like I'm eatin Corn on the Cob.
You can also use your mouse's scrolling wheel (if you have one) .....just hold down the control key keep and rotate the mouse wheel to make things bigger or smaller. I got the pictures to a manageable size but then the text was unreadable. BTW, each image was 2800x2100 pixels which is around 2 MB in size. I take my pictures at 1600x1200 which is around 1 MB but always reduce them to 640x480 or smaller for web or email use. Microsoft makes a cool little free tool called Image Resizer which makes it simple to re-size pictures
<span style="font-size: 26pt">Bobby</span>- Need to call you again about your fuel tank. Many more question. Well, maybe not many , but a few.
LOL! Good one!
Fixed the pics in the original post so they are more manageable.
Thanks. What's the velcro for in the above photo. Port injection, how's he gonna mate the turbo to the intake. Individual runners?
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
D TR2/3/3A tr3 fuel line Triumph 9
K For Sale TR3 Fuel Gauge Triumph Classifieds 8
scottdr TR2/3/3A TR3 Fuel Sending Unit Triumph 3
S TR2/3/3A Not all tr3 fuel pumps are built the same Triumph 5
S TR2/3/3A old tr3 fuel pump Triumph 2
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
S TR2/3/3A TR3 fuel pump Triumph 16
mrv8q TR2/3/3A TR3 Fuel line rubbing Triumph 8
M TR2/3/3A TR3 fuel pump Triumph 14
O TR2/3/3A TR3 Fuel Tanks Triumph 5
PatGalvin TR2/3/3A Late model TR3 Fuel Tank Straps available to a nice home Triumph 0
J TR2/3/3A Fuel pump for a Triumph TR3 or 4? Triumph 2
S TR2/3/3A Bad fuel perhaps water tr3 miss Triumph 0
S TR2/3/3A tr3 fuel delivery system Triumph 18
M TR2/3/3A TR3 fuel cap install question Triumph 9
S TR2/3/3A tr3 metal fuel lines Triumph 1
M TR2/3/3A TR3 fuel sending unit Triumph 25
Kleykamp TR2/3/3A TR3 fuel filter location and type Triumph 7
M TR2/3/3A TR3 fuel line part#104842 Triumph 5
M TR2/3/3A TR3 Fuel tank straps and pads Triumph 13
T TR2/3/3A TR3 weeping at fuel pump, again Triumph 11
J TR2/3/3A TR3 fuel pump question Triumph 7
O TR2/3/3A TR3 Fuel Tank Filler Triumph 3
J TR2/3/3A TR3 Fuel line size Triumph 3
A TR4/4A TR4 FUEL GAUGE CONVERSION FOR A TR3 Triumph 4
K TR2/3/3A TR3 Fuel Gauge Again.....Adjusting? Triumph 11
mgedit TR2/3/3A Seal for TR3 Fuel Tap Triumph 10
B TR2/3/3A 57 TR3 fuel tank vent Triumph 3
S TR2/3/3A Tr3 Fuel line support clips Triumph 4
Gordon_Dedrick TR2/3/3A TR3 Banjo Fuel Fittings Triumph 1
M TR2/3/3A TR3 Fuel line routing Triumph 6
M TR2/3/3A Fuel line missing [ TR3] Triumph 13
PatGalvin TR2/3/3A TR3 Fuel Line - where to buy? Triumph 7
martx-5 TR2/3/3A TR3 Fuel Sender From Moss Triumph 8
mrv8q TR2/3/3A TR3 Fuel line Q Triumph 4
martx-5 TR2/3/3A TR3 Fuel Gauge Triumph 17
jdubois TR2/3/3A What's the deal on the fuel stop tap on the TR3? Triumph 4
K TR2/3/3A TR3 Erratic fuel gauge finally quits....testing? Triumph 4
T TR2/3/3A Visiting the tr3 fuel tank again Triumph 7
RedTR3 TR2/3/3A TR3 Fuel Pump: Mechanical vs. Electric Triumph 14
R TR2/3/3A TR3 Fuel delivery problem Triumph 5
M TR2/3/3A TR3 Fuel Pump rebuild Triumph 2
E TR2/3/3A tr3 fuel pump spacer Triumph 6
M_Pied_Lourd TR2/3/3A TR3 Mech/Elec Fuel Pump Question Triumph 9
M TR2/3/3A TR3 Fuel Pump Check Valves Triumph 7
