TR6 steering column removal bushing replace
robert52
hello everyone I am a new member and a total luddite when it comes to computers so here is my question. I am in the process of replacing steering column bushings and rubber coupling. I have coupling off, no problem . steering wheel off ,tach and speedo removed I cant figure out how to get the column out, steering lock is out and I can slide column almost all the way out either towards cab or forward but something is stopping it. I am afraid to force anything . any help is greatly appreciated.
Welcome, Robert !
Have you been following the procedure in a manual ?
If so is there a step after which you can no longer progress ?
have several manuals but none specifically addressed my issue. However I got it out. it was hanging on the old bushings that were still in the housing. There is a fat spot on the steering shaft that will not allow it to pass thru with the bushing in place, all I have to do is reassemble with reverse procedure in mind. Thanks for the reply, great site, Im sure I will make good use of the info
K TR2/3/3A TR-3 steering column worm gear removal. Triumph 4
N PLEASE HELP! - Midget steering column removal? Spridgets 7
S TR2/3/3A TR3A steering column- one piece column removal? Triumph 4
J Steering Column Bushing Removal Triumph 4
B Steering Box & Column Removal Austin Healey 7
B Steering Column/box Removal & Rebuild Austin Healey 4
S TR6 Bent Steering Column Triumph 12
olarson TR2/3/3A Steering Column Bracket Triumph 2
M Midget steering column Spridgets 3
B Steering Column Wiring/Sealing Austin Healey 1
Walter74 Steering Column Felt Bushing Austin Healey 3
D Steering Column Adjustment Collet Austin Healey 8
Retired2020 TR250 steering column bushing Triumph 2
ActionJackson Spitfire Steering Column Lock Triumph 3
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
R TR2/3/3A Replace wiring harness in steering column Triumph 61
R TR2/3/3A Install new wiring harness in steering column Triumph 16
R TR2/3/3A Steering Column Wiring Triumph 18
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
R TR2/3/3A Wiring from the steering column Triumph 7
M TR6 EZ Power Assisted Steering Column Fitment Triumph 3
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
D TR6 Replacing Horn insert in steering column Triumph 11
L TR2/3/3A Upper steering column bushing Triumph 8
BoyRacer Steering Wheel Location with non-adjusable column Austin Healey 6
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
steveg Steering column steady brace and scuttle shake? Austin Healey 2
T TR2/3/3A Is there a Delrin bush available for the top of TR3 steering column instead of felt? Triumph 8
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
T Steering Column Installation Spridgets 6
C Non-Adjustable steering column questions Austin Healey 14
BoyRacer Steering Column Height Adjustment on BN2 Austin Healey 1
SherpaPilot TR6 Steering Column Loose Triumph 8
John_Mc TR6 Steering column rubbler coupler Triumph 8
R TR2/3/3A Installing wiring harness in steering column Triumph 59
B Steering Column Bushing Austin Healey 2
S TR2/3/3A steering column through the body tub Triumph 5
S TR2/3/3A steering bracket that fits under the dash for the end of the column Triumph 2
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
G Steering Column Mounting Austin Healey 1
60BN7 Adjustable Steering Column Won't Lock Austin Healey 9
B Outer steering column connection to the steering box Austin Healey 6
D TR2/3/3A steering column bushings Triumph 8
M TR4/4A Triumph TR4/4A Steering Column spline size Triumph 1
D BT7 adjustable steering column / steering wheel Austin Healey 1
G TR2/3/3A Steering Column Support for One-Piece Steering Column Triumph 3
adcronin For Sale MGB New Turn Signal Switches: 62-67 and 68-70 Also 70-73 MBB Steering column cover MG Classifieds 0
rjc157 TR6 steering column Triumph 0
S TR6 steering column bushings Triumph 5
Marvin Gruber BJ8 steering column blanking plate seal Austin Healey 1
