Standard Herald [India]
Sherlock
I'm not sure how many of you aware of the manufacturing of Triumph sedans in India, one of my Flickr contacts from India just posted some photos of a "Standard" Herald he owns, you can see the slight differences between the Triumph Herald...
More photos of interesting classic cars in India from the same person, including some of the cars that are unique to India... https://www.flickr.com/photos/indiaclassics/
The Ambassador and the Hindustan were known as Morris Cowley's in the UK.I believe that BMC sent the tooling to assemble Morris cars in India. You will also see the smaller Morris Oxford doing sterling service as taxis in most Indian cities.India also makes Royal Enfield motor bikes.
Stuart. /ubbthreads/images/graemlins/cheers.gif
I would be extremely interested in knowing more about this particular car and its owner, as I also have a number of Indian contacts with interest in and ownership of Standard Heralds and related STAMPRO cars. Feel free to "PM" me here (or send e-mail to me; I think you probably still have my e-mail addresses).
I am guessing that this is a fairly early Standard Herald, possibly 1963 or so, and still based largely on CKD kits from the UK. But hard to say for sure. One thing is for sure, though: it was not originally a convertible!
And yes, that is the same "shield" badge found on Triumphs. Both Triumph and parent company Standard used that shield style of badge, red and black until about 1958, then blue and white. The version used on the Herald (as pictured) had no wording, so it could easily be used on either a Triumph or Standard (Heralds were always badged under the Standard name in India).
The ones I love are the Royal Enfield Diesel bikes. Who knows an LBC might be able to out drag on of those
M Wanted Standard 10 sunvisors Other British Classifieds 0
M Wanted Standard 10 sunvisors Triumph Classifieds 0
S Wanted 1949 standard vanguard Other British Classifieds 0
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
HalLucy Standard Vanguard Sportsman engine and the TR3 Other British Cars 7
M TR2/3/3A Standard Engine Trust Washer Thickness Triumph 18
S General Tech Standard for the Girling Bubble Flare Triumph 15
T Wanted Workshop manual for Triumph 10 [Standard 10] Triumph Classifieds 4
Mickey Richaud General TR Standard 10 Pickup! Triumph 3
T 1933 Standard Little Nine Carburetor Other British Cars 8
NutmegCT 1951 Standard Vanguard Other British Cars 3
Lbp TR2/3/3A TR3A - Converting Adjustable Steering Wheel to Standard? Triumph 16
Tim Tucker TR2/3/3A TR2-4 86mm standard rings Triumph 10
RickB standard size lug studs for 78 Midget? Spridgets 3
C Triumph Standard Flying 8 Triumph 5
M Thak you and Metric or standard.... ? Austin Healey 5
B TR4/4A Adding OD to Standard TR4 Gearbox Triumph 18
rlich8 Standard-Triumph Engine Package Diagram Triumph 4
K Early 50's Standard Triumph 1/2 Ton? Triumph 8
wangdango Vandervell bearings for 100M, standard, main Austin Healey 3
bighealeysource Pertronix coil verus standard Lucas coil Austin Healey 3
QuickSilver Technical: Converting From Wire Wheel To Standard MG 6
kurts100 Bugeye Lever Shocks/Standard or Heavy Duty Rebuild Spridgets 14
hilsideser Standard 10 in S.C. on Craig's list for $300 Triumph 20
K TR2/3/3A Standard Continental Touring Kit for TR3 on EbayUK Triumph 0
TR4nut Standard Triumph Gray Colors for Russ.. Triumph 15
K 1950 Standard Vanguard Other British Cars 2
T Neat project - Triumph Standard 10 Triumph 11
Ohiobugeye Metric or US Standard Threads? Spridgets 26
Wirewheels Did the BJ7 come with OD standard? Austin Healey 11
germanmichel Standard clearance mainshaft of the transmission ? Austin Healey 3
W TR10 / Standard Axle for Lotus Triumph 10
pakiwi 1275 Cam Specs - Standard Spridgets 1
PeterK standard-triumph hardware catalog Triumph 7
MadRiver TR6 Standard TR6 Tires? Triumph 2
ncbugeye Tyres for standard Bugeye rims Spridgets 1
G Standard Vanguard Paint Code Other British Cars 4
Alan_Myers If I had room, time, $! FS: '47 Standard Flying 14 Triumph 2
A MGB How much Torque can a standard MGB gearbox handle? MG 5
bobh A Radical Idea? Or An Old Standard? Triumph 11
gsalt57tr3 1953 Standard Vanguard Phase II Other British Cars 0
gsalt57tr3 Standard Vanguard Triumph 2
gsalt57tr3 Standard Vangard in St. Louis MO Triumph 2
Webb Sledge David Vizard: Tuning Standard Triumphs Triumph 2
Sherlock History question - Standard-Triumph of Belgium Triumph 3
R air shocks vs.standard type? Triumph 3
Webb Sledge Tuning Standard Triumphs Triumph 0
4 1947 Standard Flying 14 Info Other British Cars 5
UltimateQuestion Standard-Triumph T-10 Triumph 10
S Standard Triumph publications list source wanted Triumph 0
