TR2/3/3A Time to replace the exhaust header wrap....
karls59tr
Bronze
Anyone know if 5 feet in length is enough to do the job? Are they all pretty much the same or is there one product that is better than the others? (not going the ceramic coating route).
Not sure what you mean by manifold wrap. Anything that impairs heat exchange with ambient air seems like a bad idea.
Bob
Bob
I was referring to the "exhaust header down pipes" that some people replace the stock down pipes with. They are wrapped with a heat treated wrap to lower the under hood temperature.
A MGB MGB exhaust replace MG 8
N Before I replace my exhaust.... Austin Healey 3
AngliaGT '97 Miata - Need to Replace the EGR valve - recommendations? Other Cars 7
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
V MGB Replace late intake manifold angled breather with early model straight? MG 1
W replace rigid master cylinder lines with flex. Spridgets 2
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
B A plan to replace BE floor pans Spridgets 0
nichola TR6 Rebuilder or replace wiper switch? Triumph 7
R TR2/3/3A Replace wiring harness in steering column Triumph 61
mrv8q TR2/3/3A Brake master cylinder: rebuild or replace? Triumph 9
R TR4/4A Master Cylinder Corrosion Do I replace? Triumph 4
J TR2/3/3A replace brake and fuel lines? Triumph 4
J TR2/3/3A Replace rusty sills? Triumph 10
NutmegCT Brake fluid - flush and replace. Why? Restoration & Tools 8
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
JPSmit replace shocks in pairs? Spridgets 7
JPSmit When do you replace things? Restoration & Tools 22
wangdango BN2 wheel cylinders/rebuild/replace? Austin Healey 3
AUSMHLY When to replace spark plugs Austin Healey 1
drooartz MGB What to replace when engine is out MG 10
71TR6 TR2/3/3A Inner sill or floor pan- which to replace first? Triumph 5
G TR2/3/3A Hydraulic supply lines from reservoir..replace with flexible Triumph 19
AHS BJ8 blower motor switch - how to replace? Austin Healey 1
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 4
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 15
TRMark TR4/4A Replace Water Curtain Triumph 5
H Bugeye fuel tank sending unit - repair or replace Spridgets 5
John_Mc TR6 Rebuild or replace Clutch Master Cylinder? Triumph 8
S Replace original suspension for shocks? Austin Healey 2
J Replace the outside skin on a cargo trailer??? Restoration & Tools 0
drooartz MGB Good people go to heaven, bad people replace MGB clutch hydraulics MG 2
7 How to replace door windows on a 77 MG Midget Spridgets 6
AngliaGT '74 Midget - Best way to Replace Brake Line? Spridgets 1
S Replace seal and dust cap BJ8 steering box. Austin Healey 23
gbtr6 TR6 TR 6 Head Studs, replace? Triumph 3
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
J TR2/3/3A What is the best way to remove and replace carb shaft bushings. Triumph 4
B Radiator - repair or replace? Pics attached Austin Healey 20
Lukens TR2/3/3A Water pump bearings making noise... time to replace Triumph 9
mailbox General Tech Fix, replace or rewire? Triumph 8
Kleykamp TR2/3/3A '61 TR3 Horns repair vs replace Triumph 15
drooartz MGB-GT Any gotchas when remove/replace rear axle? MG 4
britlover proper tire size to replace 5.90-15? Austin Healey 16
Rob Glasgow Replace clutch disk? Austin Healey 8
S TR4/4A Replace or rebuild heater control valve? Triumph 5
