TR2/3/3A TR3 Front end..wishbone assembly end float???
karls59tr
Bronze
The manual says:"To give the required end float,tighten the two castellated nuts equally untill the assembly feels solid. Next turn back the nuts betwween 1/2 to 2 flats untill the split pin holes are visible.Lock the nut with a new split pin.This gives the end float of0.0004 0.012 in." How is the end float obtained using lock nuts on trunnion without split pin holes. Thanks in advance for any advice. I think this has been covered before but I cant remember the procedure. Karl
Same procedure, tighten until the pivot binds substantially, then back off both nuts between 1.5 and 2.0 flats (ie between 1/4 and 1/3 revolution). But don't bother to insert the cotter pin :laugh:
BTW, a friend of mine recently reported stripping the nuts, trying to force new "lock" washers onto the splines. I suggest using ordinary hardware store nuts (which are thicker and stronger) to force them on the first time; plus if the trunnions are also new, using a file to 'break' the edge a bit where the splines get formed. But none of this applies if you are reusing the old lock washers (which is what I did).
BillyB62 TR2/3/3A TR3 front end shake Triumph 24
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
O TR2/3/3A TR3 front End Alignment Triumph 8
S TR2/3/3A tr3 front end alignment Triumph 9
H TR2/3/3A TR3 Front End Rebuild -- Tips, Advice? Triumph 17
K TR2/3/3A TR3 front end..mounting wishbone near steering box Triumph 9
K TR2/3/3A TR3 Front End Rebuild Question Triumph 2
prb51 TR2/3/3A TR3 Front end rebuild Triumph 13
M TR2/3/3A TR3 Front End Rebuild Triumph 3
K TR2/3/3A A TR3 plug check left to right 1234...do I lean out front carb a couple of flats?...turn down correct? Triumph 3
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
T TR2/3/3A tr3 front carpet replacement Triumph 5
S For Sale TR3 front nose,trunk & petronix distributor Triumph Classifieds 0
B TR2/3/3A 'A' type Front calipers, TR3 vendor??? Triumph 7
S TR2/3/3A tr3 front apron body work Triumph 9
jfarris TR2/3/3A Front Sway Bar on a 56 TR3 Triumph 13
F Wanted TR3 Front Float Bowl Lid SU H6 Triumph Classifieds 6
T TR2/3/3A Pictures of my TR3 with over riders on front Triumph 14
toysrrus TR2/3/3A "WANTED": TR3 Small Mouth Front Apron Medallian Triumph 14
S TR2/3/3A tr3 front fender Triumph 4
B TR2/3/3A TR3 Front Hub Felt Seal questions Triumph 2
Got_All_4 TR2/3/3A Tr3 front suspension re-bush, what's good out there Triumph 15
sqbsprite TR6 Do the TR3-6 front spring pans interchange? Triumph 6
G TR2/3/3A Front Sway Bar Installation on Wide Mouth 61 TR3 Installation Problem? Triumph 9
charleyf TR2/3/3A Front wheel bearing--inner tr3 Triumph 4
Tinkerman TR2/3/3A 1960 tr3 a petrol tank front millboard question Triumph 6
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
T TR2/3/3A Vent hole in lower front valance of TR3? Triumph 7
luke44 TR2/3/3A TR3 Front Fender Washers? Triumph 19
mgedit TR2/3/3A TR3 Front Banjo Connectors Triumph 2
mgedit TR2/3/3A TR3 Front Banjo Connectors Triumph 7
T TR2/3/3A TR3 front license plate Triumph 4
mgedit TR2/3/3A Front Drum Brakes 56 TR3 Triumph 2
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
BillyB62 TR2/3/3A Front Float Cover Lid for TR3 H6 Carb Triumph 10
AHS TR2/3/3A Which way does the TR3 front crankshaft oil seal face? Triumph 8
Kleykamp TR2/3/3A TR3 Front Emblem??? Triumph 7
J TR2/3/3A TR2 - earlyTR3 front brake hose length and photo? Triumph 1
Scotsman TR2/3/3A tr3 front wheel hub stud removal Triumph 2
Tr3aguy TR2/3/3A TR3 Front suspension breakdown..Help Triumph 2
JFeher TR2/3/3A TR3 Type "A" front brake caliper rebuilding Triumph 17
AEW TR2/3/3A TR3 engine front cover repair Triumph 10
B TR2/3/3A Fitting the front wing 57 TR3 Triumph 2
B TR2/3/3A Installing front fenders on TR3 from TRF Triumph 12
Kleykamp TR2/3/3A TR3 Front Suspension rebuild????? Triumph 12
