NLA SU HS6 part request
tdskip
Hi guys - under the heading of you never quite know what you've got until you tear them down... One of the HS6 carbs for the TR4A is missing the spring shown below. It goes in between the nut and the body/face of the arm that controls the movement of the jet.
As installed;
With bolt loosened;
By itself. Sorry - slightly blurry standalone shot;
At least I'm a help to you. At the moment my daughter thinks I'm worthless!
You know, it took me being a Dad to realize just how with-it my parents were... Or maybe it was when I realized that I better darn well have a job after graduating college in order to feed myself... But in any case she'll come around. Just might be a bit.
When did she turn 13?
Tom-
If Joe Curto can't help you, I think you can get that spring washer from Burlen in the UK:
HS6 parts
Not sure if I have the right part, but is it #36d on the diagram? If so, its dirt cheap.
Randy
17, she's just a little cranky at the moment. Usually get along great. Though, she hates the Wedge
I just bought a set of core hif6's from Ted Schumacher for parts. He may have something in the HS6 line also.
Zitch TR4/4A Who said the TR4 round shift knobs were NLA Triumph 4
G Spax Bugeye kit NLA? Spridgets 2
DrEntropy Bosch Plat Plus NLA? Other Cars 6
Brosky TR8 Visors NLA, so I did the next best thing Restoration & Tools 2
G Crush sleve NLA, whattaya do? Spridgets 12
G SU HS6 Carburetors Needle Jets Selection Austin Healey 3
KVH General Tech HS6 Carburetor Bushings Triumph 10
F TR4/4A SU HS6 jet initial adjustment jet not flush with bridge Triumph 7
F TR4/4A Replacement air filter for SU HS6 Triumph 6
Jayplum For Sale SU HS6 for sale along with a long intake Triumph Classifieds 3
Y TR6 SU HS6 question Triumph 1
J TR6 Moss HS6 SU conversion kit question Triumph 4
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
Carlos TR4/4A GROSE-JET or Viton-tip for SU HS6 carbs? Triumph 15
D TR4/4A SU HS6 throttle spindle size Triumph 20
BLong63AH HS6 BJ7 Carb Insulators Austin Healey 5
T TR4/4A HS6 problem Triumph 6
KVH TR4/4A Wish I Could Give Up--My Carbs Still HS6 TR4A Triumph 27
TRMark TR4/4A Convert from H6 and log to HS6 and 4A intake Triumph 6
trotti Calling all SU experts - Volvo HS6 Carbs Austin Healey 11
gbtr6 TR6 SU HS6 carb needle questions Triumph 17
KVH General Tech HS6 SU Carbs Triumph 1
RickB MGB HS6 or HIF4 bolt right on in place of Stromberg? MG 6
toysrrus TR2/3/3A HS6 Jet Assy Linkage Request Triumph 4
A BJ7 with HS6 SU Carbs - which needles Austin Healey 1
Simmo TR2/3/3A HS6 Carburettors Triumph 4
charleyf TR4/4A Hs6 carb rebuilding Triumph 8
KVH TR4/4A Carburetor Heat Shield for HS6 SUs Triumph 4
G TR4/4A tr4a hs6 carb Triumph 1
H TR4/4A 4A Throttle linkage for HS6 SU Triumph 2
Hap Waldrop SU H6 and HS6 carbs Triumph 9
B TR6 Hitachi HS6 HIF rebuild/TR6 Triumph 1
T SU HS6 tuning - lifting pin question Triumph 11
Lotuswins HS6's on a BJ8 motor Austin Healey 11
H TR6 TR6 HS6 Needle selection Triumph 0
TR4nut TR4/4A TR4A HS6 Factory writeup? Triumph 9
KVH HS6 SU Carbs Triumph 2
K H6 SU carb dome and HS6 carb dome? Triumph 9
T HS6 idle setting Triumph 3
R SU HS6 Carbs overflow leaking........... MG 20
T Anyone have a spare HS6 pivot bolt Triumph 13
S HS6 Carburetor Austin Healey 16
T One more SU HS6 question Triumph 25
T Float & needle adjustment on SU HS6 - slightly OT Triumph 20
KVH TR4/4A SU-HS6 Carb "Choke" Issue--My TR4A Triumph 8
T TR2/3/3A Will HS6 fit in TR3? Triumph 10
H HS6 Fixed needle centering tips Triumph 1
B Measurements of HS6 Carb MG 12
H TR6 TR6 HS6 Conversion Triumph 6
H HS6 JET identification Triumph 2
