Piston Polishing
MikeH
Hi All, I'm in the process of rebuilding my TR4 engine, and while waiting for the machine shop to grind the crank for a new rear seal conversion and balancing all components, things keep creeping into my head. Somewhere I read or heard that polishing the piston skirts lessens friction and possible breakage, if piston slap occurs. Am I correct or is this an old wife's tale. Apologies to any ladies out there. Am also having the head shaved, can I do some of the required reshaping on the combustion chamber myself, following Kas Kastner's competition handbook? What would I need in the way of tools? Thanks, Mike
63 TR4 Surrey Top
I don't know about the polishing but I can comment on the head reshaping. I did the head reshaping myself on my TR4A. All it took was an air powered die grinder and a long neck carbide bit. You may as well port the intake and exhaust while you are there with the grinder. The process was not that hard, just make sure you read all about it and know where the water chambers are so that you don't get too close to them. Also I would do this before you send the head in to the machine shop (you would hate to slip and hit a freshly machined surface).
Hi Mike,
I think the key benefit of polishing the pistons (pretty much all over, not just the skirts) is that carbon will have a harder time building up, helping the engine stay clean and run more efficiently.
There might be some piston-slap benefit, too, but not very likely with stock or most standard aftermarket piston. It's more likely to see slap with forged racing pistons (expensive). So, unless those are what you are running in the motor, there shouldn't be much (or any) slap, so polishing can't effect it.
Cheers!
Alan Myers
San Jose, Calif.
'62 TR4 CT17602L
[ QUOTE ]
Hi Mike,
Cheers!
Alan Myers
San Jose, Calif.
'62 TR4 CT17602L
[/ QUOTE ]
Hi Alan,
Just something to ponder. Engines do not obtain full thermal efficiency until a layer of carbon has built up on the pistons & chambers. Heat that could be doing useful work is escaping into the cooling & lubrication systems.
Builders of Diesel engines & high output gas engines, regularly apply a ceramic thermal barrier coating to piston tops & combustion chamber surfaces.
The light carbon buildup acts in the same way. It has been demonstrated on dynos that an engine has more power & efficiency with a light carbon build up on these parts. Maybe carbon build up is better than shiney clean. A properly setup engine will only build a minimal carbon coating after which any further build up is burned off.
[ QUOTE ]
Hi Alan,
[/ QUOTE ]
I'm curious... do you know if that study was comparing a regular surface to a carbon buildup or comparing to a mirror finish? I would expect that the mirror finish would reflect heat better and actually run cooler. The problem being that the finish wouldn't stay mirror for too long because of the severe environment.
Craig
G Polishing my piston tops..... Triumph 5
K TR2/3/3A Piston slap? Triumph 3
T TR2/3/3A valve guides and piston clearance Triumph 6
Simmo TR2/3/3A Something is eating away at my Piston Liners Triumph 15
D Separating the piston from the connecting rod. Spridgets 9
J Piston Coating Austin Healey 3
KVH General Tech Grant Piston Rings--Can't Fit Them Triumph 15
KVH General Tech Removing Piston Wrist Pin Triumph 2
sail TR4/4A Piston Ring Question Triumph 6
M Wanted WANTED...New TR6 piston set. Triumph Classifieds 2
K TR2/3/3A Brake caliper piston install? Triumph 18
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
J TR2/3/3A 87mm piston ring gaps Triumph 15
Jayplum TR2/3/3A TR3 Piston Sleeves Triumph 36
M TR2/3/3A How many miles to seat piston rings? Triumph 4
6 WTB +.040 piston with con rod for 2639cc Longbridge 100-6 Austin Healey 6
BJ8Healeys Disc brake piston seals Spridgets 2
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
J TR2/3/3A Hastings Piston Ring End Gap Issue Triumph 16
M TR2/3/3A Please Help ID This Piston Triumph 6
Got_All_4 TR6 Are these piston nitrated coaded Triumph 5
J TR2/3/3A 83 to 87mm Piston Considerations Triumph 7
Gerard 1275 piston ID Spridgets 2
HighAltitudeTR3 TR2/3/3A Piston Slap đź‘‹ Triumph 12
M TR2/3/3A Sleeve and Piston Sizes Triumph 6
Got_All_4 TR6 Depth of the metering needle in the air valve piston Triumph 12
steveg Piston options for Healey Austin Healey 12
T TR2/3/3A SU Piston Drop Test Triumph 4
C TR2/3/3A Piston gap orientation Triumph 2
Steve1970 TR6 Carb air piston test, still results in stall even when adjusted rich Triumph 11
AHS TR4/4A Looking for piston & liner recommendation Triumph 17
C TR6 ZS 175 CD2 stuck air valve/piston Triumph 5
T General Tech Brake caliper - piston stuck Triumph 4
2billydavies TR2/3/3A need an educational lesson about piston rings Triumph 14
KVH TR4/4A Piston Size Measurement on Rebuild Triumph 4
Jake OD unit operating piston rings? Austin Healey 1
JPSmit Brake piston removal - McGyvered some tools Restoration & Tools 0
W TR2/3/3A Piston and Liner Triumph 2
tinman58 TR6 Piston clearance Triumph 4
T TR4/4A Overdrive piston is sticking Triumph 9
TomMull caliper piston tool Restoration & Tools 11
T General Tech How loose can a piston liner be? Triumph 2
busybrit TR6 AE Piston supplier, when you only want one ! Triumph 2
M Healey 100-4 Piston Crown Clearance needed to Cylinder Head Austin Healey 3
oxford piston rings Austin Healey 4
T TR2/3/3A caliper piston stuck Triumph 12
S TR6 Clutch slave piston shooting out during bleeding Triumph 8
RedTR3 TR2/3/3A TR3 Piston Sets Triumph 10
M Healey Overdrive Accumulator Piston using O-Ring Seal Up-date Feedback Austin Healey 4
A TR2/3/3A Tr3 / 4 piston clearances Triumph 7
