TR2/3/3A Production Change
6TTR3A
I'm doing some research for a fellow sidescreen owner..
Piggott says,"At TS12567, windscreen wiper motor changed from CRT 15 to Lucas DR2; mounting bracket modified , and motor now mounted on opposite side of car"
Attached are 2 photos I pulled form the internet, clearly showing the wiper motor on the same side as the Comm plate and the Comm. numbers are clearly much higher than 12567.
Any thoughts?
Frank
CJD
Those are both plates from TR2's, so they are below 9000. I don't know why there are more numbers than they should have.
Anyway, all TR2's had the wiper motor to starboard.
Edit, As I look at them closely, I read TS2014 with an extraneous looking "5" at the end...and 2245, with an obviously wrong "2" at the beginning. The "2" is obvious because it is not even the same size as the rest of the numbers.
6TTR3A
6TTR3A
They both looked like five digits to me at first glance.....Thanks for pointing that out.
Frank
Tinkerman
I have a post 60,000 and for what it is worth the WW motor is on the drivers side. I just went through the TRA Judging manual and saw no reference to the position of the ww motor. I did go through it fast but there it is for what it's worth.
Dick
TR3driver
Great Pumpkin - R.I.P
I downloaded and zoomed on both photos; I don't see any extraneous digits, just some spots that look like dirt or accidental damage. TS2224LO and TS2014O
CJD
The dead give away is the top of the plate that reads "20TR2". The final TR2 was, like, number 8900 and change.
mgedit
My TR3 is very close to the transition point ... single speed wiper on right side. Cheers, Mike
TRTEL
Triumph was always using up parts on the shelf if they could and they did the with serial number plates at the 2 to 3 transition. Apparently they had upwards of a couple hundred plates and continued to use them up even though they are labeled TR2, (as does my '55 junker). I saw at least one TR3/2, which was badged a 2 at midOhio maybe 20 yrs. back. The owner admitted that he had simply installed a two badge and grill obtained from a salvage yard. The earliest cars and perhaps all the small mouth 3's had the same stamping die for the air intake sheet metal as the latest twos, which allows you to bolt on the two grill. To my knowledge, the last TR2 was TS8636.
Editor_Reid Job Production Cards Austin Healey 0
nitro BJ8 Production Year Austin Healey 6
D GT6 A 69 GT 6+ production date Triumph 2
R 3-point seat belts on late production BT7 MKII Austin Healey 7
X Production year based on body number ? TVR 3
M TR2/3/3A Late 57 Production with a Small Mouth Apron Triumph 16
drambuie Austin Healey body production windscreen card Austin Healey 16
T TR5/TR250 TR-250 Production Numbers Triumph 1
H Rad bulkhead plates production run? Austin Healey 8
simon1966 Daily BN1 production Austin Healey 0
K BN-7 Production Numbers Austin Healey 7
Hap Waldrop 2014 Vintage Production Car Festival at VIR Racing 0
GBRandy Wedge Triumph Production Numbers [TR8 related] Triumph 26
M MGB Second MGB Off Production Line and First LH MGB [GHN3L/102] MG 3
R BJ8 Production Numbers Austin Healey 3
C Austin Healey Production Figures by Year? Austin Healey 3
X Royal Enfield Bullet, still in production British Motorbikes 4
glemon TR5/TR250 TR250 Production Changes??? Triumph 4
B And the 2011 H Production SCCA MARRS champion is Racing 16
Grantura_MKI TVR to start production once again? TVR 0
S 1966 Spitfire H-Production SCCA - eBay Racing 2
JFS Wedge TR8 Pre Production? Triumph 32
swift6 Ford Kent Engine to resume production... Other British Cars 19
swift6 Ford Kent Engine to resume production... Racing 5
V Late production classic minis: anyone have one??? British Motor Corp 5
glemon Spridgets, greatest production racer of all time? Spridgets 16
judow Production date.... Jaguar 3
C TVR Production TVR 6
T Identifying year of production from serial number Spridgets 5
JamesWilson MG Production Resumes at Longbridge MG 7
T Factory production cert arrived! Triumph 29
BOBBYR Production dates ??? Austin Healey 8
T Found another pre-production coupe Triumph 1
G DM6 distributor on the an early production BJ-7 Austin Healey 7
Hap Waldrop 2007 SCCA Production Car Festival this weekend VIR Racing 1
B BE Production year by VIN Spridgets 12
TRMark Surrey production numbers Triumph 13
T Wedge TR8 pre-production coupe Triumph 1
Camshaft 1974 1/2 production numbers? MG 4
Jack_Long T-Series MG TF Production MG 13
Hap Waldrop SCCA Production Car Festival Racing 3
T Wedge TR7 production question Triumph 2
Editor_Reid Body Production Windscreen Card Austin Healey 1
MattP Fastest Production car Other Cars 10
racing girl *UPDATED* Production ceased at Browns Lane Other British Cars 8
D Aston DBR 1 back in production.... Other British Cars 1
J Jaguars new production timetable..pretty cool lineup. What do U think? Jaguar 0
J Lack of Diesel Engine in Europe causes slowdown in X type sales and production Jaguar 0
D Overdrive Stops Working After Oil Change Austin Healey 26
