[solved] Sunpro Fuel Gauge... going crazy!
pjsmetana
I just installed a new Sunpro Fuel Level Gauge in my Spitfire. The stock one was quite beaten up and never read better than 1/2... Plus I'm changing all Dials to red :laugh: When I started her up under full choke the gauge read perfect, as I have a full tank for sure. A few second into running I pushed the choke in to 1/2 (as its about 65F in my garage, and 55F outside) the gauge started going crazy... as in, rapidly moving from full tank to lower than empty. I don't think the choke has anything to do with this, but its the only thing I did after starting. I also tapped the gas to see if maybe the low idle had any effect, and it did not.
I suppose a loose wire could have this effect, so maybe someone has a diagram of where all the fuel level related wires run? Maybe some tips on problematic locations? Also, do I access the fuel tanks level sensor thingy from the trunk side? I'm replacing that too. I pulled the panel from the interior and I didn't see it.
Pictures are greatly appreciated!
Don_R
Re: Sunpro Fuel Gauge... going crazy!
Pete,
The sender is accessed trunk (boot) side.
Does the sunpro gauge use a sender with the same resistance valuesas the smiths unit?
Remeber...the smiths unit is a 10V unit not 12V...
martx-5
OK, I found a wiring diagram online for a Mk III Spitfire, and it shows the voltage regulator inline with both the temp and fuel gauges. As <span style="font-weight: bold">Don </span>says, these supply 10VDC to those gauges. However, if it's the original type that came with the car, it's rather crude, and and turns on and off at a rapid frequency to approximate a 10VDC signal. If your new gauge is fast acting, it is most likely emulating this on-off signal. The other thing to consider is if the new gauge is calibrated to work with the resistance of you original sender. Did this new gauge come with instructions?? If so, do they mention anything about the resistance of the sender that is needed to drive this gauge??
If you have to, you can easily eliminate the voltage regulator if the new gauge doesn't require it, but the resistance scale of the new gauge will have to match the sender or it will never work properly.
Edit: BTW, here is the wiring diagram I found. I had to translate a few German words just to make sure of what some of the items were. :laugh:
Edit again: Since you have a 1500, I looked around some more for a later wiring diagram, an it still shows the voltage regulator.
Later diagram...
dklawson
The Sunpro instruction are likely to say to connect it to a 12V switched supply. That's because it has its own internal voltage regulation. Most aftermarket (non-Smiths) gauges do not require connection to the Smiths stabilizer and should not be connected to it.
If you connected the Sunpro to the voltage stabilizer, unhook it from the light green wires that are coming from its "I" terminal and make/install a jumper so it is connected to the stabilizer's "B" terminal. The stabilizer's "B" terminal will be switched, fused, 12V power.
As Art said, you have to have the right range sender for the gauge... or buy the right gauge to match your sender. The "nominal" range of the Spitfire sending unit will be about 270 Ohms empty to near 30 Ohms full. That's close to one of the many industry standard ranges for gauges (I think the closest nominal is 240 Ohms = empty to 33 Ohms = full). If you bought a Sunpro gauge that accepts that range and direction you should be OK connecting the sending unit's green/black wire directly to the input terminal on the Sunpro.
pjsmetana
pjsmetana
Its just the general sunpro generic fuel gauge. I assume this means 12v, as the instructions that came with it were for 6 different items, none of which were the fuel gauge itself... which immediately gave me a frowny face.
I have a new sunpro fuel level sender that I plan to use.
dklawson said:
...voltage stabilizer, unhook it from the light green wires that are coming from its "I" terminal and make/install a jumper so it is connected to the stabilizer's "B" terminal. The stabilizer's "B" terminal will be switched, fused, 12V power.
Where the heck is this stabilizer thing? And what does it look like?
Don_R
Pete,
The stabilizer is a rectangular metal type unit attached to the back of the Speedo.
I replaced mine with a solid state unit last summer....
There are 2 sets of spades on the regulator...switched 12V and 10V regulated..
Don't remember if I kept the old regulator...
Hope the sending unit has the same diameter as the old one or more fitting and possible gas leaks may occur...
Don_R
Pete,
heres a pic of the unit
TR3driver
Great Pumpkin - R.I.P
Just for clarity, the on/off action is not what I would call "rapid". It's slow enough to easily see a test light blink, for example, not much quicker than a turn signal flasher (which is very nearly what it is). And it does take a few seconds to turn off the first time, so this would be entirely consistent with your Sunpro gauge working at first and then "going crazy".
pjsmetana
pjsmetana
Found the stabilizer. That thing sure is in an inconvenient location :smile:
I don't see an "I" or "B" label anywhere on it.
So, read the voltages, and whatever side says 10v, move to the side that says 12v? Sounds like I'm going to be bypassing the regulator completely. Would there be any problem with just removing the regulator, and soldering (or using a butt connector) the dark green wire to the light green wire?
martx-5
IIRC, you put in a mechanical temp gauge, so you won't need the stabilizer at all with this new fuel gauge. It also means that you probably have a dangling light green wire that went to the original temp gauge, unless you removed it. That leaves another light green wire that goes from the fuel gauge to the stabilizer. You will need to unhook that wire from the stabilizer and then attach it to the dark green wire(s) on the other terminal of the stabilizer. You can take off the dark green wire(s) from the stabilizer if you want to make the connection easier, because you won't be needing the stabilizer anymore because you have a mechanical temp gauge that doesn't require any electrical input.
Look at the wiring diagram I linked to...the one marked "later diagram" and you will see what we are talking about. Look for the "tach" in the diagram, and the gauges are just below and to the left.
Don_R
Pete,
<span style="font-weight: bold">The regulator also provides 10V to the temp gauge</span>..
On my diagram for the 73 Spit it shows that the regulator goes to the tem gauge first then on to the fuel gauge.
They may both go back to the regulator you need to check that on your car..
You will need the the regulator for the temp gauge unless you have changed that out....
Was at the Sunpro site and the sender they show won't fit the stock sender location.
The stock unit is in the side of the tank w/ a lock ring. the Sunpro unit looks like a screw on top mount unit
martx-5
Randall, I've never checked out one of these stabilizers, but if it's as slow as you say, and I'm not doubting that in the least. But, just out of curiosity, what kind of buffering is there in the original gauges that allows this low frequency without seeing the result in needle movement??
TR3driver
The gauge movement has a resistance wire heater that heats a bimetal strip and the deflection of the strip is what drives the needle. Since the heater has to be electrically isolated from the bimetal strip, it takes some time for the heat to penetrate the insulation, and the (deliberate I assume) result is a gauge that responds very slowly.
When the Stag with the leaking headgasket would overheat, I would literally see the steam leaking from the hood <span style="font-weight: bold">before</span> the temp gauge needle even made it to the red zone!
I was a little surprised myself at how slow the "voltage stabilizer" switches, but I checked several of them and they are all like that.
Don't have the link handy, but someone posted a photo of the mechanism here on BCF a few months back.
Worth noting, perhaps, that not all Lucas gauges work this way. The VS + hotwire gauges were apparently only for the cost-sensitive OEM market; their aftermarket gauges of the period did not require a VS. The aftermarket Lucas temperature gauge I have uses a "balanced" movement rather similar to the fuel gauge in a TR3, which responds practically instantly.
TR3driver
It's usually stamped into the phenolic base (the brown part behind the terminals); but I've also seen units that don't have either label.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]So, read the voltages, and whatever side says 10v, move to the side that says 12v? Sounds like I'm going to be bypassing the regulator completely. Would there be any problem with just removing the regulator, and soldering (or using a butt connector) the dark green wire to the light green wire? [/QUOTE]
You can't read 10v, the output switches between 0v and full battery voltage. But usually the connectors are opposite gender, so you can just pull them both off of the VS and plug them into each other. Add some insulation and support, should be good to go.
Don_R
Randall,
That may be possible BUT..if the wiring goes from regulator to Temp to Fuel, that will put 12V on the temp guage.
If both guages run back to the regulator..pulling the 12V switched side and connecting it to the fuel sender drops the power to the temp guage.
the best solution is to run a new wire from the fuel gauge back to the 12V switched side of the regulator
TR3driver
That is true, Don, <span style="font-weight: bold">if</span> he is retaining the original temperature gauge. My understanding is that it is already gone, and so no longer needs to be connected to the VS.
pjsmetana
pjsmetana
Well, its not gone <span style="font-style: italic">just yet</span>... but yes I have the new sunpro mechanical temp gauge and am just waiting on the adapter from the mini parts site. It should be here tomorrow.
TR3driver said:
... pull them both off of the VS and plug them into each other. Add some insulation and support, should be good to go.
Roger that Randall :smile: gonna go give it a shot now.
pjsmetana
pjsmetana
Bingo! Works perfectly now :laugh: Thanks everyone!
DNK
$20 under everyone's pillow should be fine
pjsmetana
pjsmetana
I'll be sure to let the tooth-fairy know she's gonna be working for me now. I hope she can carry that many quarters!
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
EricJNewman MGB Weird Brake issue finally solved. MG 1
E MGB MG Idle issues, restart issues solved. MG 4
AngliaGT MGB-GT Extremely Dumb Question - Distributor Hose - SOLVED! MG 3
P TR6 Clutch problem not solved Triumph 6
M A problem solved Austin Healey 0
Basil DIL's O2 sensor problem - SOLVED Other Cars 11
Flash_Harry MGB MGB '74 B-GT with fuel problem - SOLVED [I think!] MG 4
andrea PROP ROD BONNET RATTLE easy solved Austin Healey 9
B Oil Pressure Issue Solved 3000 BT7 Austin Healey 1
L Turn signal problem solved [sometimes its not your fault] Austin Healey 6
G My engine keeps conking out problem solved! Austin Healey 2
DanLewis Solved the oil cooler mounting problem in my Bugeye! Spridgets 8
T TR6 TR-6 Clutch disengagement issues, recurring or solved ? Triumph 6
DanLewis Overheating problem solved, or ... did you disconnect your vacuum advance? Spridgets 4
R TR4/4A Tr4a horns problem solved Triumph 4
HEALEYJAG 73 E-type Roadster short solved- NOW........... Jaguar 9
P Coolant leak solved Triumph 1
T Sqeeling Clutch Problem..SOLVED Triumph 2
Gliderman8 Problem solved! Triumph 5
tr6nitjulius Problem Solved! Triumph 4
Morris Mystery solved! Spridgets 14
G Vapor lock issue solved [RB cars only] Spridgets 22
Tinkerman TR2/3/3A Overdrive Switch question. TR3A, Problem Solved! Triumph 10
hondo402000 TR6 Leaking Transmission solved TR6 Triumph 5
A Oil leak solved - the footpower stomp Latest Austin Healey 0
rlandrum TR2/3/3A TR3A Low Oil Pressure Solved Triumph 19
1965_MGB VB SU fuel pump kits, any experience? *Solved* MG 0
jackq nightmare o/d problem solved MG 0
jjbunn Call for help: Pasadena, CA UPDATE PROBLEM SOLVED! Triumph 15
regularman One problem solved. Spridgets 2
G Solved my Master Cylinder Reseroir Leak problem... Triumph 6
O tach problem solved? Spridgets 4
healeyboz Allright Fellas --- Problem to be solved!! Spridgets 39
B New gas tank issue [SOLVED] Spridgets 14
RickB Gassy smell in cockpit - Solved! Thought I'd share Spridgets 4
budk1953 One problem Solved? Spridgets 6
Bret Mystery Coolant Leak Solved! MG 3
kyreb1862 Disappearing Brake Fluid Problem Solved [Sadly] MG 8
WidespreadPanic TR6 '74 TR6 Fuse Box [UPDATE] SOLVED! Triumph 27
PAUL161 MGB The Australian CKD MGB - Mystery Solved! MG 2
MadRiver Alternator problem solved Triumph 0
8 84 jag no start SOLVED Jaguar 1
P MGB overheating 63 mgb solved :] MG 10
C Solved TR 3 tuning problem Triumph 2
G Starter Switch Mystery Solved! Spridgets 2
R Windshield problem solved! I think? MG 0
D Broken hood release cable - problem now solved. Triumph 1
trrdster2000 TR generators, problem solved??? Triumph 1
G Irregular Heartbeat - SOLVED!! Spridgets 3
