twas_brillig
The rocker shaft design incorporates a single set-screw to prevent the shaft from moving fore & aft; the parts manual shows it threaded into the rocker pedestal at one end of the shaft. The rocker shaft assembly I was going to install has it (and the appropriately threaded pedestal) located second from the end. I've got a couple of other engines; the most accessible has it in the end location.
I don't see how the location makes a difference, but would appreciate others' thoughts on this.
Thanks
Doug
Thanks
Doug
