TR2/3/3A TR3 Brake drums on a 1956?
TR3driver
Great Pumpkin - R.I.P
Yes.
Sorry, couldn't help it. All 56 TR3 should have 10" drums, some all-round and some just on the rear. The rear brakes changed from 9 to 10 in 55, and back to 9 in 59.
2long
Weren't the front drums always 10 inch, with the back drums vacillating from 9 to 10 and then back to 9?
Dan
Don Elliott
My 1958 TR3A came new with 10" drums on the rear and disks up front. All are still on the TR with almost 200,000 miles on it.
TR3driver
Yes, that's right. Sorry I wasn't clear.
1937dodge TR2/3/3A Anyone have any photos of TR3's sporting rear finned aluminum brake drums? Triumph 8
K TR2/3/3A TR3 10" Brake Drums? Triumph 10
af3683 TR2/3/3A Original Paint on TR3 Brake Drums Triumph 1
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
K TR2/3/3A TR3 Brake MC pushrod? Triumph 0
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
S TR2/3/3A brake reservoir on a tr3 Triumph 8
A TR2/3/3A TR3 Brake / Clutch Resevior & Lines needed Triumph 2
K TR2/3/3A TR3 brake fluid reservoir outlet at the bottom..... Triumph 0
T TR2/3/3A One Person TR3 Brake Bleeding Option? Triumph 11
mgedit TR2/3/3A Brake Light Switch 56 TR3 Triumph 3
T TR2/3/3A What is thread size on TR3 brake light switch? Triumph 5
mgedit TR2/3/3A Brake Line Master to Banjo Connection LHD 56 TR3 Triumph 4
mgedit TR2/3/3A Routing of Clutch and Brake Pipes from MC 56 TR3 Triumph 7
mgedit TR2/3/3A Source for Brake Pipe 56 TR3 Triumph 9
JFeher TR2/3/3A TR3 Type "A" front brake caliper rebuilding Triumph 17
D TR2/3/3A TR3 brake rotor question Triumph 4
J TR2/3/3A Brake line advice for my TR3 Triumph 5
L TR2/3/3A TR3 Brake Rotor Thickness Triumph 18
T TR2/3/3A tr3 brake/clutch reservior question Triumph 1
K TR2/3/3A TR3 Brake & Master Cyl "C" clips? Triumph 2
K TR2/3/3A Generic TR3 Brake Light Switch? Triumph 3
K TR2/3/3A TR3 Brake Proportioning Valve? Triumph 2
S TR2/3/3A rear brake lines tr3 Triumph 3
C TR2/3/3A TR3 Brake pads interchangeable? Triumph 1
mgedit TR2/3/3A 56 TR3 Clutch/Brake Pedals Triumph 4
Got_All_4 TR2/3/3A TR3 E brake problems Triumph 19
Got_All_4 TR2/3/3A What's wrong with this brake fluid? TR3 Triumph 19
S TR2/3/3A Should TR3 rear brake slave cylinders move? Triumph 4
K TR2/3/3A Installing Brake Switch TR3? Triumph 6
B TR2/3/3A TR3 brake restrictor valve Triumph 6
J TR2/3/3A TR3 Lockheed brake/clutch MC bracket... Triumph 11
K TR2/3/3A TR3 Rear Brake back plate... Triumph 2
K TR2/3/3A TR3: diff oil on the rear brake shoes... Triumph 4
J TR2/3/3A tr3 hydraulic brake light switch Triumph 13
K TR2/3/3A TR3 rear brake adjuster seized? Triumph 10
T TR2/3/3A tr3 rear brake band installation question Triumph 7
S TR2/3/3A tr3 e-brake handle Triumph 4
T TR2/3/3A TR3 front brake line routing Triumph 3
S TR2/3/3A tr3 brake restrictor Triumph 14
NutmegCT TR2/3/3A TR3 brake [?] squeak Triumph 14
T TR4/4A Toyota brake conversion for TR3 or TR4a Triumph 7
S TR2/3/3A brake lines and rubber bumpers tr3 Triumph 12
Moseso TR2/3/3A TR3 Brake/Turn Lighting Improvement Discussion Triumph 12
mountainman TR2/3/3A TR3 Rear Brake Position Triumph 11
T TR2/3/3A Tr3 brake calipers Triumph 3
CraigLandrum TR2/3/3A TR3 front disk brake squeal cause? Triumph 11
