Starter Solenoid Nut Size for BJ8
SimsBJ8
Member
Could someone please provide a description (size and thread) for the nut on the starter solenoid for the cable going to the starter on a BJ8? I believe it is part # AJD 8019 Z.
Thanks in advance.
Bob
Probably 1/4ā€ whitworth or an equivalent metric .
R TR6 Starter Solenoid Conection Triumph 11
S TR2/3/3A Starter or Solenoid Triumph 13
ckeithjordan TR2/3/3A Starter Solenoid Triumph 3
K TR2/3/3A Starter,Solenoid, Ignition Switch Issue? Triumph 5
NutmegCT Failing starter solenoid? Restoration & Tools 15
S Wedge TR8 starter solenoid details? Triumph 3
Crankshaft TR2/3/3A Starter Solenoid Question Triumph 13
Perrymip TR2/3/3A Starter Solenoid Push Button Triumph 11
P Bugeye starter solenoid??? Spridgets 2
A TR6 Starter solenoid Triumph 3
H Starter Solenoid Positon Triumph 3
S TR6 TR6 Starter/solenoid Clicking Triumph 1
Mychael Location for pull starter solenoid. Spridgets 11
The_architect Bugeye battery / solenoid / starter cable lengths Spridgets 7
B Solenoid to starter cable on my 57 Triumph 6
Stinger TR4/4A TR4A Starter Solenoid Connector Triumph 2
doates Spitfire Spitfire Starter Solenoid Triumph 2
M Replacing the starter solenoid Triumph 16
Tr4dude TR6 Tr6 starter solenoid Triumph 4
S TR2/3/3A tr3 solenoid to the starter Triumph 6
RJS Starter Solenoid Issues Triumph 3
KVH More Battery/Starter/Solenoid Woes Triumph 14
KVH TR4/4A TR4 Starter and Solenoid Issue Triumph 19
K TR2/3/3A TR3 Starter Solenoid Test...Out of vehicle?? Triumph 3
bigbadbluetr6 TR6 TR6 Starter Solenoid Triumph 3
Lin starter solenoid problem Austin Healey 3
Dudly Spitfire setting up starter solenoid 79 Spit Triumph 11
Dadandson Starter Solenoid Alternative Spridgets 3
mjobrien Wiring Question on Starter Solenoid. Austin Healey 2
J BJ8, PH I Starter Solenoid, I Think? Austin Healey 12
T Smoke from Starter Solenoid Spridgets 9
G Blue and black wire near starter solenoid Triumph 2
Jim_Gruber Starting Question / Solenoid / Wiring / Starter Spridgets 1
W Aftermarket starter solenoid? Triumph 9
A Wiring connections for starter solenoid Spridgets 1
J starter-solenoid issues? Triumph 12
A Starter Solenoid Question - Push vs. Non-Push Austin Healey 4
Frank C. Starter Solenoid Austin Healey 3
Hegg Starter Solenoid Buzzes when trying to start Triumph 2
K TR2/3/3A Hi Torque Starter...... Triumph 4
M MGB 1967 MGB starter conversion MG 9
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 10
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ā€˜74 TR6 original starter Triumph Classifieds 0
