rust proof removal - how to
Adrio
I can't blame the DPO for this one. I was young and dumb 30 years ago and I sprayed that rattle can tar undercoating (the kind that never dries) everywhere there was not exterior paint Including the engine bay, boot, and the under side of the boot lid and bonnet.
Fast forward 30 years and I am tired of dealing with the sticky mess. I want to remove it and paint those areas body colour.
Is there an "easy" way to remove that stuff. I have been going at it with thinners and paper towels for about an hour and not made much of a dent. At this rate I will need a week of evenings at the least.
Adrio
Try a paint scraper, the kind that you pull, to scrape off the bulk. Then use the Eastwood stuff and scrape some more... and some more. Try kero or diesel fuel to finsh off the film after scraping.
Try a wire wheel on a drill and then the eastwood stuff.
I've had decent success with a heat gun -- used judiciously -- and a wooden scraper (like a paint stirrer) in removing the bulk of such undercoat with little or no damage to paint underneath. Final cleanup can be done with kerosene or other solvents.
There is no easy way!Best way I have found (and possibly the less messy)is how Andrew describes,just use enough heat to get it soft enough to scrape off,and laying loads of paper out underneath to catch it(if too hot just tends to spread it about)make various shaped wooden scrapers to get into the nooks and crannies.If you try with a wire wheel,all that happens is it throws it everywhere and the briush clogs up and renders it useless and marks the paintwork.
Adrio,
Heat gun and a flexible scraper and lots of patience.
I found that brake cleaner really worked well to clean up the left over residue.
Cheers,
M. Pied Lourd
This is another endorsement for Andy's method. I have used it on two cars now.
As a footnote to the heat method, use safety gear. By that I mean heavy gloves, a long sleeve shirt, and a full face type shield. Half melted undercoating can create very painful burns.
Been there, can personally confirm that unless <span style="text-decoration: underline">99%</span> of the coating is off first this will just make a mess, sprary stuff everywhere and ruin the attachment.
Ok, I got one for all of ya... I've been doing this very thing on my car for the last while, and I've found something that works very well. I did try the regular wire wheel, and the heat, scraper methods, but they weren't working for me.
Get one of those 4 1/2 inch <span style="font-weight: bold">knotted</span> wire wheels and put it on your grinder. It will blast the stuff off in no time flat, and take the paint off too. :cooler: It won't touch the rust or remove any metal though. Make sure you wear heavy clothing, and wear a face shield and gloves or you will be getting bits of tar, paint and wire brush sticking into your skin. Use a smaller knotted brush on a drill for the tight areas.
Cheers
5 BJ7 Boot Rust-Through Austin Healey 13
E Rustproofing and Rust Austin Healey 2
1 General Tech Rust Proofing Triumph 7
ROARRR For Sale 1930-40's AUSTIN 10 SALOON! straight, good glass, no through rust, very complete Austin Healey Classifieds 0
D TR6 Rust and hesitation 71 TR6 6 Triumph 9
D Removing the last rust from pitted steel Restoration & Tools 11
algot1901 My Prefect in her B-Day Suit and playing with rust-Flash! Other British Cars 19
O For Sale 1969 GT6+ Mostly rust free. Triumph Classifieds 3
SteveTheBrewer Spitfire More rust repair Triumph 1
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
R Rust in Block? Help needed! Austin Healey 6
F TR2/3/3A Rust under flanges Triumph 7
D MGB Stopping rust under patch panels MG 1
P BJ8 Frame Rust Options? Austin Healey 14
Rut TR4/4A Rust for sale Triumph 2
S TR2/3/3A door blistering with rust Triumph 4
R TR6 Rust on the floorboards Triumph 5
J TR2/3/3A inner sill rust prevention Triumph 1
Chuck9482912 Rust in new fuel filler neck Austin Healey 4
R GT6 Looking to purchase GT6 Rust repair question? Triumph 4
Rut TR4/4A Rust bucket, save, sell, or part out Triumph 15
D General TR Fluid Film Rust and Corrosion Inhibitor Triumph 8
J TR2/3/3A Flash Rust Triumph 21
E For Sale 1955 Austin Healey 100 /4 rust free project car Austin Healey Classifieds 3
Lukens Outer rocker showing "rust" Restoration & Tools 11
R TR2/3/3A Good Rust Remover Triumph 14
Rut TR4/4A Rust free TRs Triumph 4
69MGC MGC Cut out the Rust! MG 9
KVH General Tech New Camshaft Has Rust Triumph 7
JimLaney Engine rebuild - how critical is rust? Spridgets 3
B 1960 TR3 With rust in cylinders Triumph 7
Rut TR4/4A Rust removal by Electrolysis Triumph 9
H Bugeye seat pan rust and possible repair Spridgets 2
Popeye TR4/4A Seat frame - rust "repair"? Triumph 1
Keoke Cars keft behind turned to rust by mother nature Austin Healey 8
bugedd Rust advice Spridgets 24
Sopwith_Camel Compressed rust Jaguar 1
T GT6 Opinions on what a rust free GT6 is worth Triumph 22
C TR6 New rust discovered Triumph 10
S Rust treatment recommendation? Austin Healey 5
maxwedge5281 who buys rust buckets? Austin Healey 16
nevets "RUST The longest War" Austin Healey 5
bugedd Why the rust? Spridgets 15
catfood Self tapping screws an rust prevention Austin Healey 10
Chuck9482912 Rust holes in engine of Austin Healey 3000 Mk II BJ7 Austin Healey 22
S Rust Bubbles Spridgets 17
G Rust repair needed for 66 AH 3000 Restoration & Tools 4
B MGB-GT Best rust repair person/shop on the East Coast? MG 2
T Sprite rust Austin Healey 10
MG Lily Best way to safely remove minor surface rust? Restoration & Tools 5
