oil pump choice
BOBBYR
Hi Guys,
I hope everyone is doing well. I've been putting together a list of priorities for this year and I think oil pressure is at the top of the list. I know there are common problems all these engines have, but I want to begin with a quality oil pump to start with. I would like to hear your opinions and results if you have replaced yours. Please list the type,make and vendor if possible. Thanks for your help.
Bobby R
I have replaced the oldest wit the High capacity- rotor type by AHead (Not usable for over 6000 rpm engines)But good for me
Supposedly the pump was changed from the gear type to the rotor type because the gear type put undue load on the cam gear, possibly even causing stripping of the gears. If your engine is otherwise tight the rotor (later) type gear will provide adequate pressure.
I got this backwards ... the rotor type pump was the earlier type. Thanks to Randy Forbes for the correction.
Me, well I replaced mine with a DW high capacity unit. You do have to cut down the suction spigot and fit the old strainer on which needs to be distorted a tad ( done when you fit the sump) as mine clashed with the new DW sump. (not sure about the original sump as there definitely is a capacity difference between the two and that is a whole other story)
Oil pressure is up in the 60s, when warm, using Penrite oil and with a re-bore, reground crank, and a new rocker set up.
:cheers:
Bob
Well I have asked the same to Adam at AH Spares in UK as I am rebuilding the engine as part of the restoration of my car, and this is what I have been told regarding the choice of just replacing internals (gears, studs) of oil pump vs. complete original vs. high capacity:
"We would recommend replacing the oil pump complete. It’s a small cost for some piece of mind knowing that it is all functioning well. The high capacity oil pump is designed for a worn engine where a lot of oil passes through the bearing faces and causes low oil pressure. Pumping more oil around the engine compensates for this.
The standard pump pumps the correct amount of oil around the engine in correspondence to the revs. This is the one to have if the engine is fully rebuilt."
So I will be ordering the standard complete pump for my rebuild.
T TR2/3/3A fuel pump oil leak Triumph 7
KVH General Tech Oil Pump Woodruff Key Triumph 10
KVH General Tech Gaskets—Head/Oil Pump Triumph 4
S For Sale Oil Pump Rotor Assembly for Sale Triumph Classifieds 0
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
A T-Series MGTD oil pump bypass valve MG 0
MikeAH100M Oil Pump for BN2 Austin Healey 4
A T-Series Mgtd oil pump alterations MG 2
nichola TR6 Oil pump drive barely engages Triumph 2
S TR6 After I put in my new oil pump.... Triumph 3
S T-Series oil pump MG 0
svtmikey GT6 Oil Pump replacement Triumph 5
D TR2/3/3A Oil pump question Triumph 31
J TR2/3/3A Oil Pump Wear Triumph 5
H For Sale Healey oil pump drive Austin Healey Classifieds 0
B TR2/3/3A Oil pump rebuild Triumph 4
Michael Oritt 100 Oil Pump--options and resources Austin Healey 12
Michael Oritt 100 oil pump Austin Healey 5
J Bj8 Oil Pump Austin Healey 2
J 3000 bj8 Oil Pump Austin Healey 38
Jim_Gruber Priming oil pump Spridgets 9
JPSmit Question One - oil pump Spridgets 2
F Video showing oil pump and Kingpin bushing repacement on BJ8 Austin Healey 3
JPSmit New Oil Pump startup Spridgets 8
Rut 1275 oil pump, camshaft adapter Spridgets 2
KVH TR4/4A Using Drill to Spin Oil Pump Shaft Triumph 10
gbtr6 TR6 Prime oil pump in rebuilt engine... Triumph 10
T TR2/3/3A Oil Pump Grief Triumph 8
D Not another oil pump question. Austin Healey 7
tinman58 TR5/TR250 OIL PUMP Priming Triumph 3
B Overdrive Oil Pump Installation Question Austin Healey 10
J Denis Welch Aluminum Sump and H/C Oil Pump clearance Austin Healey 18
dcoplan I've got a twisted camshaft-to-oil pump pin. How to fix?? Spridgets 1
RJS TR4/4A Oil leak at/on fuel pump Triumph 7
D Wedge Funny oil pump Triumph 9
johnrip Wedge TR7 Oil Pump Leak Triumph 2
JPSmit Oil Pump Question Spridgets 13
B TR2/3/3A oil pump drive shaft removal challenge on TR3 Triumph 14
Patrick67BJ8 Oil Pump Recommendation[s] for BJ8 Austin Healey 12
M Healey 100-4 Oil Pump Condition Check Austin Healey 3
BillW103 Oil Pump Spridgets 24
TulsaFred Oil pump priming access Spridgets 8
richberman Anyone rebuild oil pump gears Austin Healey 1
johnrip Wedge tr7 oil pump leak Triumph 2
B Oil Pump for 100-4 Austin Healey 2
chrpark MOWOG oil pump cover- attachment to back plate? Spridgets 6
richberman Which oil pump? Austin Healey 1
DNK Oil Pump spin up Question Triumph 18
P T-Series Looking for TD Oil Pump Top/Cap MG 0
johnrip Wedge TR7 oil pump Triumph 2
