SuperPro trunnion bushings
Upland
Member
I have been rebuilding the front suspension on my Mk IV. New pans, fulcrum pins, hardware and SuperPro bushings. I have an issue with the trunnion bushings. The SuperPro bushings come with 2 washers, when I put the washers in the the cut out in the fulcrum pin will not line up with the shock arm set bolt hole. The set pin can not go in. If I remove the washers it fits just fine. Question, if I extend the fulcrum pin cut out by approximately .25” the set bolt goes through the cut out and into the shock just fine. Which is the better choice? Have the washers on the ends of the bushings, (the original rubber bushings have metal washer/top hats) or no washers and not have to extend the cut out in the fulcrum pin. Your thoughts will be very appreciated.
Upland
C TR4/4A SuperPro Front Spring Packing Triumph 7
Got_All_4 General TR Anyone running superpro bushings? Triumph 3
R TR6 TR6 Trunnion Setup Triumph 5
R TR6 Lower A-arm trunnion bushings Triumph 18
pkmh BJ8: Upper Trunnion Rebuild [Of Continuum] Austin Healey 9
J Top Trunnion Bushing Fit Austin Healey 9
F TR2/3/3A Trunnion bolts Triumph 11
warwick-steve Front suspension rubber trunnion bearing question Austin Healey 4
J TR2/3/3A Trunnion Install Triumph 3
D TR6 Rusted Trunnion Pivot Bolt Triumph 18
G TR4/4A Well...another stripped trunnion Triumph 8
Scotsman TR4/4A Steering Stop Lock on trunnion Triumph 9
B TR2/3/3A Dimensional discrepancy in Moss trunnion parts Triumph 0
B TR2/3/3A trunnion bush clearance Triumph 2
GTP1960 TR2/3/3A Re-tapping a zerk in a brass trunnion housing? Triumph 17
C TR5/TR250 Trunnion Installation Triumph 3
maxwedge5281 adjustable trunnion Austin Healey 15
B TR2/3/3A Removing front trunnion Triumph 15
M TR4/4A TR4A - Torque the Front Suspension Trunnion Bolt! Triumph 5
Got_All_4 TR2/3/3A Reaming trunnion bushings Triumph 4
doc50 TR2/3/3A Trunnion seal Triumph 1
M_Pied_Lourd TR2/3/3A Verticle Link to Trunnion Fitment Triumph 5
catfood Top trunnion pin removal. Austin Healey 4
S TR2/3/3A bottom out the trunnion Triumph 7
gubba TR4/4A Lower Trunnion question Triumph 8
S TR2/3/3A trunnion drama Triumph 2
S TR6 Trunnion lube Triumph 6
Gerry M TR6 Trunnion oiling Triumph 7
B Top Trunnion Bearing Kit Austin Healey 6
K TR2/3/3A Trunnion replacement done....Thanks to Forum Triumph 3
K TR2/3/3A Trunnion spindle conundrum again? Triumph 2
K TR2/3/3A Randall....another trunnion spindle issue? Triumph 5
K TR2/3/3A Trunnion spindle cotter pin hole non existent! Triumph 9
K TR2/3/3A Front end reassembly: trunnion spindles and wishbone bushes??? Triumph 10
K TR2/3/3A Trunnion oil/grease again? Triumph 1
trrdster2000 Trunnion torque. Triumph 16
R BJ8 Top Trunnion removal Austin Healey 8
H top trunnion too tight Austin Healey 3
kurts100 TR6 TR6 Trunnion/Lower A-Arm Bolt--Torque or End Float Triumph 8
K TR2/3/3A TR3 Trunnion Question Triumph 2
Willie_P TR2/3/3A Trunnion Installation - TR3/4 Triumph 7
doughairfield Trunnion question Triumph 27
A TR2/3/3A TR3 Trunnion - vertical link play Triumph 10
M TR6 TR6 Trunnion Bolt Removal Triumph 3
J Trunnion Oiler Triumph 5
ekamm TR2/3/3A tr3 trunnion bushing help Triumph 2
Jim_Gruber Refitting trunnion and .008" Spacers Spridgets 30
ekamm TR2/3/3A Tr3 trunnion Triumph 8
F Trunnion Oiler Triumph 23
Bremer Trunnion pin diameter Triumph 3
