RB weight sans driveline and bumpers?
G
How much would a mostly comlete RB car weight minus the entire driveline and bumpers? Trying to figire weight on a project.
I'll buy that but how much do the engine,trans and diff weigh?
I found 275#'s for engine. I would guess ~100 diff and ~75 trans if that much.
So ~1100#'s for an empty body. Put in 1000#'s of 343, trans and rear end for a total of ~2100#'s and
~11.49 e.t. @ 116 mph figuring 2300#'s w/ driver.
12.63 e.t @ 106 w/ Rover V8.
I bet 1100 lbs for an empty body is high - shell is 300-350 lbs. racing seats? dash - 15 lbs? wiring 5 lbs? I know shocks and steering etc factor in but....
Gotta cut out and lay in new heavier frame ans suspension stuff. You didn't think I was just gonna shove in a V8 and run 11.XX's with a stock frame and suspension...did ya?
I might be low budget but that doesn't mean I'm stupid.
I'm still up in the air. The Midget I have is solid, the Spit has rusty rockers, quarters and rear frame (That I'd cut out anyway)and the 6 I have is solid w/ a rebuilt front end. While Midget would be truer to what I want, the Spit wouldn't be a sacrifice and the 6 is an all together a different build.
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
Michael Oritt 100 Flywheel Weight Austin Healey 16
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
T TR2/3/3A Body Tub Weight Triumph 8
X Technical specifications including the maximum technical weight TVR 8
S TR2/3/3A What weight transmission oil in a tr3 with OD? Triumph 13
Joe_Healey 1952 Nash Healey Lightweight Austin Healey 12
H MGA MGA engine weight? MG 3
TRMark TR4/4A TR4 Weight Loss Program Triumph 6
banjojambo TR2/3/3A TR3A adding weight to improve handling Triumph 5
R Engine component weight reduction Austin Healey 53
BoyRacer weight of bare Healey chassis Austin Healey 8
T TR2/3/3A TR-4 Tail shaft counter weight Triumph 4
kennypinkerton MGB Body shell weight? MG 3
kennypinkerton MGB Rubber bumper weight surprise.. MG 4
BOBBYR Frame weight Austin Healey 14
T Weight of a Bug-Eye bodytub: approx 220 pounds Spridgets 10
Willie_P TR4/4A Weight Weenies: Tr4 relo of battery to boot...good idea? Triumph 6
glemon General TR Weight Loss Program Triumph 9
H The Lindner-Knocker Lightweight: is it an authentic restoration? Jaguar 0
C The "Lightweight" Jaguar E-Type.....why did they only make six?? Jaguar 2
GeorgeC Hardtop weight? Spridgets 6
Griz Engine weight Austin Healey 13
2billydavies TR2/3/3A engine fan assembly on TR3a: balance weight question Triumph 3
R weight of BJ8 Frame with inner body panels Austin Healey 1
P 1275 Weight?? Spridgets 3
K TR2/3/3A The "Counterweight" on the 4A gearbox. Triumph 12
D Engine weight Triumph 4
O TR2/3/3A TR3 Overdrive Weight? Triumph 6
5 TR2/3/3A TR3 bare shell weight Triumph 9
T Weight difference beween steel and wire rims Triumph 11
S Weight of Bugeye unibody Spridgets 2
T TR2/3/3A What weight gear oil to use in TR3 transmission? Triumph 23
M 3.0 iron weight difference Austin Healey 7
J Another pic of the E-Type light weight Jaguar 0
G Spitfire Weight diff b/w Spit 4 and 6? Triumph 3
J TR 4 Rear Transmission Counterweight Triumph 8
A Rear end weight? Austin Healey 7
J TR2/3/3A TR3 tub weight? Triumph 16
B Engine Oil Type and Weight? Austin Healey 8
Frankenhealey Aluminium everything - weight saving? Austin Healey 3
K TR4/4A TR4 &4A transmission counterweight? Triumph 2
hilsideser Spitfire Spitfire frame weight? Triumph 6
B Rear Clip weight Triumph 2
Ken40 MGB-GT MGB/GT body shell weight MG 3
B Race spridget weight jacking Racing 8
aeronca65t Corner weight setup Racing 3
K Curb weight Triumph 4
BionicHealey Chassis Weight Austin Healey 13
AUSMHLY 1961 Austin-Healey Sebring Sprite Lightweight Work Austin Healey 0
