TR6 Sputtering along
FR Burkhart
Somehow I have created a problem I can't resolve. On my TR6, it sputters both starting from a stop and at higher RPMs. Could it be the metering needles? The Stromberg 175 CD-2 carbs are set to maximum rich as anything less leads to stalling. Spark plugs checked and replaced 2 months back, timing checked and set by a local British car shop, replaced distributor cap and rotor (electronic ignition), installed new electric fuel pump. What am I missing? Could it be vacuum setting?
Thank you for any guidance.
Have you checked the fuel filter? Is there sufficient flow to the carbs?
By the way, welcome to the British Car Forum.
I have to ask....please describe in detail what you did to set the mixture ?
Elliot,
Just installed a new electric fuel pump with filter. Pump is rated at 3 psi. I have also replaced the needle valve and carburetor float on the rear carb (haven't touched the front carb).
Thanks for the welcome. I can't imagine a better place to get advice.
I have adjusted the metering needle to max clockwise. Even at that setting, raising the piston slightly causes the engine to almost stall (drop of RPM). I tried using the vacuum tool but couldn't get enough airflow - as soon as the tool was pressed against the carb, the engine stalled.
One other item - oil is not remaining in the dashpot. When I add oil up to the top ring, the oil will be gone within a couple days.
Whatever the problem, raising the needle to maximum height is really just an attemt to compensate for an underlying problem.
I'd put the needle in the middle of it's adjustment range and try to find the actual problem.....1 and 1/2 CounterClockWise from Fully ClockWise.
I've never been able to get satifactory results with a UNiSYN type of synchronizer on ZS carbs...It blocks some ports in the carbs' air box mounting flange.
And while I see your point about the damper oil level, I'm not sure you are filling just the damper well properly when you refer to the 'top ring'
See this: ZS carb Damper level 002.jpg
There's an adage:
"90% of carb problems are ignition problems"....with that in mind I think I'd check the ignition timing at idle if only by ear...you can't be that far off.
See this:View attachment 64372
There's an adage:
Great suggestions. I can try these tomorrow morning. At least, the car isn't my daily driver. But it is summer and some longer road trips would be fun.
And...carefully just put the oil in the damper well; it's the smaller diameter cylinder that you see when you unscrew the damper knob/piston
The Owners Manual recommends using the same oil and viscosity that you put in the TR6's engine.
Well, I think we found the problem. Recently we had installed an electric fuel pump. Today, removed the mechanical pump, installed the backing plate and removed the old fuel lines. Just as a precaution, started the engine - and would not start. Short story - we had bounced against various wires and the wire from the alternator to the coil had come loose. Once that wire was securely reattached, the sputtering problem disappeared. Our guess is that the wire had been loose all along so the coil was not getting a steady current. Longer trip later today to test (90 degrees in the bright sun is just too hot). Hopefully, this problem is solved.
Thank you for your help.
There you go !....
There's an adage:
Question does temp make a differents ? Your CD 2 carbs have a diaphragm on the top under the four screws remove top check for a hole and or lost it's flexibility it should be almost like a condom. If you find one bad change both. I carry an extra one as I have lost a few. When you remove to check note they have a key notch that has to go back in it's slot; Question does pulling the choke out help? You should not be running at full rich you have covered up the problem Madflyer
Recently replaced both diaphragms (problem existed before the change). And, having the choke out does eliminate the problem. Maybe I should be asking the question of why do I need to have the carbs set to full rich? Leaning out the mixture by turning the metering needle by turning counter clockwise makes the problem worse. Fuel shouldn't be a problem, new fuel pump running a 3 psi. What else could cause a lean condition?
Could be a couple of things, but the last set of carbs I had in the shop with a similar complaint had debris clogging the very bottom of the jet...About the only fuel available was that supplied thru the choke.
Cleaned the rear carb within the last month and replaced the metering valve. No apparent debris in the bottom. Also replaced the float. Didn't touch the front carb as the rear was so clean. Always a chance that the front carb could be a problem.
tr6web TR6 Sputtering help Triumph 6
F TR6 Sputtering at low rpm Triumph 16
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
bugedd Sputtering Spridgets 15
PeterK TR4/4A Stalled project, now sputtering Triumph 3
S BJ8 Sputtering at High Engine Speed and in Overdrive Austin Healey 36
J MGB 69 MGB sputtering problem MG 5
nevets sputtering issue fixed...it was the timing Austin Healey 4
Bremer TR2/3/3A TR3A sputtering after 1 hour of driving Triumph 1
drooartz Sputtering in left hand turns Spridgets 17
nevets sputtering redux Austin Healey 3
nevets intermittant sputtering follow-up Austin Healey 13
nevets Intermittent sputtering Austin Healey 38
K TR2/3/3A TR3A: Occasional sputtering and hesitation? Triumph 4
K TR2/3/3A TR3 Coil + Heat = Misfiring and Sputtering? Triumph 6
TR4A_IRS Sput...Sput...Sputtering? Triumph 19
Shane Fully choked and sputtering Austin Healey 3
Mio Sputtering under load Spridgets 27
U sputtering at start Spridgets 3
Wana UPDATE: Engine Sputtering Austin Healey 2
Don Elliott TR4/4A Sputtering when hot TR3 & TR4 Triumph 29
Luke_Healey Ignition/Sputtering troubleshooting? Spridgets 16
Wana Engine sputtering... Austin Healey 22
H Rough Idle and Sputtering Austin Healey 22
mabbott TR6 73 TR6 Sputtering problem? Triumph 17
wkilleffer Sputtering/backfiring around left-hand turns MG 4
Gray_Cat Sputtering/warmish Running BN1 Austin Healey 2
K ran fine, now sputtering/backfiring at speed MG 8
T TR6 TR6 Sputtering Triumph 12
Jayplum For Sale SU HS6 for sale along with a long intake Triumph Classifieds 3
AngliaGT A Few More along Highway 220 Spotted 3
PC sing along British Motorbikes 0
dougie 100-S Ride Along Austin Healey 3
AngliaGT Saw a Few Along the Trip Spotted 4
TulsaFred Bugeye garage paint job - start to finish [almost] with lessons along the way Spridgets 28
drooartz The teardown begins, follow along at home! Spridgets 51
T '76 Midget driving along then chugging? Spridgets 18
drooartz MGB Follow along as Drew tears down an MGB engine! MG 21
HealeyRick Nasty Boy Ride Along Austin Healey 6
longbridgehealey interior is coming along Spridgets 31
dougie Ride Along With One of the Best Austin Healey 3
M 1275 Exhaust Manifold Needed - Along with Advice Spridgets 5
T TR4/4A Randy - how is your TR4 engine build coming along? Triumph 18
PAUL161 T-Series TF Coming Along MG 32
T TR2/3/3A Tush - how is the TR3 coming along? Triumph 1
T Tush - how is the project coming along? Triumph 5
Tabcon Rolling Along II [with good link] Triumph 3
Tabcon Rolling along! Restoration Pics Triumph 15
T Randy & Keith - engine rebuild coming along? Triumph 2
T Randy - how are things coming along? Triumph 6
