Strange Noise While Cornering in TR6
SherpaPilot
At a recent autocross event, My 72 TR6 developed a thumping noise which appeared in the area of the transmission tunnel. This noise only appears during hard cornering, especially to the right and will stop when the weight is transferred back to neutral. I suspect the driveshaft universal joint is striking the metal tunnel but cannot find any evidence of contact. Additionally I have jacked the car up on the right side transferring weight to the left side in an effort to duplicate the cornering. There is no evidence of universal joint contact. Has anyone experienced this sort of noise before? Thanks for any input or experience you might have. I might add, this car has mild upgrades in the form of Addco anti-sway bars, Goodparts rear camber adjustment link, Koni shocks, prothane bushings and Panasport wheels. None of these parts show any contact during cornering.
I had the same problem years ago on an MG TD. No obvious signs of hitting. I think I levered something to stop the noise. It was many years ago and my memory may be failing as to exactly what I did but you might try bending the driveshaft tunnel on the passenger side since that's where it's probably hitting.
Yes, I agree and hope to further investigate this problem next week. I am running heavy duty universal joints which may very well be making ever so slight contact when the body rolls. Thanks for the reply.
Check the rubber mounts for the tranny, they are not real strong. Might be old enough to let the tranny shift and let the u-joint knock on frame or tunnel.
nicko Strange Engine Noise Austin Healey 7
F TR2/3/3A Strange Loud Noise Triumph 11
bighealeysource Okay, here's one with a strange noise from the engine Austin Healey 7
P Strange clunking noise Triumph 20
bugedd Strange trans noise Spridgets 7
JAV strange noise Austin Healey 4
G Strange Engine Noise...? Austin Healey 20
M Strange noise in first gear Spridgets 2
G Early 2.6 strange engine noise... Austin Healey 3
D Strange clutch noise Triumph 3
G Strange noise Triumph 3
J Help! Strange Noise Jaguar 3
JCL TR4 TR4/4A Strange Problem Fitting Inner Fender Triumph 18
E TR6 Strange Steering Rack Cap Triumph 3
Vargus TR2/3/3A Strange dents Triumph 19
jlaird MGB Strange daily question. MG 10
C MGB strange?? MG 3
J TR2/3/3A such strange thread on gear shift knob Triumph 12
7 Strange A/C - radio problem Other Cars 7
S TR2/3/3A Strange part Triumph 3
steveg Strange gasket pieces Austin Healey 5
steveg Strange Oil Leak Austin Healey 7
D TR2/3/3A Strange hole! Triumph 5
Jim_Gruber Strange noises - Bad U Joint perhaps? Spridgets 10
Michael Oritt Strange debris found in sump Austin Healey 19
C Strange...can won't start and then magically ressurects Austin Healey 16
bighealeysource Strange problem with throttle staying open Austin Healey 6
D TR2/3/3A Strange Transmission Issue Triumph 9
Rhodyspit75 Strange windshield washers Spridgets 0
tahoe healey strange OD question. Austin Healey 9
andrea Very strange austin healey 3.9 Austin Healey 5
M Strange Healey Tach Austin Healey 9
Rut Strange occurance! Spridgets 19
aeronca65t Big Healey-strange wheels Austin Healey 12
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
J TR4/4A Strange question that may involve the coil- Triumph 13
jlaird Todays strange question Spridgets 6
JPSmit What is that strange grinding sound in the distance? Spridgets 3
PAUL161 MGB Strange Reminder of a Missing Friend. MG 4
B Strange rear light Other British Cars 6
KVH Strange Sound Like Compressed Air Escaping Triumph 14
Bremer TR2/3/3A TR3A: Strange brake bleeding behaviour Triumph 4
B SU Carbs have strange vacuum fitting Triumph 17
Kleykamp TR2/3/3A Strange TR3 side curtains ??? Triumph 13
HAN8L1965 Strange event ? Spridgets 6
T strange litter Triumph 5
aeronca65t Strange and interesting MGs MG 3
PAUL161 Strange 5 Speed Conversion - Will it Work? MG 41
W Strange occurence Spridgets 5
Musicman Strange Clicky/Tappy Sound Triumph 6
