Radiator ID or information please?
RickB
[SIZE=+0]Looking for information / identification.
I have a radiator that appears to be for a Bugeye or MK1 Midget, MK2 Sprite.
It is thicker than standard, has no fan shroud and has larger inlet and outlet.
The really interesting thing is on the top tank it has a tag that reads:
[/SIZE][SIZE=+0]Manufactured By
Morris Motors Ltd[/SIZE][SIZE=+0]
Radiators Branch.
Oberton Works OXFORD.
ARA 0092 000 0001
(that's what it looks like)
[/SIZE]
[SIZE=+0]
Here is another picture.
The central part with the fins, the core, is 2.75" thick.
The inlet/outlets are 1.5" inside diameter.
[/SIZE]
[SIZE=+0]
[/SIZE]
Rut
Looks like the radiator on my Dads old Morris Oxford from a 'few' years back.
Rut
RickB
RickB
A chap in England confirms it's an early Bugeye Sprite radiator.
Also John Sprinzel writes:
"I don't think I ever saw one like that, but clearly special radiators were always being made. As you know, the early Sprites had big overheating problems, as the bonnet itself had no ducts for the air, which just went around the rad. and not through it, until a duct was incorporated. Running prototypes around Warwick wasn't exactly like driving one on the Alpine Rally in June in the French Alps .
Aloha. John"
Now, what about the rest of the numbering? "000 0001" has got to mean something, usually it's the first (possibly only) of a thing.
Probably more of a model number than a serial number.
nomad
Aloha. John"
You got a personal reply from JS!! Geesz, Rick, you get around!
Kurt.
RickB
RickB
I really wanted to look him up last fall when we went to Maui, but we were busy with all the things we had planned to do for our anniversary.
If you've been around British cars for a while things tend to l accumulate, not only parts and cars but associations and relationships and memberships etc...
So now I need to get Ray English in Australia to take a look, I figure if he doesn't know it then it's probably not worth knowing.
Michael Oritt Wizard Radiator Austin Healey 7
S Installing a Radiator Fan Austin Healey 9
5 MGA Radiator MG 2
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
RJS TR4/4A Radiator Fan Shround Triumph 3
S Install drain cock in radiator. MG 2
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
S TR2/3/3A radiator on Ebay Triumph 4
T For Sale TR3A Original Radiator Triumph Classifieds 3
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
T Radiator Hose Size Austin Healey 2
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
Simmo MGA Aluminium Radiator AUSTRALIA MG 17
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
nevets Radiator Service Austin Healey 6
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
mrv8q TR2/3/3A Rebuilt or new radiator? Triumph 12
J BJ8 Radiator Fan Austin Healey 12
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
R TR6 Radiator protection shield differences Triumph 0
K For Sale TR3 Radiator Guard Triumph Classifieds 0
S For Sale Mg tf new radiator shell-slats-false nose-emblem MG Classifieds 2
Kurtis TR4/4A TR4 Radiator Guard Attachment Triumph 7
edkap2002 TR6 lower radiator hose fitting Triumph 2
nevets Radiator Overflow Tank Austin Healey 23
K TR2/3/3A Radiator coolant level? Triumph 5
K TR2/3/3A Radiator drain tap? Triumph 4
D TR2/3/3A radiator overflow restrictor Triumph 9
T TR2/3/3A Question on TRF radiator cap GRC103 Triumph 1
G 100/6 Radiator cross member Austin Healey 6
D TR2/3/3A assembly, TR3A rear fender and radiator stays Triumph 22
S TR2/3/3A and the radiator was leaking. Triumph 7
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
B Radiator Baffle Installation Austin Healey 4
S Painting a BJ8 Radiator - any advice? Austin Healey 17
S Bugeye Radiator Tank Plug Size? Spridgets 24
FlyingCat Spitfire Electric Radiator Fan Triumph 10
T Radiator Shroud "Chinese Red" Match Needed Austin Healey 10
FlyingCat Wanted 1979-80 Spitfire Radiator Mount Bracket and Cradle Triumph Classifieds 0
FlyingCat Spitfire Radiator and fan Triumph 5
aero3113 Radiator overflow catch tank Austin Healey 15
Sarastro TR4/4A What radiator do I have? Triumph 4
Patrick67BJ8 Radiator & Engine Flush Austin Healey 10
D BT7 radiator Austin Healey 1
M Radiator Paint Austin Healey 20
RAC68 Radiator Core Replacement and Sleeve Thermostat Alternatives Austin Healey 20
RAC68 Recovery Cap for Original Healey Top Tank Radiator Austin Healey 7
JFS TR2/3/3A Radiator fan temp probe Triumph 3
