    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Strange clutch noise
desmo900rider
Member
When I press in the clutch on my 79 Spitfire, it makes a strange kind of grinding, or fast clunking noise, but only on about the 1st inch or so of travel...the clutch was just replaced last year, and otherwise works fine, shifts smoothy, and after the 1st inch of depression, the noise dissapears...if I just sit at idle and press the clutch pedal in a bit, like just start to put the first bit of pressure on it, thats where it happens...almost like a rattle? I do have a broken engine mount that I will be replacing this week, not sure if that could be causing any weird vibrations...
Anybody heard of this?
Thanks!
Mike
Offhand, I'd say you might have a (minor?) problem with the throwout bearing. I would certainly continue to monitor the situation and be prepared to pull the gearbox if it gets worse. At the same time, it's surprising what broken motor mounts can cause; same thing with the rear gearbox mounts (harder to both see and get to but also worth checking).
Sounds like it very well may be the broken motor mount is the culprit...Hopefully when the new ones get put in it will settle down the vibrations through the clutch...
2 clutch pedal strange Triumph 4
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
E TR6 Strange Steering Rack Cap Triumph 3
Vargus TR2/3/3A Strange dents Triumph 19
nicko Strange Engine Noise Austin Healey 7
jlaird MGB Strange daily question. MG 10
C MGB strange?? MG 3
J TR2/3/3A such strange thread on gear shift knob Triumph 12
7 Strange A/C - radio problem Other Cars 7
S TR2/3/3A Strange part Triumph 3
steveg Strange gasket pieces Austin Healey 5
steveg Strange Oil Leak Austin Healey 7
D TR2/3/3A Strange hole! Triumph 5
SherpaPilot Strange Noise While Cornering in TR6 Racing 3
Jim_Gruber Strange noises - Bad U Joint perhaps? Spridgets 10
Michael Oritt Strange debris found in sump Austin Healey 19
F TR2/3/3A Strange Loud Noise Triumph 11
C Strange...can won't start and then magically ressurects Austin Healey 16
bighealeysource Strange problem with throttle staying open Austin Healey 6
D TR2/3/3A Strange Transmission Issue Triumph 9
Rhodyspit75 Strange windshield washers Spridgets 0
tahoe healey strange OD question. Austin Healey 9
andrea Very strange austin healey 3.9 Austin Healey 5
M Strange Healey Tach Austin Healey 9
Rut Strange occurance! Spridgets 19
aeronca65t Big Healey-strange wheels Austin Healey 12
bighealeysource Okay, here's one with a strange noise from the engine Austin Healey 7
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
J TR4/4A Strange question that may involve the coil- Triumph 13
jlaird Todays strange question Spridgets 6
JPSmit What is that strange grinding sound in the distance? Spridgets 3
PAUL161 MGB Strange Reminder of a Missing Friend. MG 4
B Strange rear light Other British Cars 6
KVH Strange Sound Like Compressed Air Escaping Triumph 14
Bremer TR2/3/3A TR3A: Strange brake bleeding behaviour Triumph 4
B SU Carbs have strange vacuum fitting Triumph 17
Kleykamp TR2/3/3A Strange TR3 side curtains ??? Triumph 13
HAN8L1965 Strange event ? Spridgets 6
T strange litter Triumph 5
aeronca65t Strange and interesting MGs MG 3
PAUL161 Strange 5 Speed Conversion - Will it Work? MG 41
W Strange occurence Spridgets 5
P Strange clunking noise Triumph 20
bugedd Strange trans noise Spridgets 7
Musicman Strange Clicky/Tappy Sound Triumph 6
SilentUnicorn Strange things British Motorbikes 4
Bremer Strange, but interesting... factory blunders? Triumph 8
M another strange bugeye on ebay Spridgets 12
JAV strange noise Austin Healey 4
J Strange electric problem. Jaguar 11
