    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
TR4/4A Stainless Steel exhaust on a TR4A
Carlos
Member
I am looking to replace the one-muffler exhaust on my 67 TR4A. What fitting issues are there with the Falcon system?
Should I look for some other brand instead?
Rusticus
Carlos, which Falcon system are you replacing your current with? The TR4A single, the TR4A dual, or one of the TR6 systems?
G
Carlos,
The Falcon stainless steel system in the stock configuration
is a good choice and should present no particular fitting problems.
The only time you will run into any difficulties in installing a Falcon system is when you try and change over to a dual system, where clearance for the mufflers is always an issue. A friend has a really nicely restored TR4A that he fitted with the Falcon system in the stock configuration and he is tickled pink.
It will be the last exhaust system you should ever have to install.
Bill
Carlos
Carlos
Member
I am replacing a single-muffler system with a single-muffler system. If there are no fitting problems, I'll do the work myself.
There is an outfit called Engel Imports at https://www.engelimports.com/ who sells on ebay as britishpartsplace who has a system for $330 plus shipping. They require 6-8 weeks to import the system from England, and don't know what brand it is. I have asked for his shipping cost.
Anyone have experience with this seller?
Alan_Myers
Hi Carlos,
I installed the Falcon "Sport" system and header on my TR4. Not the same setup you are asking about, but perhaps I can give you some general feedback.
Overall I found all the pieces to be pretty well made and easy to fit (the body was off the frame at the time, which *really* makes fitting easy!). The Falcon "Sport" system was designed to use all the stock hanging methods on the car and fitted up well to those. I would be pretty certain the same would be true of a stock-style system.
My only clearance issue has to do with the fully boxed frame on my TR4, and isn't the fault of the exhaust system. The mods to the frame make for a very tight fit right at the collector, next to the gearbox. Next time the body is off the frame, I'll likely make some minor changes to better accomodate the exhaust system. Those will be either changes to the frame or installing a flex-pipe in the exhaust (which is a good idea anyway), or both.
My only relatively minor gripe about the Falcon "Sport" stainless steel exhaust is that the pipes aren't mandrel bent (all the header primaries are). So, there is a bit of "crushing" on the inside curve at the bends. I would prefer mandrel bends throughout.
The car is not back on the road yet, so I can't report how I like the performance and sound of the system.
Before committing to a ready-made kit like this again, I'd seriously consider working with a local exhaust fabricator. That would give me a lot more control over the exact specification of the system and I don't think the cost would be much different. It might be well worth your looking into this and getting a quote locally, particularly since you aren't planning any modifications. A good, local muffler shop that can handle stainless steel could simply use your old system as a guide to fabricate a new setup.
A couple suggestions:
You might want to consider going just slightly larger on the piping, say to 2" or 2.125" inside diameter. The stock pipes (ID 1.75" or 1.875" if I recall correctly) are a bit restrictive and this minor change can give a nice bump in performance even with the stock manifold (which is really pretty good on the 4A).
Finally, careful port matching between the manifold and the head is a good idea, too, and would only involve internal changes that keep the car's stock appearance. This includes checking that the replacement gaskets match up well.
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
B Stainless Steel Exhaust System Wanted Austin Healey 5
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
I Stainless steel exhaust. Austin Healey 5
DornTRoriginal TR2/3/3A Stainless Steel Exhaust Installation Triumph 4
Rob Glasgow Tourist Torphy Stainless Steel Exhaust Systems Austin Healey 27
Jeepster Mixing stainless and mild steel exhaust Austin Healey 5
60TR3A What's The Recommended Stainless Steel Exhaust for '63 BJ7? Austin Healey 5
C BJ8 Stainless Steel Exhaust - throaty sound ? Austin Healey 4
af3683 TR2/3/3A TR3 Stainless Steel Exhaust Triumph 5
Frank C. Stainless Steel Exhaust Austin Healey 6
R Stainless Steel Exhaust system Austin Healey 14
G stainless steel exhaust Austin Healey 14
S Stainless steel exhaust Austin Healey 30
S BJ8 Stainless Steel Exhaust Austin Healey 7
S Falcon Stainless Steel exhaust info needed. Triumph 3
Guido36 Stainless Steel Bumpers Austin Healey 5
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
B Electrochemical cleaning of stainless steel welds Restoration & Tools 7
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
G For Sale Stainless Steel TR6 Bumpers Triumph Classifieds 0
J General Tech Stainless-steel caliper pistons Triumph 8
TulsaFred Polished stainless steel bumpers? Spridgets 13
S TR2/3/3A radiator pipe in stainless steel Triumph 5
bighealeysource Installing new stainless steel beading on BN2 Austin Healey 4
T Stainless Steel Fender Beads Triumph 1
J TR2/3/3A stainless steel rear spring pins for TR3 Triumph 19
RJS Stainless Steel Bumpers Triumph 11
T TR4/4A Stainless steel brake lines for a TR4a Triumph 12
T Regular vs stainless steel pistons for calipers Triumph 13
S Spitfire Stainless Steel Spitfire Bumpers on ebay- Info Triumph 7
T Stainless steel brake hoses - two questions Spridgets 13
T Let's talk about stainless steel brake lines... Triumph 4
bighealeysource Installing front fender stainless steel beading Austin Healey 4
Brosky TR6 Stainless Steel Bumpers for TR6 Triumph 20
Tinkerman Stainless Steel Tenon Plates On Ebay Triumph 1
N Who supplies Stainless Steel lines for clutch? Triumph 12
LuckyLuke Stainless steel battery trays Austin Healey 1
I Stainless Steel Fasteners? Triumph 10
G Braided Stainless Steel Hydraulic Hoses Austin Healey 15
Frazier Stainless Steel Polish Restoration & Tools 1
Y Stainless Steel Brake Lines Austin Healey 4
M XJ8L Stainless steel problem Jaguar 2
7 For Sale Stainless trim for Herald Convertible top. Triumph Classifieds 0
I TR6 How to distinguish between stainless and aluminum Triumph 6
E Moss stainless exhaust offering. Austin Healey 28
Gliderman8 TR6 Stainless oil pressure line install HELP! Triumph 8
T Rattling stainless muffler Austin Healey 10
B Stainless hood / bonnet and trunk / bood support rods Austin Healey 2
drambuie Getting a better deep throaty sound from my Stainless exhaust Austin Healey 5
